big-phil Posted September 20, 2009 Share Posted September 20, 2009 Ive been real busy with life, but here is a video I made today on the way home from a dance my daughter did in town. I guess I'll have to get a bigger external wastegate? I'm going to try porting, and smoothing the sharp corners of it first while putting my ported head and Isky cam on. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted September 20, 2009 Share Posted September 20, 2009 Yup, Sublime IS faster!! I can feel the G forces in the video. I was getting pushed back into my desk chair! Try a little experiment. Lower the boost or raise it and see if the creep-to point changes also. What will that tell you? I have no idea, but if someone else can finish my thought... Quote Link to comment Share on other sites More sharing options...
big-phil Posted September 20, 2009 Author Share Posted September 20, 2009 Yup, Sublime IS faster!! I can feel the G forces in the video. I was getting pushed back into my desk chair! Try a little experiment. Lower the boost or raise it and see if the creep-to point changes also. What will that tell you? I have no idea, but if someone else can finish my thought... ha ha, My boost controller can be set so the boost doesn't come on as fast to the max setting. That pretty much will fix the problem BUT if I have is set at 17 it gets there slower. It looked like I maxed at about 21lbs? I can deal with that. If I turn the controller off then 9lbs is my setting, then she wants to climb to 15ish? as the rpm get higher. If porting wont do it I might try a 44mm wastegate? But I'd have to find an adapter that size. So I may live with it? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted September 20, 2009 Share Posted September 20, 2009 Phil, that's the 35r with a 1.06 hot side? I just bought a new one. It came with a .86 and a 1.06. By the grin on your mug I'm guessing you like the power the GT35r has given you now...? Quote Link to comment Share on other sites More sharing options...
Sparky Posted September 20, 2009 Share Posted September 20, 2009 sounds absolutely sick! Are you coming down to SA for the big Z show next week? Quote Link to comment Share on other sites More sharing options...
big-phil Posted September 20, 2009 Author Share Posted September 20, 2009 Phil, that's the 35r with a 1.06 hot side? I just bought a new one. It came with a .86 and a 1.06. By the grin on your mug I'm guessing you like the power the GT35r has given you now...? yes gt35r with a .63 hot side full boost at the 3k mark i think Quote Link to comment Share on other sites More sharing options...
big-phil Posted September 20, 2009 Author Share Posted September 20, 2009 sounds absolutely sick! Are you coming down to SA for the big Z show next week? not sure? Its hard to get away from work, I'd have to pay someone to run my route. Quote Link to comment Share on other sites More sharing options...
Graves Posted September 20, 2009 Share Posted September 20, 2009 Wow. Your car sounds incredible. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 20, 2009 Share Posted September 20, 2009 Bigger wastegate and piping, I don't think porting is going to get you far already having an external wastegate. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 20, 2009 Share Posted September 20, 2009 try this phil http://autospeed.com/cms/A_111348/article.html Quote Link to comment Share on other sites More sharing options...
Sparky Posted September 20, 2009 Share Posted September 20, 2009 not sure? Its hard to get away from work, I'd have to pay someone to run my route. Yeah I'm not sure I'm going to make it either, and I live in the area. Maybe i'll try to make one of those track days that Chris keeps telling my about the day before they happen. Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted September 20, 2009 Share Posted September 20, 2009 During the run where you were focused on the tach (2:33)... it was bouncing during acceleration - more than I think it should. Is that a result of the boost creep, or could it be causing the creep? Take a log with megasquirt to see what manifold pressure, RPM, and throttle position are doing. I'm suprised that a 38mm gate can't keep up with the air you are pushing. I know that Tial 38mm gates are used in 500 hp applications all over the place. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted September 20, 2009 Share Posted September 20, 2009 Do you have a mechanical boost gauge? If so, is it tapped in the same line with your wastegate? Do you have a restrictor in the line going to the gauge? It might cause some issues with the wastegate controlling things if the gauge is pulling some of the air. It will act like a bleeder. Typically creep will get you to the same boost no matter where your gauge is set. It seems odd that you can turn the boost level down and it creeps to a lower number as well. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted September 20, 2009 Share Posted September 20, 2009 Car sounds great Phil! During the run where you were focused on the tach (2:33)... it was bouncing during acceleration - more than I think it should. Is that a result of the boost creep, or could it be causing the creep? That is the result of a 32 year old, worn out tach. Quote Link to comment Share on other sites More sharing options...
thrustnut Posted September 20, 2009 Share Posted September 20, 2009 Wow, nice! I think i'm driving the Z to work today. Video's like this are an insperation to Z drivers everywhere! Quote Link to comment Share on other sites More sharing options...
S130Z Posted September 20, 2009 Share Posted September 20, 2009 Phill, I rounded the inside of my WG port the best I could with my dremel(it wasnt much since mine is welded on and I can't get at it from the other side). I will be dropping my turbo motor in hopefully within 2-3 weeks, so I will let you know if I get any creepz. Sounds amazing by the way. That is some good footage for a phone camera, what phone do you have? Quote Link to comment Share on other sites More sharing options...
sticky280zx Posted September 22, 2009 Share Posted September 22, 2009 phil throw me some money....ill run a route in my nikes =) Quote Link to comment Share on other sites More sharing options...
