Talkin the talk... q45 r230 r200 z30 & so on & so on
  • Please log in to reply
55 replies to this topic
#21 Guest_zfan_*
Guest_zfan_*
  • Guests
Posted 06 February 2006 - 04:23 PM
Not that simple. You need 1 rear diff., 4 axles from the r200 VLSD, custom axles and adapters plus have your mustache bar redrilled. I think that covers it all.
Mike
#22 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12366 posts
  • LocationSeattle area, WA
Posted 06 February 2006 - 04:27 PM
You need VLSD CV axles to run the VLSD. They have a different spline count than the open diffs or the CLSD's. Mark mentioned Leith280zlt1, he was putting NEW clutch LSD's into a diff with the ratio of your choice and selling the assembled unit for a very reasonable price. If you go that way you can use your existing halfshafts and it will just plug right in with 280 mustache bar. The only other thing that might need some attention is the yoke. The 300ZX R200's came with a different yoke. The 280Z or 280ZX yokes bolt right up to your existing driveshaft.
Jon Mortensen, owner/operator www.petdoorstore.com
#23 HarrisonTX
HarrisonTX
    Member
  • Members
  • PipPipPipPip
  • 285 posts
  • LocationWaco, Tx
Posted 06 February 2006 - 04:54 PM
So, a CLSD r200 will bolt right up. I will toss out the VLSD idea
What are the price ranges for r200s with a clutch LSD?
How can i spot a VLSD so i know to stay away from it?
What is the name of the part with 6 holes?
the halfshafts bolt up to that right?
I only have 4 bolt holes?
are these all q45 r200's?
Will someone explain this
Posted Image
'79 malibu
355 all forged, Super t-10 with a 3.42 first gear, 4 speed conversion done by me.
'74 260
balanced 302 rotating assembly (302 chevy)
JE pistons
H-beam Rods
Forged crank
solid roller cam
Team G intake
AFR eliminators
TKO500
Posted Image
#24 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4441 posts
  • LocationLouisiana, 70601
Posted 06 February 2006 - 06:01 PM
whats with this short and long nose r200s?
If you look at the pic you posted above, you'll see the only long nose diff, (the one all the way to the left)
RB26dettZ pics
th_April_2012006.jpg ®
#25 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12366 posts
Posted 06 February 2006 - 06:24 PM
The part with the 6 holes is a stub shaft. That stub shaft fits into the side of the diff, and then there is a stub AXLE on the wheel end which you are probably thinking of as a spindle. The stub axle is the side with the lug studs on it, then on the inside there is a small separate piece called a companion flange. The companion flange has 4 holes in it.
Then there is a halfshaft which connects the diff's stub shaft to the stub axle. Yours has 4 studs on the stub shaft end and 4 holes on the companion flange end because your diff uses the U-jointed halfshafts.
The newer diffs use CV jointed halfshafts instead. The CV's are stronger. If you have the VLSD you HAVE to convert to the special stubs and CV's that fit the VLSD. As explained before this is expensive as you need shorter custom shafts, and you end up needing 4 CV shafts to get all of the proper CV joints to make the new shafts work. PITA and expensive.
With an open diff or a CLSD you can use the original stub shaft and the U-jointed halfshaft. Just slide the stub shafts into the diff and bolt up your U-jointed halfshafts.
If you want something stronger that will handle more torque you can convert to CV shafts from a 280ZX Turbo or a 300ZX turbo with adapters made by Modern Motorsports - www.modern-motorsports.com. I think they make the necessary pieces to use the VLSD CV shafts as well.
#26 Mikelly
Mikelly
    HybridZ Supporter
  • Donating Members
  • 6285 posts
  • LocationVirginia, United States of America
Posted 07 February 2006 - 03:24 AM
Congrats to those who have contributed so far... This thread is now a sticky.
Mike :2thumbs:
Follow me on FB at Mike's Hobby Shop!
I will not be a spectator in the sport of life!
mjk 1994
#27 pimp1911
pimp1911
    Junior Member
  • Members
  • Pip
  • 24 posts
  • LocationGeorgia
Posted 13 March 2006 - 06:24 AM
I have a 72 240z with a R180 in it. I am planning on upgrading to a R200. So far I have accumulated the following.
