front control arm options?
This may be a dumb question on my part, but, why?
tightens the turning radius. a guy on the s12 board put some s14 arms on his s12, the car looks like it can almost turn on itself. i don't want something that drastic, just a sharper turn over stock.
This is another dorifto thing, isn't it... :? I think he's thinking of the rack spacers that make the tie rods shorter than the control arm. Somebody brought them up a while back and what they do is fit in the end of the rack and they space the inner tie rod out so that the distance between the inner and outer tie rod are a shorter length than the distance between the control arm bushing and ball joint. This F's up the bumpsteer sumthin' fierce, but allows you to catch the *** end when it's way out there, and since drifters aren't going fast, maybe they don't care about the negative effects.
The problem is that when you install a longer control arm, you have to lengthen the tie rod, otherwise you're going to have some massive toe in. So basically extending the control arm doesn't do anything to the relationship of the control arm to the tie rod, other than screw up the toe. When you fix the toe then you'll see that your control arms and tie rods are once again the same length. Longer control arms would give you more negative camber. That's about it.
