- Yesterday
Got out there this morning to gather some stuff to take to the powder coaters. It was also a good time to clean up the front suspension bits so I can put the front end back together. It was a dirt/oil glob on both sides, so with cleaner (g@s) and a toothbrush, a rag, a screwdriver, and a wire wheel attachment in my drill I got everything cleaned up enough to put together in my effort to get this hulk to the body shop for some block sanding and a coat of blue and clear, color sanded and buffed.
I bought a gas cap for a 2002 bmw for my 280z (MSA used to sell them, it is showing out of stock: https://www.thezstore.com/product/4445/locking-gas-cap-70-76-240z-260z-280z ) The cap fits tight. Not sure if this is something that will work for your racing events.
I bought, and installed my new Mfactory Helical lsd ... I also installed techno toys 4340 billet stub axils that i did have to make 4mm spacers where the bearing is pressed on against the flat plate side with wheel studs other wise the plate would tighten up against the bearing housing locked to where it would not spin freely , and I also used OEM 300zxt axils that were in fantastic shape like new internals i installed new grease ,and boots flipped the bearing cage on passanger side axil ,and painted them .... the adapters were from silvermine motorsports i came up with a method to center the companion flanges to adapters by using jb weld and using a digital measuring caliper to center before jb weld hardened holding the companion flange in a vice and putting the 300zxt adapter on top while jb weld cured to hold parts in position for welding ... i used a 2 1/2 thick machined flat large metal plate with 5 clamps to hold the companion flang ,and 300zxt adapter round plate tight with force on the 2 1/2 inch metal plate for welding process to keep every thing from warping, and it worked perfectly . I left it clamped until everything cooled down after welding ... The adapter ,and companion flange after this clamped welding run /spin true flat with no up and down or side play in movement while spinning zero vibration while running on the car .. every thing is worked out pretty good so far every time my TCI street fighter 700r4 hits 2nd gear both rear tires bark posi , and around the corners it feels great tracks fantastic ... some pictures
Hi, this is my first post to this forum, thanks for having me! I bought an rb20 head and am wondering if it is acceptable to use it on an rb25 block. My concern is that the rb20 head has a combustion chamber sized for a 78mm bore and I would like to use it on an 86mm bore block, do I need to port the chamber to match or is it okay to have the chamber overhang the bore? From the factory it had a flat top and bottom overhang so I assume it would work around the whole circumference? Thank you for any advice
76_280Z started following Relentless - 1977 280z LS (5.3l L59) swap
- Last week
Datsun_Panda_Z joined the community
More from Sema Show- Fully Modified Toyota Truck with Tilt Front End nject Fuel Injected V8 motor to power it. Interior of this Race truck Rear Suspension for this OFF ROAD RACE TRUCK Eating Lunch at one of the numerous Food Trucks outside of the Main Convention Buildings A Razor Crazy Fully Modified with a Disc Brake with Taxi Cab Performance Casters and 48Vt Electric Motor. I still don't know what the Front Cooler is for. My guess would be the Cooler is for cooling the Electric Motor. Nismo Race Car on a Lift at their booth. Ford Gt with a Coyote Motor in it. HKS Booth with their Turbos, intercoolers and many other accessories. A Cute Mini Bike with a VW Fender Covering it. 240z with many Carbon Fiber Parts all over it. As you can see, the attendance is definitely down. this pic was taken in the Front Entrance of the Main HALL. Normally, there would be Wall to Wall People. Outside View Prismatic Powders-Wall of their wide selection of Powder coatings. Make you own Mid Engine 67-68 Ford Mustang You cut out the Mid Section of your Mustang forn the Firewall to to Rear Tail Light Panel then insert his new frame into the space. The Finished Product should look like this pic. I stiill working posting pics that for some reason are not posting. -