R200 3.90 Open Diff(ie non LSD) from a 88 NA Z31
280Z Mustache Bar
280Z Half Shafts
Anything else?
#28 fastzcars
fastzcars
    Member
  • Members
  • PipPipPipPipPip
  • 824 posts
  • LocationSan Gabriel Calif
Posted 13 March 2006 - 08:21 AM
Here you go pimp1911http://www.automedic...h_tips.htm#diff
Keep the rubber side down.
#29 rztmartini
rztmartini
    Member
  • Members
  • PipPipPipPip
  • 402 posts
  • LocationSoCal
Posted 16 March 2006 - 11:38 PM
I bought a R200 from a 300ZX (early model) and plan to put it into a 72 240Z. I bought it with the half shafts and all 4 cv joints. is there some sort of adapter to bolt it to the stub axels? thanks!
#30 gearheadstik
gearheadstik
    Member
  • Members
  • PipPipPipPip
  • 344 posts
  • LocationDothan, AL
Posted 27 March 2006 - 11:10 AM
I think you have to convert to turbo shafts which are stronger anyway to get a adapter but Refer to modern-motorsports.com
and you should prob up-grade to 280z stub axles 27 spline compaired to 240 25 spline
1972 ls1 t56...under construction Gallery
1978 l28 5spd...NA-Turbo HE-351 MS&S Extra, EDIS Gallery
1988 300zx turbo
#31 QuickSilverAWD
QuickSilverAWD
    Member
  • Members
  • PipPip
  • 37 posts
  • LocationUS
Posted 02 April 2006 - 12:18 PM
Is there any readily availible markings on the outside of an 87 CLSD that would make it easier to recognize??
#32 pallnet
pallnet
    Member
  • Donating Members
  • PipPipPipPip
  • 261 posts
  • LocationLouisiana/Mississippi
Posted 18 April 2006 - 10:17 PM
I don't know if this was noted already but the long nose R200 and the short nose R200 share the same 8 bolt diffy cover bolt pattern. This means the covers should swap over. This also means you should not need to redrill your mustache bar.
Yeah that's right an L28ET in an S13.
#33 fbomb
fbomb
    Junior Member
  • Members
  • Pip
  • 20 posts
Posted 25 May 2006 - 02:14 PM
Just to verify is the gear ratio in the Q45 R200 always 3.54?
#34 jtmny1999
jtmny1999
    Member
  • Members
  • PipPipPipPip
  • 397 posts
  • LocationLancaster, CA
Posted 25 May 2006 - 02:27 PM
R200V Short nose, Q45 1989-1996 , 6 Bolt ouput shafts
Ratios 3.545
LSD Viscous
RB25DET 240z
Posted Image
#35 marcg
marcg
    Member
  • Members
  • PipPipPip
  • 61 posts
  • LocationKingston, Canada
Posted 17 June 2007 - 01:55 PM
Now that I have the 450Z running, I find that it's "one wheeling" around most of the corners. If you look at the first vid here you'll see what I mean: http://www.cardomain.com/ride/563982
Has anybody had any luck rebuilding one of these diffs? Or should I be looking for a lower mileage unit to replace mine?
Let me know as I need to get all of this new found power to hook up.
#36 underground
underground
    Member
  • Members
  • PipPipPip
  • 77 posts
Posted 26 July 2007 - 05:28 PM
I wanted to clarify some information I read on here.
All Q45's used the R200 casing, however they use 300ZX TT SIZED hubs, output shafts, and axles. They also use the same spline count, so you can use a 300ZX Hub or a Q45 hub when upgrading to the Q45 differential.
I think most people look at the size of the axles, hubs, and output shafts and assume it's a R230 diff.
The 90-96 Q45 used a 3.54 and the 97-01 used a 3.69 final gear.
The 90-96 Q45 uses the same 6-bolt axles as the ones found in the 300ZX TT, not sure about the 97+ as I haven't pulled one from a junkyard yet.
This differential is the best kept secret for the Nissan enthusiast who doesn't want to have to spend the money to modify their subframe for the R230 300ZX TT differential.
I have been having a problem with my R200 (Non-VLSD 240SX) differential breaking output shafts. The output shafts are way too tiny, and snap inside the differential.
