7 dyno pulls and 1/4 tank of gas later...
TimZ
23psi, 94 octane Sunoco pump gas...
...so how do you spell booya, anyway? :twisted:
***EDIT***
The pulls were done in 4th gear (1:1), and the corresponding engine rpms are as follows:
80mph = 3870rpm
90mph = 4340rpm
100mph = 4850rpm
110mph = 5320rpm
120mph = 5790rpm
130mph = 6300rpm
140mph = 6770rpm
150mph = 7230rpm
160mph = 7750rpm
***EDIT***
...the first graph was the best pull - the second shows a very similar pull that continued to 7600rpm (I quit too early on the first one).
The last pic is a comparison to my last trip to the dyno about a year and a half ago - blue=old red=new
The main difference today was the elgin cam vs the very mild Isky cam that I was using before.
The ignition pickup for the Dynojet was a little flaky today, which is what was causing the spikes in the torque reading - It appears that the torque was maxxing out at about 470 lb-ft or so.
Sorry if I sounded too cocky - I'm just pretty pumped by the results. :D:D:D:D:D
  • Replies 75
NICE.... i'm not sure if you've posted elsewhere, so mind sharing the specs of your build so we can get a overview of the motor?
TEC-II EFI system rev limiter at 7200rpm
ported and polished N42' date=' 7.5:1 cr
stroked to 3.0 litres[/quote']
at least thats a small bit of what I found searching through his previous post.
Tim those numbers are incredible! do you think she has any more in her?
Thanks' date=' guys - I guess it's been a while since I posted the details on my car...
Engine:
nitrided/balanced stroker crank
Cunningham forged rods, 5.300"
Diamond Forged pistons, 87.5mm ceramic coated
N42 head, polished and ported - 209.5cfm intake, 135.2cfm exhaust at .540 lift, 25" vacuum, combustion chambers and exhaust ports also ceramic coated
the combustion chambers are still open chambers - no detonation problems so far
7.5:1 cr
Elgin cam, .536 lift, 237deg@.050", 112 lobe centers
TWM 45mm ITBs, custom plenum with internal velocity stacks
T64 turbo, .84 AR o-trim turbine
custom (SFP) log-style turbo header
HKS 60mm wastegate
3" exhaust, seperate 2.25" exhaust for the wastegate
Electromotive TEC-II, LM1 wideband
Trans/Clutch/Diff
GForce T5 gearset housed in a modified Datsun T5 case
Clutch Specialties clutch (ACT 500lb-ft pp with sprung hub sintered iron disk)
custom driveshaft
R230 diff, KAAZ LSD, Modern Motorsports Moser halfshaft and stub axles
Here are a couple of pics, I should be able to dig up more if anybody wants to see them.
BTW, since these pics were taken, I have given up on the electric water pump and electric fan - today's pulls were done with the good old-fashioned stock mechanical pump and viscous-coupled fan.
[img']http://home.comcast.net/~tzwicky/pics/Engine_090.jpg[/img]Engine_109.jpg
Where did you get that great looking header? Or who made it? Those are great Numbers!!
Ahhhh... the South Florida Performance header. Brings back many memories. The final product ended up quite good, but there were many many frustrating moments in the buildup of that piece. If you were to take your car to them and leave it, they could probably do a decent job, but I would not recommend trying to have them make you one any other way, unfortunately (actually, I seriously doubt that they would be interested in making any more, anyway). Joel can probably fill you in on some of the horror stories, too...
I would not recommend doing business on any level with SFP. The header I bought from them was garbage from the get go and they never would make it right. Ended up getting a $1000 store credit after going round and round with frank a few times and him refusing to give me a refund on it. They are such a hassle to deal with that I still haven't redeemed all of my credit.
Sorry for the rant.
JT
