big-phil
    12
Everything posted by big-phil
  1. I like it. Any problem I have ever had that I thought was megasquirt turned out to be something else. There is no customer support other than the internet. And if you put it on a Z there are plenty of people here that run it. But if the price of something else does not bother you than, I don't know? read about both and go from there?
  2. I hope you get it fixxed. How did the dogs do?
  3. I had the same problem. The car would strart, rev, but when I would try to drive it, or put it under load it would die. I changed my coil and that fixed it. thats what was wroung in this video I made.
  4. I've always run the "projected" type, I'll give the non a try. Thanks for the info!
  5. Thats funny I moved my Z out side, and put my HEMI truck inside. I fixed it once, I can fix it again. But we got no hail here.
  6. I did notice that when I gaped the 11's the arm was at an angle
  7. I just bought a new coil because the car started sputtering. It a Mallory promaster E coil 51,000 volts. I had a blaster 2 on there that was a loner until I could get one, and it still sputterd. My wires are almost new. Accel 8mm. Where is my igniter?
  8. some of those gaps seem big? I'm running NGK bpr7es-11 gapped at .025 and running 17lbs trying to run 20lbs but she keeps sputtering out? my gap was .028 but now .025 its running a little better but I still get a little sputter at high boost, if I lower the boost the sputter goes away. I'm going to get a new cap and rotor mine is kind of old, and that might also have a part in it.
  9. Are you using Adobe primire to edit? Did you figure it out?
  10. I'm not sure about your problem, but..... Your from Maine aren't you? Thats where I was born. I could tell from your Sig that says "WICKED" Prescott thats in Maine right? anyway...on with your problem, its sounds very vacuum related to me.
  11. I was showing what you have to do to it before you install it in the car, and also I replaced the vb921 that fires the coil. I thought mine went bad, but that was not it. It was the optical sensor in the distributor that went bad.
  12. should it always read "0" when closed?
  13. What kind of plugs: whats the gap: How much boost are you running:
  14. check all you conections going to the ecu. Clean them. You have the turbo distributor right? make sure the plug going to the under side of that is clean. Make sure the flap inside the afm is not stuck and it opens when giving it the gas.
  15. have you ever put it on the dyno? What size intercooler does it have? what size wheels, and do you have spacers?
  16. thats great news. I remember the feeling of the first start!
  17. man oh man the black centers look good! I was so on the fence on which color to get. Yes they do look good, oh yes.
  18. that is a super clean car! It makes me want to get mine to the body shop for a real nice paint job. The thing hanging on the mirror was cool, thats a great idea to show the G's in the turns, and also when you take off it comes at the camera. When you were first backing out of your driveway I was thinking "whats that big pile of white stuff?"........oh, snow.
  19. Hey you got it from All Z, cool. I've spent lots of $$$ there as well.
  20. yes, stiches. Lumpy scars suck
