  • 4 weeks later...
looks like you have a good start on it.  My concern would be the rails.  they made need to be patched, and using a V8, and modified at that, BEEFY rails would be a good idea.  Some guys have even using thick steel runs of pipe that are U channel .  I attached pics of my car and some of the patching done.  MY car had 45K original miles and 30 years of its life sitting in an airplane hanger and I STILL had to fix the rails.  I attached a close up pic I got from one of your pics, and it already looks like it needs attention.   here is a link to watch :
  • Like 1
Thanks for the advice. The passenger side rail near the back definitely needs attention. I still haven’t decided what to do, been going back and forth with a repair, or possibly replace all of them. I know Apex sells a set that looks decent, hadn’t put too much thought into trying to make some myself. If I do a full replace I definitely want something beefy.
They've been the standard for a long time. Recently some other options have come onto the market, Capital Metal Works being one, but I've never heard a bad word about Bad Dog.
  • Like 1
yeah, Bad Dogs I hear are good, and that you can put them over the factory ones, but if the factory ones are rusty, then they need to be repaired/patched first or removed and replaced with these.  I I think they way blok did his with thick heavy steel is probably the ultimate (the youtube link I posted earlier).
  • Like 2
Got some time on the car today, everything is prepped and ready to pull the motor/transmission. Will be a few weeks before I can get back on it though. Pulling out the shifter I discovered a lot of wiring wire there touching the drive shaft, smh. Good thing I’m re-wiring this thing from scratch. Did a mock pull, hooking up to hoist, found out I need some thinner shackles, couldn’t get chains on. Looked at the frame rails too, only a little rust on one spot, but they are banged up a bit. I think I’ll cut out the rusted section, about 8”-10” or so and get the bull dog rails. I’ll order that after I pull the motor.
  • Haha 1
