wiring guys help!!!
Don't waste your time fixing the sellers problems. Instead buy a clean 240Z that runs, has not had the wiring chopped up, is not a rust bucket and has not received a bunch of il-fitting parts forming a disgusting whole. You will thank yourself later.
With a carb you should be able to hot-wire it from under the hood. Power to the coil positive and a screwdriver on the starter posts. At least you'll get an idea of engine quality and can decide if fixing the wiring is worth it. Make sure it's in neutral before you jump the starter.
The car was running in December and it does turn over just not getting a spark
If it cranks the starter is good and the battery is likely to be good. After sitting for a while it could be bad gas or some other fuel related problem. For the price I would try to check the compression. If it has good compression you should be able to get it running without to much work. Also, try starting with ether. If will run for a minute on ether you will know it has spark at least, and you will get an opportunity to listen for any major noises.
After discussing the problem at length, the seller and I figured out that there is a fusible link out in the harness between the battery, ignition and starter. How hard are these to replace?
The fusible link is not hard to change. The 240Z only has 1 fusible link (from the factory). If it is bad nothing will work. No lights, no horn, won't crank, nothing. In an earlier post you said it cranks. If so, the fusible link is good.
It cranks by hand, forgot to mention that. It is the fusible link thats out because nothing electrical works
If the coil is bad it will not get spark. By turn over do you mean by hand or by the starter? From the vague description you have given I would offer 650 and take the car before u fix his problem and raises the price or sells it out from under you to someone else.
