302 240Z Drag Video
Just Jim
The front suspension is completely stock, the rear has adjustable 250lb 8 inch long 2.5 I.D. springs. Both ends have cheap KYB replacement strut cartridges. The 4.11 R200 CLSD with 215/60R14 BFG Drag Radials have been good for a best of 1.575 60 ft.
What knid of HP and weight do you have? I've been tossing around the 4.11s for a while...with the GV overdrive it might work! I don't need to go over 140mph...ever.
Nope, don't need to go over 140.
Not sure on the HP but it might be about 340HP at the flywheel. I'm guessing the weight at about 2650. The key to running decent times at the drag strip is getting the power to the ground. 400-450HP won't be much good if the tires just spin.