Sema and Apex Show 2025 -Las Vegas Nov.4 to Nov7 I have been to the Sema and Apex Show in Las Vegas for over 35 years missing only two shows. These Shows have been crowded and always better than the previous year. That is until now, this year the show were not better than previous ones. Not as many vendors and corresponding not as many attendees. Prices at this noticable higher than past. Everyone expects convention prices to higher than outside of convention area. But, this year, prices for food, hotel rooms, etc were extremely higher. For example , one regular16 oz of Water was $9 a bottle. Mac Donald's Cheese Burger Meal with Fries and Drive ran about $35!! Prices for everything was higher within 2 Blocks of the Strip. The lack of human card dealers who were replaced with automated machines was everywhere. Also, missing was the people. I would there was about 20% less people at the convention and maybe 25% less people walking on the Strip. This is happening during one of the biggest conventions of the year!! Back to the Show- Riding the Las Vegas Mono Rail that runs parallel from MGM Grand to the Las Vegas Convention Center. Regular price was $6 a ride but it was lowered to $5.50 for the convention goers. Cars, Trucks, Food Truck, Vendor Tests, etc outside the Convention Hall. Blown Cars preparing for the Burnout Box Area Off Road Motorcycle Jump Area Videos of their Jumps Sorry, my videos of the motorcycle jumping was able to post. I will try to correct this if i can. A crazy looking Roaster Beautiful Chopped Chevy Truck Convertible a Usual Large Amount of Load Speakers in a truck bed. Pic of the Crowd of People Outside the Central Hall Ford GT Racer Interior pic of a Green 240Z Racer Fuel Injected Lowered Chevy El Camino Nismo Accessories Board Nismo Wheel Display GReddy Racing Booth FUGU Z 10year Anniversary Sung Kang Famous 240Z Right Rear Wheel Rear View Engine Compartment RB25 with Turbo Left Front Wheel Left Rear View Interior Pic Rear Hatch Area Pic Sung Kangs New 240Z-24 Valve Overhead Twin Cam Motor Interior Pic Left Rear Wheel Pic Carbon Fiber Rear End Parts Interior of a Bullet Proof Armored Vehicle 10,000 lbs worth More pics and text to come- -
IMPORTANT MESSAGE-CONCERNING NEW COMPLETE 240Z BODY ASSEMBLIES FOR SALE I just posted information concerning new complete early model 240z bodies assemblies that may be available in the near future. It is posted on the BODY KITS AND PAINT SECTION of Hyprid Z Forums on Monday. There are a lot of pics and text discussing their construction and quality. Information about the manufacturer is also listed. There was a lot of interest in their line of reproduction vehicles( Toyota Land Cruisers,Toyota A86, Ford Bronco bodies). Also, I also post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN. Weigh savings are about 20 to 30 percent and very corrosion resistant. The workmanship was excellent and looked beautiful. This is a limited production run so if you are interested, I would put your order in. Star Road in Japan is handling the sales of this product. I will also start posting pics and text of other cars and products that I found at the SEMA SHOW 2025. This will posted in my usual Hybridz Forum site at V8 ZForums-Gen III & IV Chevy V8z site soon. -
260zmaine joined the community
Well, it took all day, but I got the door jambs and inner doors all done and ready for the body shop. The paint on this car is incredible. I have never seen anything like it, it only comes off with a flapper wheel on an angle grinder....I tried 40 grit on my orbital sander, didn't touch it. So, I have continued to use a flapper wheel, and will then go over each panel with finer and finer sandpaper to get it all smooth before handing it over to bodywork and paint. I am finding areas that were slicked with filler and sanded out, with THICK layers of paint and all. I remvoed the hinges and coated both sides with rustoleum and re-assembled. Man, It really worked me today! Pics.
It seems there isn't much activity on this forum vs. about 10 years ago. I guess not as many of these cars are still being modified now. Anyway, an update on some progress. The pool hose I am using here is just for mock up purposes. It has the right ID to fit tightly on the fittings. I just heat up the the hose (a plastic/vinyl material of some sort) and then slide on the fitting. I believe this is helping to establish the actual hose lengths I need as well as "clocking" or indexing the fittings to the hose. Additionally, though I did not plan it this way originally, I came up with a great design for securing the battery to the tray... and made this upper battery mount bracket in such a way as to tie in to the bracket that I made to mount the oil tank in the car. The upper bracket I made today not only clamps the battery in place, but also ties into the oil tank bracket and the engine compartment panel, triangulating everything. This design makes the mounting for the tank very rigid. I still have a bit to figure out with regard to mounting the forward most part of the bracket that I made today to go on top of the battery. I think I may cut a plate like this red outline and rivet it to the upper battery bracket. This panel will sit atop of the angle piece that presently holds the breather tank in position. Then the two bolts (within the red outline representing the new panel) will join all three layers. The result here is that the triangulation appears to substantially strengthen the tank bracket. I won't have issues with the weight of the oil in the tank causing the brackets to bend/fatigue.