With the Q45 differential, the output shafts are literally about 2 1/2 inch thick, or about twice the size of the output shafts found in the R200 240SX diff.
Just some food for thought.
Sig Nazi was here.
#37 BRAAP
BRAAP
    Administrator
  • Administrators
  • 4166 posts
  • LocationOregon
Posted 02 January 2008 - 09:59 AM
This thread was purged of the elementary Datsun Diff questions/posts.
If you don’t know if the 280-Z "came with" an LSD, please do NOT ask that here!
If you don’t know if the Z-31 R-200 can handle V-8 power with an automatic, Don’t ask that here!!!
All that stuff has been beat to death and most likely answered in other “sticky” threads, so please search and read more, and don’t ask elementary questions in the "stickys"!!!!!
Please keep this on topic.
Thank you,
Paul Ruschman
HybridZ staff
#38 Daeron
Daeron
    DON'T PANIC
  • Members
  • 2129 posts
  • LocationWPB, Florida USA
Posted 15 January 2008 - 09:16 PM
I am getting around to reading the nitty-gritty on the differential thing just now.. and perusing through the stickies in this sub-forum, it seems a little crowded.
I would hesitantly suggest that this thread no longer hold enough merit on its own for it to remain a Sticky.. Jmortensen's encyclopedic post regarding rear diffies in our Z-cars MORE than covered every subject covered here. *Maybe* add a brief "language primer" (r230, VLSD, q45 etc) to the first post in JM's thread.. but other than that, this thread is confusing, incomplete, meandering, and not as easy to digest and absorb as the two other stickies covering this topic; namely, JM's "Diff/CV/LSD/....." thread and the "complete differential list (please help)" thread started by cyrus.
OP of this thread: I am sorry to denigrate your thread here, but I make this suggestion for the good of the Land. Mods: If you disagree, please simply delete this posting, with my humble apologies :D
Fusible Links blow.
1-5-3-6-2-4, counter-clockwise from 9 o'clock when viewing from driver side fender
There's something about a white Nissan......
Wisdom is knowing how much you do not know.
"Indeed, if fish had fish-lore, and Wise-fish, it is probable that the business of anglers would be little hindered." -JRR Tolkien
ALL YOUR BOOST ARE BELONG TO US
#39 SATAN
SATAN
    Member
  • Members
  • PipPipPipPip
  • 191 posts
  • LocationDenver Colorado
Posted 25 February 2008 - 10:37 PM
Oh sweet Christ. I have to clear up a few things since this is a sticky and is full of a bunch of wrong information.
All Z31's (84-89 300zx) came with LONG NOSE R200's
Later 87's-89 z31 TURBO'S ONLY ALL came with some form of LSD (Mostly CLSD)
ONLY the 88SS z31 came with the R200 Vlsd
VERY FEW 88 turbo's are the SS model.
ONLY the 90-96 Q45's(some say 89) have the R200VLSD with the beefy 6 bolt input shafts (30 spline) which are the same as the TT's (30 spline), and they ARE NOT twice the size of the 240sx splines which are 29 spline.
The 90-96 Q45's carrier (inside parts) will swap over to the 84-89 z31 r200 case. All that is needed is to swap ring gears. But then you have to custom make half shafts. This is where I am at now.
97 q45's do have the R200vlsd but it IS NOT the larger one like the 90-96. ONLY THE 6 BOLTS input shafts are the beefy 30 spline.
There is always someone bigger, badder, and faster than you.
Posted Image
#40 Bowtiez
Bowtiez
    Member
  • Members
  • PipPipPipPip
  • 119 posts
  • LocationArkansas
Posted 27 February 2008 - 04:28 PM
I have told a guy with a 90 model TT R230 that the popular S14 240SX/300Z brake conversion will not work due to the 29 spline axle vs 30 spline issue and that he needs a 90-96 300Z non turbo hub/brake assembly. My motive is to buy this from him but I think from what everyone is posting, I am not lying. I have a 95 Q45 complete assembly located but my 350 SBC roller cam is over 400HP and I am concerned about strength if I run the intended M/T ETs. Although I have broken u joints on the long nosed R200, I have never had differential problems including the phantom grip lsd.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
