OGJaper Posted February 13, 2009 Share Posted February 13, 2009 Hey guys I'm new to the forum and looking for solid info for my newest 280zx project, its going to be an all N/A Build for this one, my question is this: I heard alot of rumors that you can "make" a stroker kit for the L28 by using a mix of parts such as a Diesel Nissan Maxima V07 LD28 Crankshaft. I have no idea if this is true. I searched for the MSA 3.1 Stroker kit but, its no longer for sale from what I am told. So any ideas if theirs even a "home made" method to building a 3.1L stroker? Any info/suggestions would be great (Also my friend has a Rb25 Swapped 240sx and is hounding me that I should put an Rb series into my 280zx... I have seen it in Japan but never in the states... any info on this build would be cool too, thanks) Quote Link to comment Share on other sites More sharing options...
nismopick Posted February 13, 2009 Share Posted February 13, 2009 Welcome! Search for "STROKER". This is a good write-up: http://www2.zhome.com:81/rnt/L28conversion/3031FAQ.html Yes.... you used the LD28 crank. Quote Link to comment Share on other sites More sharing options...
sorealsosurreal Posted February 13, 2009 Share Posted February 13, 2009 rb swap into an s130 wouldnt be smog legal. the 3.1L strokers are very expensive to build even when doing your own machine work. search and youll find you need an ld28 crank l24 rods and Ka24 pistons for the bottom end. Quote Link to comment Share on other sites More sharing options...
ArnZ Posted February 13, 2009 Share Posted February 13, 2009 If you have a thick wallet http://www.kameariusa.com/L6_L3_1literkit.php Quote Link to comment Share on other sites More sharing options...
OGJaper Posted February 13, 2009 Author Share Posted February 13, 2009 Thanks for the info guys going to research as much as possible, and yikes ArnZ, $4400? Quite a price tag, wondering if its even worth the money to stroke the L28, what are your guys opinions? Its not so much I have a quest to have alot of hp, more or less just want enough power to have fun. Has anyone actually done the "home made" method of mixed parts? I found a LD28 crank, pretty sure I can just get the pistons for free considering my friend has 4 spare ka24de's in his garage heh. As far as the L24 rods, not to sound noob-ish, but what model engine/car is that from? (yes this is my 1st Nissan build, and I aim to do it right) Thanks in advance for any info gang, peace. Quote Link to comment Share on other sites More sharing options...
nismopick Posted February 14, 2009 Share Posted February 14, 2009 Click this link... it explains clearly the answers to your questions: This is a good write-up: http://www2.zhome.com:81/rnt/L28conversion/3031FAQ.html L24 = 2.4L motor from a 240Z. And remember... $4400 is just for the kit. Then you get to pay for the machine work and all the extra stuff needed. To build a proper stroker, expect to spend close to $10k. Short cuts and cheap parts = shorter life span for the motor. Do it right... or you will regret it later. Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted February 14, 2009 Share Posted February 14, 2009 Click this link... it explains clearly the answers to your questions: L24 = 2.4L motor from a 240Z. And remember... $4400 is just for the kit. Then you get to pay for the machine work and all the extra stuff needed. To build a proper stroker, expect to spend close to $10k. Short cuts and cheap parts = shorter life span for the motor. Do it right... or you will regret it later. Might as well get this then: http://www.kameariusa.com/L6_l3_2_85mm_crankshaft.php Quote Link to comment Share on other sites More sharing options...
Forrest Posted February 14, 2009 Share Posted February 14, 2009 As long as we're going to do your googling for you, this should have been the first link posted: http://www.geocities.com/row4navy/engine.html (props to Bob) Quote Link to comment Share on other sites More sharing options...
RigilKent Posted February 15, 2009 Share Posted February 15, 2009 for that price i wouldnt do it. you can get enough HP to have fun without stroking. just my .02 Quote Link to comment Share on other sites More sharing options...
Datsun#1 Posted April 14, 2015 Share Posted April 14, 2015 If it were me,id get the rebello 3L kit...strong,fully balanced...all forged...ARP bolt kit,racing bearings, H beam rods, JE pistons... $2250 usa Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 15, 2015 Share Posted April 15, 2015 Norm Seimpers did it, and documented the shite out of it including the removal of material for proper compression deck height down to the grade of sandpaper and number of strokes he used to cut down the Pistons using his driveway as the milling table. That "home made" enough for you? He ran 12's in his 240, using SU Carbs. He totaled the car in a Florida Rainstorm earlier this year. It sits in his father's yard. If $4,400 is big money to you, you might want to reconsider the path you hope to take. Though Norm might sell you his engine for $6,000, complete! Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 15, 2015 Share Posted April 15, 2015 for that price i wouldnt do it. you can get enough HP to have fun without stroking. just my .02 I have enough fun stroking that I don't need horsepower! Quote Link to comment Share on other sites More sharing options...
1vicissitude Posted April 17, 2015 Share Posted April 17, 2015 (edited) Tony, do you know where Norm's build log resides? I'd love to read it if you could point me towards the link, heard it mentioned multiple times. Edited April 17, 2015 by 1vicissitude Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 18, 2015 Share Posted April 18, 2015 Archives of ZCar.com. Good luck with that! Quote Link to comment Share on other sites More sharing options...
roger280zx Posted April 19, 2015 Share Posted April 19, 2015 "normthe12secsudude" or something like that. That fellow ran 12's on 10's of dollars. Quote Link to comment Share on other sites More sharing options...
