boardkid280z Posted January 24, 2008 Share Posted January 24, 2008 Here are a few pictures of my progress this past week. My roommate and I have been working hard on getting my motor put together. It has taken a while to get all the parts together. I've really just done all the cleaning and painting this past week. I think I have all the parts to finish it... just need to get some pusher fans as the SC setup takes a lot of room on the front of the motor. The throttle body is a TBI (Throttle Body Injection) off of a GM 4.3 V6 or something like that. The Supercharger and manifold are from Jim Cook Racing's kit. The header came with a $200 2.6L motor I picked up. P90 head (only dirty part on the motor ) with flattops. And I have an aluminum radiator from JTR waiting to go in. Megasquirt is already installed... I've been using it on a turbo setup for a while, it will need a little modifying and cleaning up, but it's basically ready to go. Enjoy! Quote Link to comment Share on other sites More sharing options...
steveosupremeo Posted January 24, 2008 Share Posted January 24, 2008 that looks awesome! love the TBI idea. would the low profile holley air filter with a filter on each side work? might dress it up a bit more?? but it looks great as is. Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted January 24, 2008 Share Posted January 24, 2008 That looks great!.. I am anctious to see what she can do. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted January 24, 2008 Share Posted January 24, 2008 That's just plain amazing. Quote Link to comment Share on other sites More sharing options...
RedEvilrps13 Posted January 24, 2008 Share Posted January 24, 2008 That S/C looks like a BEAST! my only question is this: how close is it going to be to the side of the engine bay? it looks like the clearance is going to me daaaaaaaamned close! Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted January 24, 2008 Share Posted January 24, 2008 Look at this post. http://forums.hybridz.org/showthread.php?t=99330&highlight=supercharger&page=2 It looks like the same set up to me. Quote Link to comment Share on other sites More sharing options...
phantaz Posted January 24, 2008 Share Posted January 24, 2008 Hows the clearance looking between the TBI and the inner fenderwells?? looks really really tight from that front view? Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted January 24, 2008 Author Share Posted January 24, 2008 steveo- I might look into the lo-pro holly filter. I just got this cheap one cuz I figured smaller would be better and I didn't want to have to run out and get one when the car was ready to run. It looks kind of small now, I'm not sure I really like it. I'll see how it sits and fits in the car and go from there. I'll have to see later if there is an easy way to get cold air to the inlet, instead of filtering hot air from the engine bay. red and phantaz- I don't think clearance will be an issue. The motor sits straight up on the engine stand, and there is actually quite a slant when it sits in the car. The kit is made for a Holly TBI so I don't think there will be much difference... although I won't know till we drop the motor in this weekend. KJones' setup is different than mine, he made his own that is similar but it isn't a JCR kit. The picture below (posted by SHO-Z in the thread linked above) shows where the top of the supercharger sits behind the wheel well. It s the same kit as mine, so I think there will be enough room, as long as it fits under the hood. Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted January 24, 2008 Share Posted January 24, 2008 cool, someone posted a pic of my old 280zsc engine. the intake you see is the way i pulled air from other than in the engine bay and solved the low engine to throttle body clearance. the intake wrapped under the sc, then forward to another tube then in front of the radiator to a cone filter. worked great. we used some old kc130 internal fuel tank fittings for the elbow and flat aluminum stock to fab the piece that fit over the tb. tig'd it all together, and polished! The picture below (posted by SHO-Z in the thread linked above) shows where the top of the supercharger sits behind the wheel well. It s the same kit as mine, so I think there will be enough room, as long as it fits under the hood. Quote Link to comment Share on other sites More sharing options...
Challenger Posted January 24, 2008 Share Posted January 24, 2008 Looks great! So the TBI is basically just a TB with injectors in it, does this work good compared to conventional fuel injection (injectors at the end of the runners)? Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted January 25, 2008 Author Share Posted January 25, 2008 Not much work done tonight, stayed up too late last night, so I need to get to bed "early" tonight. Here's a couple of pics. First one is some black (lines) and dark grey (lettering) I did on the valve cover. The others are closeups of the TBI; just need to make a bracket to mount the end of the throttle cable to and attach the fuel lines somehow. I've got some stock TBI fuel lines with the fittings and about 2 ft of hard line. I think I'll bend it so it extends straight back to the firewall and use rubber hose from there to connect it to the stock hard lines. Which brings up one question, and I'll post this under fuel delivery also: If I use the pressure regulator in the TBI to run 15psi is there a problem qith using the stock fuel pump, or will the lower pressure mess up the pump. I thought lowering the pressure reduces the strain on the fuel pump allowing it to flow more fuel (lbs/hr) with no adverse effects. Anyone have any experience with this? Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted January 25, 2008 Share Posted January 25, 2008 man that looks good, all of it except one thing... because everything is so clean and all your old/dirty/non polished thermostat housing sticks out like a sore thumb... but man that thing is going to be fun... very nice Quote Link to comment Share on other sites More sharing options...
