turbogrill Posted August 17, 2016 Share Posted August 17, 2016 Hi, How reliable is a stock turbo engine vs a NA engine? My concern with turbo is that it is an additional thing that can brake while doing 10h+ endurace racing. The car is a 1980 280ZX NA and I need a little more power. 170-200 crank hp is fine. A typical race is 10hours non stop of going balls to the walls. This puts a tremendous stress on everything and all kinds of things brake all the time. Overheating and fuel consumption is also a problem. Reliability is MUCH more important than performance for endurance racing. (A shitty team with a shitty car will place much better than a "pro" team that has car issues, it is all about keep the car running). Any thoughts? Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted August 18, 2016 Share Posted August 18, 2016 For your needs, I would go for a lightly built NA L28. A stock L28 makes about 170hp stock as far as I know, so you don't have far to go to reach your goals. What's the budget like? I'm thinking some porting and polishing, a cam, and Megasquirt would probably do it for you. Or even just a stock engine with Megasquirt and a good tune. Quote Link to comment Share on other sites More sharing options...
turbogrill Posted August 18, 2016 Author Share Posted August 18, 2016 On 8/18/2016 at 12:35 AM, rturbo 930 said: For your needs, I would go for a lightly built NA L28. A stock L28 makes about 170hp stock as far as I know, so you don't have far to go to reach your goals. What's the budget like? I'm thinking some porting and polishing, a cam, and Megasquirt would probably do it for you. Or even just a stock engine with Megasquirt and a good tune. I am leaning towards something like that. A NA build will be 1.5x of the turbo cost for less HP, that is fine if I am paying for reliability. The 280zx has 170 crank HP gross , it has 135 crank HP net. Quote Link to comment Share on other sites More sharing options...
HuD 91gt Posted August 18, 2016 Share Posted August 18, 2016 People rave about how little their turbo swaps cost them. If your going for reliability it's not that cheap. A NA build, built by a reputable builder will get you your power goals for cheaper I'm betting. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted August 18, 2016 Share Posted August 18, 2016 (edited) NA build with carbs. Super cheap, super reliable. Large radiator and good, new hoses. I put this down with a stock engine L28 from a ZX with SU's and a 6-1 header. Car weighs in at 2100 lbs, and that does make a difference Edited August 18, 2016 by BluDestiny Quote Link to comment Share on other sites More sharing options...
Tony D Posted August 19, 2016 Share Posted August 19, 2016 It's a toss, most people aren't technologically savvy enough to properly prepare for endurance racing and stupid things break. On an N/A as well as a Turbo. Quote Link to comment Share on other sites More sharing options...
supernova_6969 Posted September 3, 2016 Share Posted September 3, 2016 (edited) I'd go for a NA... a well built one should last a long while, and provided it's build with the right cams and pistons, you should get plenty of power and torque without any lag. with a mild overbore, a flat or slightly domed piston, and you're good to go. the way i see it, in the end, you need to rebuild the engine one way or the other (I don't think any 30 year old engine without a relatively fresh rebuild will last 10 hours of flogging). and then if you turbo it, you need to buy a turbo on top of it. one thing for certain, no matter what the build, you need to start with a really good block, tested in a professional shop for cracks or other issues, potentially with all the mating/bearing surfaces redone (which could raise the compression, which is great for a NA motor, not so for a turbo). ****I just thought of this. if you go here http://forums.hybridz.org/topic/123487-compare-your-dyno-sheets-here/, you can see the dyno sheets of a bunch of engines, a few of them NA. that's show you what power they got with what parts... Edited September 3, 2016 by supernova_6969 Quote Link to comment Share on other sites More sharing options...
