Mayolives Posted January 2, 2010 Share Posted January 2, 2010 I have a new GoPro HD camera and I'm unable to view the video I have taken. I have tried all the programs I have to replay the video but to no avail. I receive this message when I try to replay. "The player might not support the file type or might not support the codec that was used to compress the file" This is all Greek for me. Any ideas??? Quote Link to comment Share on other sites More sharing options...
280zNHChris Posted January 2, 2010 Share Posted January 2, 2010 go to http://www.videolan.org and download the free viewer. Then insert your SD card into your computer and browse the card and play it VLC for now. I don't have a GoPro yet but was looking at them last night, looks cool as $hit. Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 2, 2010 Share Posted January 2, 2010 Ditto, there isn't much that the vlc viewer can't play. Quote Link to comment Share on other sites More sharing options...
Darrel Posted January 2, 2010 Share Posted January 2, 2010 Are you trying to view going through the camera to the computer? Or are you just using the memory stick? Quote Link to comment Share on other sites More sharing options...
letitsnow Posted January 2, 2010 Share Posted January 2, 2010 What type of file is it? What resolution? A lot of computers have trouble with higher quality h.264 files. My amd dual core desktop barely played 1080i .m2ts files from my sony HD camera until I got a graphics card that decoded instead of the CPU. If you have a multicore CPU and VLC plays it, but not very well you want to download k lite codec pack. After you install it, find ffdshow video decoder configuration and change the h.264/avc decoding to ffdshow-mt, this was the only way I could play full quality files until I got a better graphics card. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted January 2, 2010 Share Posted January 2, 2010 You need to plug the camera into the computer, and save it from there. It should convert it then. Inserting the memory card into the computer is not going to work. I also had this problem. Quote Link to comment Share on other sites More sharing options...
Darrel Posted January 2, 2010 Share Posted January 2, 2010 Is that just an HD problem? Both of my computers worked with just the card, a macbook and pc. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted January 2, 2010 Author Share Posted January 2, 2010 Darrel said: Are you trying to view going through the camera to the computer? Or are you just using the memory stick? Thus far I have followed Gopro's instructions and connected the camera to the computer using the supplied USB cord. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted January 3, 2010 Share Posted January 3, 2010 I have heard of people having issueswith older ones. Specifically if they recorded until the sd card is completely filled, it will corrupt the file and make it unreadable. I haven't heard of people having the same issue with the newer HD versions though. I don't know if that is the problem here but just an FYI. Quote Link to comment Share on other sites More sharing options...
260DET Posted January 3, 2010 Share Posted January 3, 2010 Mayolives said: Thus far I have followed Gopro's instructions and connected the camera to the computer using the supplied USB cord. Was there software supplied with the camera? There should be, to do editing too but I don't have a Gopro so maybe they don't. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted January 3, 2010 Author Share Posted January 3, 2010 280zNHChris said: go to http://www.videolan.org and download the free viewer. There is no supplied software and I tried the videolan.org download to open it. I sent a message to Gopro for help needed. I'm sure they will help me. Quote Link to comment Share on other sites More sharing options...
mark Posted January 3, 2010 Share Posted January 3, 2010 Google avi player. If you used the HD setting this type of player will it. I had a similar problem with my sony HD hard drive camera and this player worked for me. My kid told me this. Us old farts don't know this stuff. Hope it helps. I look forward to checking out your new toys at the track. Quote Link to comment Share on other sites More sharing options...
Darrel Posted January 3, 2010 Share Posted January 3, 2010 I have the 5mp standard definition gopro. I don't have the cables but it worked just hooking up the card to the computer. I'm sure the HD units are different. What I would like to do is set it up to run on the lighter. I have a universal converter, but have yet to research to try and make it work. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted January 7, 2010 Author Share Posted January 7, 2010 After speaking with a Gopro tech. person I am now able to view the videos but only on my relatively new laptop. My desktops are at least five and seven years old and aren't up to the task. I really don't have a technical understanding of computers, even after using them for many, many years. Apparently, the Gopro camera records in MP4/H.264 format. I was directed to the http://www.264info.com web site, where I downloaded a codec pack called K-Lite. After which I was able to playback my videos. They are very sharp, even in lower light, indoor situations. I'm anxious to be back on track again and hope the in car stuff will be this good. Quote Link to comment Share on other sites More sharing options...
Darrel Posted February 6, 2010 Share Posted February 6, 2010 Hard wired gopro 5mp wide angle standard definition. Just thought I would update in this thread my solution to bad battery supply. http://forums.hybridz.org/showthread.php?p=1123037#post1123037 Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted February 7, 2010 Share Posted February 7, 2010 Go get the K-Lite codec pack if you intend to play around with media. Also use the Media Player Classic that comes in the codec pack. http://www.codecguide.com/download_kl.htm I usually just get the FULL version. The radio controlled airplane guys have a ton of experience with the GoPro cams. You might find tidbits here: http://www.rcgroups.com/forums/showthread.php?t=1140341 Quote Link to comment Share on other sites More sharing options...