z-ya Posted January 26, 2008 Share Posted January 26, 2008 Looks great! You definitely need a lower profile air cleaner. Also, a knock sensor is a good idea. I ran a similar setup (flat tops, P79, mild cam, 8.5:1 CR) on my road racer and eventually had a melt down. Running 180WHP NA L28 now. L28ET waiting in the wings. - Intake air temps reached over 280F (you should do better running it wet) - The SC is so loud (especially without an air cleaner and cowl hood), that you cannot hear detonation when it happens. - Those old Camden superchargers generate a lot of heat. Dyno plot before and after SC: Racing trim: Quote Link to comment Share on other sites More sharing options...
TimZ Posted January 26, 2008 Share Posted January 26, 2008 Looks great! You definitely need a lower profile air cleaner. Also, a knock sensor is a good idea. I ran a similar setup (flat tops, P79, mild cam, 8.5:1 CR) on my road racer and eventually had a melt down. Running 180WHP NA L28 now. L28ET waiting in the wings. - Intake air temps reached over 280F (you should do better running it wet) - The SC is so loud (especially without an air cleaner and cowl hood), that you cannot hear detonation when it happens. - Those old Camden superchargers generate a lot of heat. That setup does look really nice. Pete - did you experience any problems with fuel puddling in the low point under the SC? Looks like you were still using port injection and maybe just using the TBI as supplemental? I was just wondering since it appears that boardkid is going to be getting all of his fuel from the TBI. Maybe the SC does a sufficient job of atomising the fuel so that won't happen. .. because everything is so clean and all your old/dirty/non polished thermostat housing sticks out like a sore thumb... ya know... I've got a polished thermostat housing outlet (the part that the hose connects to) laying around that I could let go of cheap... Quote Link to comment Share on other sites More sharing options...
z-ya Posted January 26, 2008 Share Posted January 26, 2008 That setup does look really nice. Pete - did you experience any problems with fuel puddling in the low point under the SC? Looks like you were still using port injection and maybe just using the TBI as supplemental? I was just wondering since it appears that boardkid is going to be getting all of his fuel from the TBI. Maybe the SC does a sufficient job of atomising the fuel so that won't happen.. I was using the port injectors only. No fuel puddling problems, just a lot of heat. The TB was just that, no injectors. So my point is that if he runs it wet (TBI), the intake air temp may not be a problem. Plus, I was using it on a road racer where I was pushing it really hard for 30minute sessions. I was planning on adding two more injectors just below the TB for cooling, but I melted the motor before I had a chance to. For street use, it is not a bad setup. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted January 26, 2008 Share Posted January 26, 2008 I do not know if all of the Eaton supercharges are the same. I took my M62 apart to check the rear bearings. They were needle bearing packed with grease with no seal. Gas could wash out the grease. Mine came off of a SLK Mercedes and is made to run dry. I have also heard that gas will eat the teflon coating on the rotors. This is just a heads up, you might ask around. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted January 26, 2008 Share Posted January 26, 2008 I think it's been discussed but these camden ones were made to be run wet even tho lots of people run them dry. Mario Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted January 26, 2008 Share Posted January 26, 2008 boardkid280z: Does that supercharger have an Internal bypass IE it can be turned off? and how much was the Jim Cook Kit? Quote Link to comment Share on other sites More sharing options...
rztmartini Posted January 28, 2008 Share Posted January 28, 2008 is jim cook racing selling the kits again? i called up a few times and was put on a "waiting list" after the passing of Jim (R.I.P.), but that was over a year ago? Maybe they forgot about the list... Quote Link to comment Share on other sites More sharing options...
Jesussalvdr Posted February 10, 2008 Share Posted February 10, 2008 any more info on this? I searched but not much has been mentioned about this kit. Quote Link to comment Share on other sites More sharing options...
