Oil Cooling Jets for Pistons Anyone?
TheSwede
Tim, how deep do you need to tap the threads for the banjo bolt? Can you please take some photos of the squiter with a ruler to get some approximate dimensions?
Edited by ctc
Ok,
So I was out the garage taking pictures of the block.
Photo one shows the location of the main oil galley that runs the length of the block (red line). The blue circles show the most likely canidate for squirter locations.
Photo two shows the front main bearing. Again, red shows the oil galleys and blue shows possible squiter locations. Based on the location of the main bearing feeds, I don't think it would be possible to locate a squirter one the main bearing feed. Also, looking at the bearing, I don't think the squiter in the main bearing cap would work very well. It would take a lot of mods, and the crank would shield the piston for some part of each revolution.
Photo three is the one JohnC posted earlier. I wanted to show that with a knife edged crank, the blue circled location would be a very good location for a squirter with very little potential for piston or crank interferance.
I think all you would need to do is spot face the block and drill and tap for the squirter. One note of caution that I have found in most of my research on others who have done this, is that piston and crank interferance will be engine specific and must be checked on assembly. I think with the stoker crank, things would get very tight.
Looks like you will have to tap threads at least 10mm deep. Sorry I didn't get a pic next to a ruler, but the article that you linked to did have one.
Long weekend - had a bit more progress...
Looks like this is going to clear on all 6 cylinders - I checked both the crank throws and the piston. Also the location shown intersects the main oil galley nicely and leaves plenty of material for tapping threads, even after sinking the flat a bit deeper to allow the nozzle to hug the block a more closely. I think I'm going to want to tweak the aim of the nozzle a bit to get better distribution of oil across the piston - anybody have any pics of how these are aimed in OEM installations?
  On 5/29/2012 at 6:03 PM, josh817 said:
How many motors does this guy have? Jeeze
Looks neat, are you going to angle the nozzle a little more out towards the piston pin rather than just rotate?
Its just the one motor :P
That's pretty much as far towards the center that I can rotate in order to stay out of the crank throws, so about all I can do is angle the spray out a bit. Currently it's aimed almost identically to your second pic. I'm considering aiming it such that it sprays just past the pin at TDC, so that I can get oil to the other side of the piston as well, i.e., it would spray the near side at BDC and the far side at TDC.
After looking at it in this light I think that the current orientation (rotation-wise) is probably better than pointing more toward the center, where the rod would be in the way of getting oil to the far side. Does that make sense?
Edited by TimZ
  • 4 weeks later...
Update - got the bottom end put back together today, and took some pics of the squirters:
I aimed (bent) the nozzle out and towards the center a bit, to try to aim it just under (above when it's right-side up) the piston pin at BDC, so hopefully the oil will disperse across the underside of the crown:
Edited by TimZ
Way to go!
The question I have is; how are you going to measure your results? It will be hard to quantify the effect you have made without some before and after comparison.
I know you were just covering all your bases, but the other members will demand data! You sir might have caused a revolution.
Edit: spelling
Edited by neotech84
  On 6/25/2012 at 4:36 PM, RB26powered74zcar said:
Do you have good clearance piston skirt to nozzle, as my pistons have a 1/2 moon relief in the skirts to clear the squirters on my RB26 motor...
Yes- in the pic above the piston is pretty much at BDC, so plenty of room there.
As far as my plans to quantify the results, I don't really have any. I'm not looking at this as a means to increase performance. To me this is more akin to the cylinder head coolant flow modifications - intuitively and directionally correct and should help with longevity, but pretty hard to come up with hard proof that it worked. If something breaks right away I guess that woyld be a different story, or if i (HEAVEN FORBID) end up with oil pressure issues then that's worth reporting.
Aside from that, I'm looking at this as something that should be a belts-and-suspenders approach to control the amount of heat in the piston and therefore leave it with a much better margin of safety at 600+ rwhp.
I see.... You could get some dino time in with the squirters installed so you can tune and set your upper level and gather data. Then drop the pan, remove and install some plugs. Then see if your data is the same. Sounds simple enough!!
Keep us posted.
Keep us posted.
Ummm, yyyyeeeeaaaahhh...
I'll get right on that. :P
