JMortensen Posted March 29, 2007 Share Posted March 29, 2007 Jon, I wouldn't weld it in because it is not really necessary and 2 you won't have acess to the parking brake stuff up above it. There is also a fuel / brake line bracket up there if you kept the stock stuff. Plus there is alway an outside chance either the mount or one of the isolator bolts could break. It would be nice to be able to remove the part under those circumstances. The one I made for my series 1 is more narrow than that unit. It has dead straight sides (no little wings down by the bolt holes) and is just wide enough to fit inbetween the protrusion and that metal ridge. The side of the mount is flush to the ridge. Are sure you can't hammer that pig up into place? What parking brake??? What fuel line bracket??? I'm SURE that I could hammer it in place. But I don't need to. The car is upside down on a rotisserie so I can take my time and cut it to fit nicely. The reason for wanting to weld it is to use the structure of the mount to strengthen the trans tunnel. The mount is pretty damn stout. Just seems like if I welded it in then that would make the tunnel more stout, and since the control arm mounts are right there too, that might be a good thing. It sounds like you did the right thing by making the mount narrower so you avoided all of this stuff. Since I know you won't want to do that, I would weld a plate over the 3 mounting holes, cut that tab off so the front down piece is straight, then move the whole thing forward so it is flush to that metal lip. That should get the mount forward of the protrusion. You can then drill new mounting holes and call it a day. Seems like just notching the mount is easier than all of that, because if you move it too far then there is a lip on the back of the trans tunnel that gets in the way. I'd have to grind the whole lip off all the way around the trans tunnel to get it to move into position. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 29, 2007 Share Posted March 29, 2007 No, you just move it up to the lip. In your pic it looks to be about as far back off that lip as the width of the red part you marked to notch. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 29, 2007 Share Posted March 29, 2007 No, you just move it up to the lip. In your pic it looks to be about as far back off that lip as the width of the red part you marked to notch. I'll have a look at that again later today. I think I tried it already and it wouldn't fit, but I'll check again and post whatever I find. Quote Link to comment Share on other sites More sharing options...
dsommer Posted March 29, 2007 Share Posted March 29, 2007 Just got mine via FEDEX. Thanks!!! Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted March 30, 2007 Share Posted March 30, 2007 Just got mine via FEDEX. NICE PART!!!!! Thanks!!! Danno74Z Quote Link to comment Share on other sites More sharing options...
HB280ZT Posted April 3, 2007 Share Posted April 3, 2007 Well I put the mount in my 77 280Z last night and it looks good. The only thing that I needed to do was to slot the bolt holes a bit so it would fit. Here is what I did to put it in: 1 - put car on jacks 2 - removed the exhaust 3 - loosen the tranverse link inner bolts 4 - removed the rearend crossmember 5 - dropped the front part of the sway bar 6 - removed the 4 strap bolts and strap assembly 7 - remove 30 years of built up crud!! 8 - lowered the front of the diff so that the mount could be put in place 9 - installed the 4 old strap bolts into the 4 elongated mounting holes 10 - installed the crossmember 11 - tightened the transverse link inner bolts 12 - installed the sway bar 13 - installed the exhaust system 14 - tightened everything to specs 15 - take car off of jacks Now it is time to take the car out and drive the #$%^ out of it! Enjoy! HB280ZT Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted April 3, 2007 Author Share Posted April 3, 2007 To those that are waiting, Sorry I'm a little behind, I assure you your order will ship in the next day or two. Thanks Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted April 4, 2007 Author Share Posted April 4, 2007 All present orders are shipping today Quote Link to comment Share on other sites More sharing options...
Sven Posted April 6, 2007 Share Posted April 6, 2007 "It's in the mail" -Brad, you should see my MO before the weekend. Quote Link to comment Share on other sites More sharing options...
Forrest Posted April 6, 2007 Share Posted April 6, 2007 Did you get my check? Thanks, -Forrest Quote Link to comment Share on other sites More sharing options...
Zmanco Posted April 6, 2007 Share Posted April 6, 2007 All 5 arrived today and they look great! Thanks RoostMonkey! Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 6, 2007 Share Posted April 6, 2007 Well my order arrived I have only seen photos from my 3rd party state side buddy. Thanks RoostMonkey for 1. Making these, 2. Working with me to ship these to my mate Pete for collection when I visit him in June great stuff and excellent service from another hybridz.org member Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted April 6, 2007 Author Share Posted April 6, 2007 Yes Forrest, and its been shipped via FedEx. Quote Link to comment Share on other sites More sharing options...
Roostmonkey Posted April 6, 2007 Author Share Posted April 6, 2007 All brackets going out now are MIG welded. The first run were tig'd but I needed to speed the proccess up and since they're an unseen part,noone should care. Quote Link to comment Share on other sites More sharing options...
Savage42 Posted April 8, 2007 Share Posted April 8, 2007 Ya know, after looking through the Black Dragon catalog, seeing that the stock differential strap is $79.95 and you can get one of these with the GM mount for less money and it's WAY better.....it's all good! This forum and guys on it are awesome! Thanks for doing such a great job, taking time to make parts and sharing the info!! On a side note, I just took a new Z06 for a test drive and it really makes me want to get my Z done! It's crazy fast and the 505HP was quite a kick, but the Z will turn heads like no other Vette! Since power to weight will be about the same, it'll be fun to play on the road courses! I want it done now!! Quote Link to comment Share on other sites More sharing options...
John Scott Posted April 10, 2007 Share Posted April 10, 2007 Nice piece! Thanks Roostmonkey! Quote Link to comment Share on other sites More sharing options...
banditzed Posted April 13, 2007 Share Posted April 13, 2007 Mine arrived today, looks great! Thanks Roostmonkey Quote Link to comment Share on other sites More sharing options...
Guest loftyfang Posted April 16, 2007 Share Posted April 16, 2007 pm sent. Quote Link to comment Share on other sites More sharing options...
Guest loftyfang Posted April 18, 2007 Share Posted April 18, 2007 bump Quote Link to comment Share on other sites More sharing options...
mark Posted April 19, 2007 Share Posted April 19, 2007 Check is in the mail........Finally Quote Link to comment Share on other sites More sharing options...
