rustoleum...got it right this time
OlderThanMe
Rustoleum in the not too far past had a paint that they offered to "Custom" mix. I still have a chart at the shop. I will get it this week and find out more. They still offer Tremclad in Canada that can be mixed in over 100 colors, but not here in the US.
I would think that any paint store that does computer mixing could still do a computer match using White Rustoluem as a base. Well, maybe not a perfect match, but better than a S.W.A.G..
Here again is a test fender of mine in Rustoleum!
The lady at Home Depot's Paint Department asked me "What in God's Name are you going to paint with this?" I still have this fender in the shop, the paint is almost bullet proof after 2 years. It is very reluctant to chip or scratch.
That color is a genuine Rustoleum Color! As I posted, they had a chart of over 100 colors that the retail store would "custom" mix using Rustoluem base paint. I have not seen the bases in Home Despot in a while, but the chart is still hanging on the shelf! I do not want to rant here about Home Despot here, becuase if I get started, I may not stop.
Anyway, a decent paint store that has Rustoleum products should be able to mix anything using the Rustoleum white as a base.
Look at:
http://www.rustoleum.com/product.asp?frm_product_id=555&SBL=5
The Tremclad seems to describe what I had used for my test fender. Anyway, I will grab that color chart and scan & post. Better yet, I will go to the paint shop and see if I can get the recipes for tinting the bases.
  • Like 1
I sprayed some MINWAX indoor/outdoor spar Urethane on a test piece. I sanded the piece to 600 grit first. The gloss is great. It might be a way to minimized the sanding and possibly polishing the whole car. A quart can of this stuff might be available. Application to the lower half of the car is my thinking. You still would want to sand the clear with 600 or 800 before applying a second and third coat for durability. The upper half of the car could get additional sanding to 1000 or 1500 grit and polished.
I was thinking 4-5 coats minimum when spraying it. Rolling it looks like it goes on thicker for a single coat. My first coat is still alittle transparent, but it's only been about 16 hours and the paint is already fairly durable. Most other paints I can almost scrape the paint off with a finger nail but this stuff just marks alittle, should be really strong when it's cured. I love the fact that touch up's would be so easy with it. Imagine what you could do with the extra $1500 - $2500 you didn't spend on a paint job.
240zv8... are you still doing this on a test piece or are you doing the car? if you are doing the test peice, i noticed it was galvanized. i say this b/c galvanized steel require a special paint from what i read recently and that may be why you can almost scrap the paint off with your fingernail. if you are not describing your test piece disregard this. b/s that how is your compressor handling the spraying?
the rolling puts it on thick but...you get low spots. You have to sand them out.
Veritech: As soon as I can come up with a wicked neon green color I will put it over the gloss black. I'll probably get some pinstriping tape (like if I were doing flames) to do the outline and then add regular painters tape outside of the pinstripe tape to keep the rollover off.
clearcoat:
the problem is that you can't go back and sand more and do an easy repair. If you do a wax it would be fine but I would not do a clearcoat.
the rustoleum doesn't scratch off, I was talking about other auto paints that i've used. Within 16 hours of drying they would be easy to scratch, but the rustoleum is already really strong. I'm not sure about the difference when you want to paint galvanized, but it turned out fine.
I was really happy with the compressor and paint gun, it only ran about 20% of the time, and I mixed the paint to about the consistancy of whip cream but alittle thinner. It wasn't watery, and it sprayed great.
OTM there is one big benefit of regular autopaint, the flash time of 15-30 minuts between coats makes them better in that you can get a whole paintjob done in a day instead of one coat a day. But the overal price and touch up value makes it worth it.
tomorrow morning I will add the fourth coat to the roof and wetsand with 600 grit paper. then I will decide if I need to add another final coat before polishing. Once I get the roof done I will do the rear fenders, doors, and hood (you have to lean against the side of the car to sand the roof..).
This is going to look soo great!!!
I will go out tomorrow and get some 1000 and 1500 grit paper to get a good finish.
you might wanna grab one of those $20 buffer's from HF, it will save ur arm...lol
OTM, after you sand it, what do you clean it with before you roll again?
