palauoriginal Posted October 22, 2007 Share Posted October 22, 2007 i was wondering if wheels off of a 4 lug celica/supra(82 - 85 i think) wheels would fit properly on a s30. like these: Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted October 22, 2007 Share Posted October 22, 2007 I believe they fit but I think you need some wheel spacers. Buzz has Supra wheels on his Z but they are Momo aftermarket Supra wheels. He uses a 1" spacer in the front and 1/4" in the back I think. The spacers might not be needed with stock Supra wheels. Bolt pattern is correct. Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted October 22, 2007 Author Share Posted October 22, 2007 cool thanks man im going to have to get spacers then. got a good deal on some so im going to get them since they fit. anyone have pics with them on? Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted October 22, 2007 Share Posted October 22, 2007 I believe the center hole needs to get machined to a larger diameter for it to fit over the Z hub - no adapters/spacers needed... Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted October 22, 2007 Share Posted October 22, 2007 Does/did Ivan280zT run the rears? Mario Quote Link to comment Share on other sites More sharing options...
jerryb Posted October 22, 2007 Share Posted October 22, 2007 Ive seen those on a number of 240s. I cant say for sure but I think Toyota made a wider version for aother model...truck? Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted October 22, 2007 Share Posted October 22, 2007 I think they only made the one size, 14 X 7, and they came on Supras and some Celica GTs. I have a set on my '71. The center holes on the wheels do need to be opened up to fit over the S30 front hubs, but the rears, if your rear setup is stock, don't require it since the stock rear hub/drum area is flat. I went ahead and enlarged the hole on all four rims to make tire rotating easier. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 22, 2007 Share Posted October 22, 2007 they made 14s and 15s with different offsets. there is a 510 wheel fitment site that has all of the 411, but it's been down for the past couple weeks Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted October 22, 2007 Author Share Posted October 22, 2007 im going to be picking some supras up today so ill post some pictures on how they fit. Quote Link to comment Share on other sites More sharing options...
supra goddess Posted October 22, 2007 Share Posted October 22, 2007 These wheels are 14x7" +8mm offset and were available from 1982-86 on the Supra "P" type models AND Celica GT-S models from 1982-1985. In 1985, the Supra L model got 15x6" wheels in a similar style, just not as "dished"... +20 offset, VERY hard to find, so if you find these snatch 'em up. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 22, 2007 Share Posted October 22, 2007 These wheels are 14x7" +8mm offset and were available from 1982-86 on the Supra "P" type models AND Celica GT-S models from 1982-1985. In 1985, the Supra L model got 15x6" wheels in a similar style, just not as "dished"... +20 offset, VERY hard to find, so if you find these snatch 'em up. perfect person to post Quote Link to comment Share on other sites More sharing options...
zcarnut Posted October 22, 2007 Share Posted October 22, 2007 Another thread about these wheels: http://forums.hybridz.org/showthread.php?t=107965 Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted October 23, 2007 Author Share Posted October 23, 2007 ^thats a good thread..didnt see it srry. anyways heres pics of them mounted heres wheres the z hub/drums in the rear with the wheels on. you can see where interference is. i tried the front but there is no way of getting them on without widening the middle hole. Quote Link to comment Share on other sites More sharing options...
hondabait Posted October 25, 2007 Share Posted October 25, 2007 what is the bolt pattern and stock offset of the s30? Any how much do the supra wheels weigh? Quote Link to comment Share on other sites More sharing options...
zcarnut Posted October 25, 2007 Share Posted October 25, 2007 what is the bolt pattern and stock offset of the s30? Any how much do the supra wheels weigh? http://kmhafer.datsun510.com/wheelFAQ.htm Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 25, 2007 Share Posted October 25, 2007 http://kmhafer.datsun510.com/wheelFAQ.htm yay! been waiting a month for that site to be up! Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted October 29, 2007 Share Posted October 29, 2007 http://kmhafer.datsun510.com/wheelFAQ.htm Awesome site! I remember seeing my 6 spokes on ebay with a shipping weight of 13lbs, but figured that can't be right. And my swasticas are only 14lbs? Makes buying aftermarket wheels far less tempting. Quote Link to comment Share on other sites More sharing options...
Austin240Z Posted October 29, 2007 Share Posted October 29, 2007 I believe the center hole needs to get machined to a larger diameter for it to fit over the Z hub - no adapters/spacers needed... I have a set in my garage, and the above statement is very true. They will not fit without modification Quote Link to comment Share on other sites More sharing options...
