Home Built by Jeff 0 Posted March 27, 2019 Author Share Posted March 27, 2019 In this episode I retrim the seats to match the rest of the trim in the 680g. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted March 30, 2019 Author Share Posted March 30, 2019 In this episode I fail to fit new wheel studs, but I swap in the new fuel filler and some other bits. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 3, 2019 Author Share Posted April 3, 2019 In this episode I revisit replacing the wheel studs and fit the sway bar and bushings. Quote Link to post Share on other sites
cgsheen 22 Posted April 3, 2019 Share Posted April 3, 2019 (edited) Poly bushings on the compression rod? You'll need to replace the poly bushing on the back side with a rubber bushing - otherwise you'll probably break the compression rod. Ask me how I know... There are a fair number of thread posts regarding the issue. Edited April 3, 2019 by cgsheen 1 Quote Link to post Share on other sites
Neverdone 31 Posted April 3, 2019 Share Posted April 3, 2019 Or he could just get adjustable compression rods with a rod end in it that allows it to pivot instead of trying to squeeze rubber to get its articulation. Quote Link to post Share on other sites
seattlejester 32 Posted April 3, 2019 Share Posted April 3, 2019 (edited) Or a g-machine ball and socket setup. I'd say from down right stupid to ideal. Weld it to the frame, poly bushings both sides, modified poly bushing both sides, poly 1 side/rubber 1 side, rubber both sides, rubber 1 side/ball and socket, rod-end, a-arm style arm. Edited April 3, 2019 by seattlejester Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 6, 2019 Author Share Posted April 6, 2019 In this episode I fit a 123 distributor to the 680g to hopefully get it running properly once and for all. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 10, 2019 Author Share Posted April 10, 2019 In this episode I sort out my timing issues and tune the car using the colour tune. Quote Link to post Share on other sites
winstonusmc 4 Posted April 10, 2019 Share Posted April 10, 2019 The hazard switch on the LHD 240z is to the right of the steering wheel, so I would assume it's to the left on the RHD. It is one of two holes, the other is the cig lighter. http://zhome.com/Classic/Restore/dash.htm Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 11, 2019 Author Share Posted April 11, 2019 12 hours ago, winstonusmc said: The hazard switch on the LHD 240z is to the right of the steering wheel, so I would assume it's to the left on the RHD. It is one of two holes, the other is the cig lighter. http://zhome.com/Classic/Restore/dash.htm I have indents there, but no holes. I have been informed since that Aussie cars didn't have hazard lights. Or cigarette lighters for that matter, which is weird as they have an ash tray? Quote Link to post Share on other sites
seattlejester 32 Posted April 11, 2019 Share Posted April 11, 2019 Interesting, maybe they stripped them down like how we have stripped down models domestically. Reminder to take another look at the TC bushings. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 13, 2019 Author Share Posted April 13, 2019 After 18 long months of tinkering in the garage, I finally get to drive the 680G. Quote Link to post Share on other sites
gogriz91 10 Posted April 14, 2019 Share Posted April 14, 2019 Congratulations Jeff, long time coming, car looks fantastic. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 14, 2019 Author Share Posted April 14, 2019 5 hours ago, gogriz91 said: Congratulations Jeff, long time coming, car looks fantastic. Thanks mate Quote Link to post Share on other sites
Home Built by Jeff 0 Posted April 18, 2019 Author Share Posted April 18, 2019 It is finally time to do something a bit more permanent about my spray booth. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted May 1, 2019 Author Share Posted May 1, 2019 Many of you have been asking me what is happening and I finally have an update for you, and some info on where I am planning to go in the future. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted May 11, 2019 Author Share Posted May 11, 2019 In this episode I delve a bit deeper into the tuning issues on the 680G. Quote Link to post Share on other sites
Home Built by Jeff 0 Posted May 15, 2019 Author Share Posted May 15, 2019 I finally sort out the running issues and no surprises it was my fault. We then tune it up on the dyno and get that final figure. Quote Link to post Share on other sites
cgsheen 22 Posted May 15, 2019 Share Posted May 15, 2019 We've found that most stock L28's dyno about 110 or less depending on condition. 150 RWHP in a Z makes a fun driver. Get it out on the road and enjoy it! Quote Link to post Share on other sites
Home Built by Jeff 0 Posted May 15, 2019 Author Share Posted May 15, 2019 6 hours ago, cgsheen said: We've found that most stock L28's dyno about 110 or less depending on condition. 150 RWHP in a Z makes a fun driver. Get it out on the road and enjoy it! Thanks mate. It was built as a fun street car, and I think it will deliver. Quote Link to post Share on other sites
