Forces Posted January 10, 2007 Share Posted January 10, 2007 I finally started her up today. After all the set backs and BS I went through, it was all worth it. Still have a long way to go though. No interior, no exhaust, and no rear lights. among other things. The exhaust I think is gonna be an issue. I am in the middle now of relocating the oil filter so the d/s pipe doesn't get in the way of changing the oil. *EDIT* Any one have any advice on routing for dual exhaust?? I've seen plenty of cars on this sight with a single 3" pipe, but not many with dual. There is still a lot of work to be done, as you can see, but I'm making progress. Quote Link to comment Share on other sites More sharing options...
rdsk8ter Posted January 10, 2007 Share Posted January 10, 2007 i agree pics would be sweet too Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted January 10, 2007 Share Posted January 10, 2007 I finally started her up today. After all the set backs and BS I went through, it was all worth it. Still have a long way to go though. No interior, no exhaust, and no rear lights. among other things. The exhaust I think is gonna be an issue. I am in the middle now of relocating the oil filter so the d/s pipe doesn't get in the way of changing the oil. *EDIT* Any one have any advice on routing for dual exhaust?? I've seen plenty of cars on this sight with a single 3" pipe, but not many with dual. With dual exhaust, you are going to have to center your gas tank. Quote Link to comment Share on other sites More sharing options...
primadonna z Posted January 10, 2007 Share Posted January 10, 2007 Here's the way I did it. I used oval tube. Quote Link to comment Share on other sites More sharing options...
Ferd/289 Posted January 10, 2007 Share Posted January 10, 2007 wonderful work. I have never seen oval tubing. It looks awesome. Ferd Quote Link to comment Share on other sites More sharing options...
deja Posted January 10, 2007 Share Posted January 10, 2007 Here's the way I did it. I used oval tube. That is a sweet exhaust setup, never knew they made oval pipe. Damn dude, those are some monster tires you have on the rear! Quote Link to comment Share on other sites More sharing options...
primadonna z Posted January 10, 2007 Share Posted January 10, 2007 wonderful work. I have never seen oval tubing. It looks awesome.Ferd It's quite expensive, and difficult to work with but I needed the ground clearance. Pretty much like building a 12 foot long set of headers. You fabricate all directional changes from per-bent radiuses that you purchase. You can't bend the oval tubing. Then butt weld your joints. Here's a link to Spintech http://www.spintechmufflers.com/ I finished up with Aeroturbine mufflers (offical muffler of NASCAR). Loud, but sounds great. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 10, 2007 Share Posted January 10, 2007 Hooker makes a muffler with dual inlets and a single outlet. That is how I plan to run duals and still use a single muffler in the stock location. http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK%2D21510HKR&N=700+400390+4294922710+4294906128+115&autoview=sku We will see Quote Link to comment Share on other sites More sharing options...
Bartman Posted January 10, 2007 Share Posted January 10, 2007 Here's my dual 2.5" setup with an 'x' pipe exiting on either side of a fuel tank from an F-body LS1. More pic's: http://mysite.verizon.net/bzandbergen/Exhaust.htm Quote Link to comment Share on other sites More sharing options...
deja Posted January 10, 2007 Share Posted January 10, 2007 Hooker makes a muffler with dual inlets and a single outlet. That is how I plan to run duals and still use a single muffler in the stock location. http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK%2D21510HKR&N=700+400390+4294922710+4294906128+115&autoview=sku We will see I thought about that muffler too, but at 22" long its gonna be a tight fit. I ended up with dual "turbo" muffers ahead of the rear axel and dul tail pipes coming out at the stock location. Its loud but sounds pretty mean. I don't have the "X" pipe but plan on installing one diring the LT1 swap. http://www.dejavideo.net/280z8/280z8-sound.mp3 Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted January 10, 2007 Share Posted January 10, 2007 Very Impressive, I like it. John Quote Link to comment Share on other sites More sharing options...
b__sosick Posted January 10, 2007 Share Posted January 10, 2007 bunch of show offs!! Quote Link to comment Share on other sites More sharing options...
v80z Posted January 11, 2007 Share Posted January 11, 2007 Forces Awesome Man. Nothing like the first crank. Congrats. Please send pics and VIDEOOOOOOOOOOOOOOOO! with Sound Quote Link to comment Share on other sites More sharing options...
buZy Posted January 11, 2007 Share Posted January 11, 2007 I run the same x-over. Dual flowmasters. The previous owner installed the the air dam. Still cant decide if I like it but for now it works I guess. Quote Link to comment Share on other sites More sharing options...
