DuffyMahoney Posted February 1, 2024 Author Share Posted February 1, 2024 On 2/1/2024 at 5:12 PM, MONZTER said: In the past when I would bench and smooth out casting lines in parts you would always see the smooth ground areas in contrast to the original casting finish. What I would do is blast it with a heavy 36 grit aluminum oxide to add even texture on the entire part, then Vapor hone it to brighten it up. It looks great, almost as if it were originally cast like that. So something to consider vs just glass bead if you decide to smooth out any of the maching marks and go with a more classic cast look. Expand Got any pictures? Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted February 6, 2024 Author Share Posted February 6, 2024 (edited) I launched my Datsun parts company, for anyone looking. https://www.m2racing.com/ Thanks! Edited February 6, 2024 by DuffyMahoney Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted February 24, 2024 Author Share Posted February 24, 2024 ITB update! I got the dog bones/ rods shortened, design and had the cable mount made plus the fuel rail mounts. It’s almost ready to bolt in! I might try some surface finishing on the cnc intake. I don’t love the look of it. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted February 27, 2024 Author Share Posted February 27, 2024 (edited) Finally got the linkage sorted on my ITB. This is without an over head bar return spring (I will add tonight). The system is very smooth and returns strongly. Pretty stoked.; Edited February 27, 2024 by DuffyMahoney Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted March 3, 2024 Author Share Posted March 3, 2024 I finished the injector wiring. I cheated and used an RB harness and just redid a few of the lengths to be perfect. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted March 4, 2024 Author Share Posted March 4, 2024 I got my cnc intake and some parts back from media tumbling, it looks almost cast. I am super happy with the finish. Only issue it now shows finger prints. 1 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted March 5, 2024 Author Share Posted March 5, 2024 So nice Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted March 6, 2024 Author Share Posted March 6, 2024 All ITB test fitment is done. Cable mount is perfect, everything is smooth and actuates as good as I hoped. Now time to bolt it down, cut the cable to length and finish some wiring. I lined up the MZR haltech tuner to help me with my tune. It should be interesting to see how good he can get it, especially with my balance bar design and throttle angle. Will the snow melt so I can drive it soon? Probably not. 1 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted April 3, 2024 Author Share Posted April 3, 2024 My 3.1 is going back together! 48035565-3f87-41e9-8969-6a890e052731.mp4 Quote Link to comment Share on other sites More sharing options...
madkaw Posted April 5, 2024 Share Posted April 5, 2024 Looks like the same pistons I run with the dish . Smart man to put arrows on the pistons. You won’t put one in the wrong place like I did - lol. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted April 5, 2024 Author Share Posted April 5, 2024 On 4/5/2024 at 1:06 PM, madkaw said: Looks like the same pistons I run with the dish . Smart man to put arrows on the pistons. You won’t put one in the wrong place like I did - lol. Expand That's Andrews work! Pistons are eagle, sold by rebello. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted May 3, 2024 Author Share Posted May 3, 2024 (edited) Something fun I have been working on! I really want drive by wire on my 240z. But figuring out a location for the actuator has been tough to say the least. I don’t want it hanging over the intake. This is a 100% bolt in adapter featuring a BMW 6 cylinder actuator and a 350z pedal. This will attach to stock linkage and drive my ITBs. Hopefully it works! The pivot arcs a far bit, so that might not work and the pedal mount might flex too much? Time will tell. This would allow me modern cold starts, any sort of progressive pedal movement I could want. Full idle control, traction control, valet mode, cruise control and way easier tuning. We 3D scanned the pedal area and the actuator to mock it all up in CAD! All of this is 5axis cut out of 6061. IMG_2641.movFetching info... Edited May 3, 2024 by DuffyMahoney Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted May 5, 2024 Author Share Posted May 5, 2024 Well it works. But the firewall flexes too much, next I will try to mount to the pedal box which doesn’t flex at all. I also want to keep the arm movement on the same plane. Currently actuator is up and down and bell crank is left to right. IMG_2655.movFetching info... Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted July 2, 2024 Author Share Posted July 2, 2024 New ITB intake is getting sent off to China to CNC cut! This fixes a few mistakes on the first version and also gives me the stock J-hook pivot as an option. It will feature a bolt on banjo balance bar and ideal injector angles. It's slightly longer then the last version as well. 1 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted August 9, 2024 Author Share Posted August 9, 2024 Wow is all I can say 464f5f2c-e7c2-4dd9-affb-6d86115b0fea.mp4 1 Quote Link to comment Share on other sites More sharing options...
inline6m Posted August 20, 2024 Share Posted August 20, 2024 That came out nice. How much is something like that to make? Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted August 20, 2024 Author Share Posted August 20, 2024 On 8/20/2024 at 12:09 AM, inline6m said: That came out nice. How much is something like that to make? Expand Not terrible, but I had to buy 5. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted November 6, 2024 Author Share Posted November 6, 2024 Well drive by linkage is fast and accurate. Pretty darn stoked. I might try a few more actuators. Since the one I picked is being discontinued (BMW S54 13627840537) This should make anyone doing ITBs life much easier. Cold starts, traction, AC, intelligent throttle curves. This is just hooking it straight to a 12v source. So it’s just on or off. Actually when wired to the ecu, closing will be faster. This is returning via springs. When hooked up to the ecu. It’s powered open and closed. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted November 6, 2024 Author Share Posted November 6, 2024 Crazy fast Quote Link to comment Share on other sites More sharing options...
Derek Posted November 7, 2024 Share Posted November 7, 2024 Congratulations you have finally gotten a "I must have that" out of me. Great job. Quote Link to comment Share on other sites More sharing options...
