waddiejohn Posted March 24, 2012 Share Posted March 24, 2012 I'd like to replace a couple of the 17mm vent hoses that run from the filler neck to the top of the fuel tank. They don't seem to be available.does anyone have a source? Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted March 24, 2012 Share Posted March 24, 2012 I just used fuel line from autozone, cut to length. Quote Link to comment Share on other sites More sharing options...
VKLR Posted March 24, 2012 Share Posted March 24, 2012 I just did mine. 5/8" fuel vapor hose from Napa. I also needed to get one 90 degree fitting for the line from "kidney" to tank. Quote Link to comment Share on other sites More sharing options...
at-jefft Posted March 24, 2012 Share Posted March 24, 2012 http://www.classiczcars.com/forums/showthread.php?19034-Treating-inside-outside-of-gas-tank-with-POR15-products-and-removing-evaporation-tank&p=149383&viewfull=1#post149383 I used some hose from a local hydraulic hose builder. Some hose clamps and I was good to go. Quote Link to comment Share on other sites More sharing options...
brianZortiz Posted March 24, 2012 Share Posted March 24, 2012 use NAPA, great quality and cheap and it works. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 24, 2012 Share Posted March 24, 2012 My solution is in the archives, there is a McFadden-Dale Hardware with the adapter fittings in Phoenix. Quote Link to comment Share on other sites More sharing options...
240z72 Posted March 29, 2012 Share Posted March 29, 2012 Napa has it all just use emissions or vapor or fuel NOT HEATER HOSE Quote Link to comment Share on other sites More sharing options...
waddiejohn Posted March 29, 2012 Author Share Posted March 29, 2012 Thanks to all who replied. I was hoping for factory molded hose, but I'm not going to be that picky and will follow suggestions presented. Waddie 1 Quote Link to comment Share on other sites More sharing options...
rossman Posted March 29, 2012 Share Posted March 29, 2012 (edited) If you want factory hoses, try Z Car Source: http://www.zcarsource.com/fuel-tank-vent-hoses_8_52880.html Edited March 29, 2012 by rossman Quote Link to comment Share on other sites More sharing options...
takayuki Posted March 30, 2012 Share Posted March 30, 2012 You can also try banzai motor works http://www.zzxdatsun.com/catRequests.php Quote Link to comment Share on other sites More sharing options...
