thehelix112 Posted November 26, 2008 Share Posted November 26, 2008 Guys, Does anyone have a recommendation for a budget (yet still accurate) probe-type tyre pyrometer? Is something like this http://www.soloperformance.com/Longacre-50640-Accutech-Digital-Pyro_p_98-1123.html par for the course? Many thanks, Dave Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted November 26, 2008 Share Posted November 26, 2008 I borrowed a friends snap-on pyrometer which was a gun/laser type and it was much easier to use than my probe type one. I just randomly found this one on eay.http://cgi.ebay.com/ebaymotors/LONGACRE-AccuTech-12-Memory-Laser-IR-Pyrometer-50614_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem220317449942QQitemZ220317449942QQptZRaceQ5fCarQ5fParts I'd be willing to go halfs on one if your interested. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted November 26, 2008 Author Share Posted November 26, 2008 I've just been reading about IR vs probe and everything points to if you're serious, get a probe one. I have an IR one in Aus but I've never used it. You wanna sell your probe-type one? Dave Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 26, 2008 Share Posted November 26, 2008 That is really splitting hairs on 'accuracy'. A cheap probe can be much slower to react than a cheap I/R, the key is taking the temps as quickly as possible after each run. While a multiple probe unit can measure across the tread at a predetermined interval and record/display the temps for an instantaneous readout, the same general impression can be had by sweeping with the I/R gun as well. How 'serious' are you to need Hundreth of a degree acuracy? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 26, 2008 Share Posted November 26, 2008 That is really splitting hairs on 'accuracy'.A cheap probe can be much slower to react than a cheap I/R, the key is taking the temps as quickly as possible after each run. Eh, if you figure the outer layer is exposed to the air during a cool down lap, I think the probe really is the way to go. This coming from a guy who has used an IR up to this point... Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted November 26, 2008 Author Share Posted November 26, 2008 Tony, I'm only going by what I've read, both here and other places. E.g. http://forums.hybridz.org/showpost.php?p=540669&postcount=9 I think as long as you are consistent and methodical in your measurements, value can be gained irrespective. I.e. measure from the same side to side and the tyres in the same order each and every time. I was more wondering on people's experiences with different versions. E.g. This one: http://www.check-it-electronics.com/chec0316digt.html quotes 15 second response times. Can't find any specs on the Longacre one. Dave Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted November 26, 2008 Share Posted November 26, 2008 My mulimeter from craftsman has both built in. IR and a probe. Both work great. only cost around 100 dollars. not sure of the temperature range though. Im not sure they have it any more though. Quote Link to comment Share on other sites More sharing options...
Clifton Posted November 26, 2008 Share Posted November 26, 2008 I use an Intercomp tire pyro. It's pretty fast. I even use it when BBQing as the cheapo digital meat temp gauges take so long. Quote Link to comment Share on other sites More sharing options...
johnc Posted November 27, 2008 Share Posted November 27, 2008 I use both. The probe type gives true indication of tread temps and is the most useful and accurate when setting up a car for a specific track. Once I have a track setup logged, I use the IR temp sensor to quickly verify the setup on a return visit to the same track. The IR sensors are also helpful in diagnosing brake problems, finding dead cylinders, or checking trans and diff temps. So, you need both Quote Link to comment Share on other sites More sharing options...
johnc Posted November 27, 2008 Share Posted November 27, 2008 Recommendations: http://www.racerpartswholesale.com/product/1458/Longacre_Pyrometers http://www.racerpartswholesale.com/product/1454/Longacre_Pyrometers Quote Link to comment Share on other sites More sharing options...
rxsleeper Posted November 27, 2008 Share Posted November 27, 2008 I use both. The probe type gives true indication of tread temps and is the most useful and accurate when setting up a car for a specific track. Once I have a track setup logged, I use the IR temp sensor to quickly verify the setup on a return visit to the same track. The IR sensors are also helpful in diagnosing brake problems, finding dead cylinders, or checking trans and diff temps. So, you need both Core tire temp is a better indicator. an IR will not give you core temp, only surface. As JohnC said, both are useful depending what you are doing. You are usually looking for a gradient from inside of the tire to the outside and a delta of 20 degree's or so. I use both and have the memory setup in Johns first link for tires. YMMV Quote Link to comment Share on other sites More sharing options...
Mayolives Posted November 27, 2008 Share Posted November 27, 2008 I have Longacre's duel function IF with probe. The best of both worlds with many uses. Quote Link to comment Share on other sites More sharing options...
heavy85 Posted November 27, 2008 Share Posted November 27, 2008 I've been using a basic Longacre probe one this year. I find it difficult to figure out. First the probe end is not attached to the handle so it falls out ... need to glue it in. More than that though is to judge when to take the reading. The temp spikes then settles back down maybe 10 degrees after a second or two. I'm not sure why it would do this but it does. Do you try to catch the peak or take the stabilized reading? Cameron Quote Link to comment Share on other sites More sharing options...
Mayolives Posted November 27, 2008 Share Posted November 27, 2008 quote: " Do you try to catch the peak or take the stabilized reading?" I'm no expert at set up or tire temp. readings and I've only been using my probe for one season, but I'm more concerned with the temperature variation from inside, center and outside readings, than I am with the actual temperature reading. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted November 27, 2008 Author Share Posted November 27, 2008 The longacre website offers some tips on how to go about using their probe pyros http://www.longacreracing.com/articles/art.asp?artid=16 They recommend you stick the probe into the tyre in a few places prior to taking the first reading in order to pre-heat the probe and get more consistent/repeatable readings. Makes sense. Thanks guys, I guess I'll be getting the budget longacre one. Unless someone has one for sale they no longer want? Dave Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted November 28, 2008 Share Posted November 28, 2008 how Unless someone has one for sale they no longer want? Dave Sorry dude its also my multimeter Quote Link to comment Share on other sites More sharing options...
Savage42 Posted November 28, 2008 Share Posted November 28, 2008 Couple options at Sears. http://www.sears.com/shc/s/p_10153_12605_03450466000P?mv=rr http://www.sears.com/shc/s/p_10153_12605_03450499000P?mv=rr Quote Link to comment Share on other sites More sharing options...
