big-phil
    12
Everything posted by big-phil
  1. I don't have a way to check the LSA. I will check to be sure my timing mark has not slipped.
  2. Yes MS is controlling it all. I'll try 15, or 10 at idle it just seems like it likes 30. At least that was with the stock cam.
  3. I'll have to check for sure what the hot side is, I'll also try the #2 hole, yes stock cam gear. I was going to port the other p90 I have also, and my intake aswell. Thats what it feels like, it just not getting the air. The cam sounds great at idle:-o
  4. its a regrind cam intake dur 290 lift 490 exhaust dur 280 lift 480 112 deg lobe sep. I used .230 lash pads to get the wipe pattern to look good. The first thing that seemed strange was I has to lean the entire map out, even in boost. The vac at idle was 21lb, now its 9-10lb. It just seems to not have any power unless your using the turbo? When the turbo does hit it feels good, and seems to make power above 6200rpm (thats as far as I have pushed it) I had the cam gear in the #1 hole, I changed it to the #3 hole. It might of made a diff. but I'm not sure? My timing at idle is 30deg, goes up to about 40 until boost, then drops to 24 at 17 lbs boost with the meth spraying. All in all it just is not as powerful before or after boost than the stock cam? It revs higher, but thats about it?? Am I missing something? Thanks **specs. holset hy turbo, supra 440cc injectors. stock p90 head no port. 60mm TB stock intake. 3 inch exhaust isky valve springs.
  5. O hell F-ing yeah!! If I EVER did a V-8 it would have to be turbo. That looks grrrrrreat!
  6. I had to pass my work truck. I put on a new CAT. Here is a little vid of the truck with straight pipes.
  7. I had one sensor go bad and this is my second one? They are both used so I don't know?
  8. I was kinda wondering the same thing all day today after I posted that? How can my intake temp be below the temp outside?? I might have a bad intake airtemp sensor? My meth does not spary untill 14-15 psi. But when the car idles, the output of the intercooler is "cold" Can anyone confirm if its possible for this to happen?:hs:
  9. how much boost did you have it at. And was it from a dig or was it a roll on from the "cough" track "cough"
  10. today with the outside air temp at 75deg F, my coolant temp was around the 185-191deg F mark, the intake air temp never got over 51deg F. When I feel the intake of the intercooler its hot, and the outlet feels almost cold. Like a can of soda thats been out of the fridge for 15-20 min or so?? Fricking intercooler is AWESOME! I got into boost a few time, but did not kick the car's a$$ or anything. Mostly normal driving. Hope that helps.
  11. hahahahahahahahahahahahahaha, thats great
  12. No not yet. I am waiting for the day I get pulled over for no front plate. Its been 3-4 years with no front plate, and never stopped??
  13. Looks great. Man I remember that feeling I had when mine started for the first time. Oh and no more videos like this! OR, the "BIG-PHIL" copy rights will come down on you like 20 pounds of boost:ass:
  14. It can print moving parts?!?!?!?! That blows my mind?
  15. this is weird, we lost our power on Halloween plus I took my truck to get the friend home. My daughter wanted to go also and trick or treat. I'll try to get a reading tomorrow.
  16. this is the funniest thing I've seen in a long time!! You do look kinda gay, but who frickin' cares. Your girlfriend is HOT!! Don't mind me, I dress as Elvis, and might look gayer than you? lol:grin:
  17. Man I just got back from a little tunning run. But I didn't notice what the air temp was. I have to take my daughters friend home in a bit. I'll hook the lap top back up and take a look.
  18. I'll take one, .....no...no, better make it two of those heads. Thanks.
  19. I drive mine everywhere!!! I love the sound of the turbo spinning up just a little as I gently go through the gears. And I love the BOV as I get on the highway. I drive it everyday.
  20. I've always wanted to do this also, just the paint. I have a Krammer striker 300st. Nothing special but I would like to paint it like God's guitar.....O, i mean Eddie Van Halen.
  21. Yup! I paid $150 for them. Not to bad I guess? I haven't seen them under $250-$300 in forever.
