steveosupremeo Posted April 1, 2007 Share Posted April 1, 2007 so are they made to bolt up to a webber/cannon/mikuni runner setup or is there a spacer/adapter to do that with? life is good Kevin. looks like you've been very busy lately, lol. sounds great in the video by the way Quote Link to comment Share on other sites More sharing options...
steveosupremeo Posted April 1, 2007 Share Posted April 1, 2007 ooops, nevermind, just read the answer to my question about the base plates. what do you mean beta program? didn't see it mentioned on the website... Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 2, 2007 Share Posted April 2, 2007 I guess my quote didnt make sense.. Im thinking on the right page.. I edited my post and added $600 for ITB's (PLUS... I have to buy my own manifolds etc etc etc) Kevin, s30zforce mentioned he left me a PM and voicemail, so dont worry that one sorry PrOxLaMuS: I checked Private messages and had nothing if you are referring to here? Kevin Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 2, 2007 Share Posted April 2, 2007 niiice... I agree on the Alpha-N blend for ITB's. The TEC2 system we had on the Bonneville car was a DREAM off-idle with the PAFFZ-Blend software---used a blend of Alpha-N and MAP as the RPM rose. Much smoother than the pure-MAP based system we have on the thing now, but this one give us more power under the curve for whatever reason. Much more torque. You think 7cfm per throttle is bad, try a Six Cylinder engine total displacement of 1998CC's breathing through 45mm ITB's...with a Bonneville Cam set up for shiftpoints in the 92-9500rpm range! Talk about no vacuum signal at idle....or off idle for that matter. Alpha-N is the way to go in that situation, for SURE! Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 2, 2007 Author Share Posted April 2, 2007 Hey Joel Got the Message and sent you a reply on our Beta install Program think you will like what you see! Thanks Mario! Kevin Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 2, 2007 Author Share Posted April 2, 2007 The Beta Program is for Applications we do not currently have running, which we do not currently have a Twin SU set-up running! You can see details of it here http://www.extrudabody.com/News.html The ITB system utilizes base Plates which we have to mount to basically any Weber Manifold, but custom Base plates can be used as well! Just have to make sure the ITB bolt pattern doesn't interfere with the bolt pattern of the base plate! If in doubt send us a Picture of a Gasket or the manifold base and we can tell you! Kevin Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 2, 2007 Author Share Posted April 2, 2007 Twin SU's in Polished and 1" Extensions! Kevin Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 2, 2007 Share Posted April 2, 2007 wow!! this is so cool. when are these available for purchase?! Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 2, 2007 Author Share Posted April 2, 2007 We are looking at 30 to 45 days before we hit the market with the 45mm ITB's, then 40mm and then 50mm! Kevin Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 2, 2007 Share Posted April 2, 2007 Whoo hoo! I landed quite a bit of money selling some old parts, so I am very interested in this! Definatly let me know! Quote Link to comment Share on other sites More sharing options...
Thanh Posted April 3, 2007 Share Posted April 3, 2007 This defnitely is making me interested. Might change my mind and go back to L-series motor . Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 3, 2007 Author Share Posted April 3, 2007 What about "Triple and tunable length 50mm ITBs" on a Stock 5MGE or 7MGE Manifold? Hahahaha! No end to Extrudabody's configurations only limited by the Designer of the intake and how good you are with a Drill Press! Quote Link to comment Share on other sites More sharing options...
justin260z Posted April 4, 2007 Share Posted April 4, 2007 Hey Guys: We are new and soon to be on the market help spread the word! New concept in ITB's where the whole system is Modular in design where the base plates are seperat from the Main Bodies, this allows us to manufacture main components and allows you the DIYer to build your own base plates or utilize our Weber base Plates! 40mm, 45mm, and 50mm! Everything is Anodized or Stainless, we will also have polished too! RETAIL will be in the $99 per ITB Price range! Website is www.extrudabody.com The Test bed below is just an old Weber Manifold and have no Idea who makes it! We designed everything else in the Picture except the Bolts! Please help pread the word! Thanks! Kevin Does that tiny hose work well for the brake booster? Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 4, 2007 Author Share Posted April 4, 2007 I would say no! Most of your older Manifolds that were ever fitted to cars with Power Brakes have a Brake Booster Port! If you look on the Manifold on #6 Runner you will see the Brake Booster Hose and Fitting, it has a "T" fitting in it to supply Vacuum to the Dash heater and A/C Components! The Vacuum Log has a 5/16ths fitting in it, and as a last resort could be used, but you run the risk of causing the MAP Sensor Signal to not be steady! Hope that helps! Kevin Quote Link to comment Share on other sites More sharing options...
z-ya Posted April 5, 2007 Share Posted April 5, 2007 Do your SU TBs have the same bolt pattern and bore diameter as the original Hitachi SUs used on 240Zs? Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 5, 2007 Author Share Posted April 5, 2007 We are starting with 45mm then 40mm and then going to 50mm! Honestly I am not exactly sure what size they are? Sorry! Our SU Base plates are designed to be SU/Universal and our ITB bolt pattern is a "+" Pattern because most manifolds use a "X" Pattern to bolt to the Head or Crab Bases! The ones pictured on this thread will bolt directly to the SSS 510 Manifold, which is 3" or 75mm C to C on a 45 Degree Angle! The 510 SSS Manifold is "Pictured" Bored to 45mm with a blending down in the manifold where the Ports divide! It cuts into the Water passage of the Manifold, so it has to be Blocked off at the Manifold/Head Junction! To answer your question on the "bolt to a Z Hitachi manifold", they can be made to if they don't now! We can also make a 100 run of any Base Plate that we have a Market for, very economically! I will also make you a Set of Specific Base Plates if that's what it takes! I see by your By-line what you do! Contact number is 850-835-1588 comes direct to my desk if you want to chat about a Dealership! Thanks for the Interest! Kevin Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted April 6, 2007 Share Posted April 6, 2007 Thanks Kevin!! I sent you the Beta Program payment, and the rb26 intake and ITB's to use as a pattern. We should have a working set up to show off to everyone, soon as you get up and running with the first batch of Extrudabody ITB's. I can't wait to see how they look/perform on the rb motors... Please keep me and everyone here updated as you progress with the fabrication of your ITB's... thanks - joel Hey Joel Got the Message and sent you a reply on our Beta install Program think you will like what you see! Thanks Mario! Kevin Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 6, 2007 Share Posted April 6, 2007 I thought the RB26 came with ITB's from the factory?! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted April 6, 2007 Share Posted April 6, 2007 I thought the RB26 came with ITB's from the factory?! It does.... but have you noticed yet, I'm kinda into custom intake/exhaust parts. (I still have all the oem ITB stuff, just want something special) Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 6, 2007 Author Share Posted April 6, 2007 Hey Joel Will Do! By the Way I use to Work for Amerisafe in Deridder! LOL! Use to hunt Duck in Holly Beach too! LOL! Kevin Quote Link to comment Share on other sites More sharing options...