Got a lot of the rear track attack kit put together today. It went together pretty well, their videos are very helpful. Only minor issue was these lock washers being too big, just ground them down a bit. -
Can't separate oil pan / bottom block on 1981 280zx
toolman replied to adsdsasdasdasda's topic in S130 Series - 280ZX
Have you tried industrial Blower Heat Gun (capable of heating the area to 200degrees)? This method usually works but be carefully not melt anything near by. This Process softens the glue to allow parts to separate. Try on a small area first. -
NewZed replied to adsdsasdasdasda's topic in S130 Series - 280ZX
Not clear what this means. There is no "upper pan". This is a 280Z but it's the same engine. You posted Sunday so probably already got it done. Good luck. https://www.carpartsmanual.com/datsun/Z-1969-1978/engine-280z/cylinder-block -
Zetsaz replied to adsdsasdasdasda's topic in S130 Series - 280ZX
It should only be the bolts that hold it to the block. No extra secret hidden bolts. Have you tried tapping it with a rubber mallet? if someone used gasket adhesive on both sides it would be pretty well stuck. I had to use a rubber mallet to knock mine loose. If it's really stuck with something like permatex ultra black instead of a stock style gasket have you tried running fishing line through it? Could cut through easier than a blade without damaging the metal. -
My rollpan is almost ready to ship as well. I got it from Chop Suey Hot Rod Shop, he is filling in the exhaust cut out for me. It bolts on to the rear.
dropped off my new hatch from resurrected classics, my grille, and my 240 taillight outer panels at R&S Powdercoating for a coat of gloss black powdercoat. I had the hood sandblasted and found damage, so I ordered a new hood for Resurrect Classics, and will make my cut out and then have it powder coated gloss black as well. The car will be light metallic blue, with black hood, hatch, flares and rear spoiler/Air Dam. here is the inspiration for my change in direction: (Just picture the light metallic blue instead of red)
Yep that is there forever home. I can cover them if needed, but this is an around town hotrod only. no wipers, my version of a cooler AC Cobra.
stock brakes Sir. of the two "blocks" I assume you are talking about the one with the electrical probe on there. Rather than try to figure it out, I knew I was going to run stock brakes so just copied how Nissan built it. (shrug)
You don't really need the brake line differential pressure warning switch. It does function as a decent junction block. You are also likely to want an adjustable proportioning valve instead of the stock unit unless you plan to run stock brakes.
I believe you are referring to the Proportioning Valve and the Brake Line Pressure Differential Warning Switch. Is the switch still functional (I couldn't see any wiring from those photos)? Did you decide to relocate them to the fender well for a cleaner look under-hood? If that's going to be their permanent position, I would fabricate some kind of metal shielding to protect them from road debris damage....the stock plastic inner fender liners are probably not sufficient. Good tip on the "Finishing Lines"...will check it out for sure! 👍
jpndave started following A COMPLETE EARLY MODEL 240Z BODY may be available soon
IMPORTANT MESSAGE-CONCERNING NEW COMPLETE 240Z BODY ASSEMBLIES FOR SALE I just posted information concerning new complete early model 240z bodies assemblies that may be available in the near future. It is posted on the BODY KITS AND PAINT SECTION of Hyprid Z Forums on Monday. There are a lot of pics and text discussing their construction and quality. Information about the manufacturer is also listed. There was a lot of interest in their line of reproduction vehicles( Toyota Land Cruisers,Toyota A86, Ford Bronco bodies). Also, I also will post text and pics of ALL ALUMINUM BODY PANELS FOR 240Z MANUFACTURED IN JAPAN. Weigh savings are about 20 to 30 percent and very corrosion resistant. The workmanship was excellent and looked beautiful. This is a limited production run so if you are interested, I would put your order in. Star Road in Japan is handling the sales of this product. I will also start posting pics and text of other cars and products that I found at the SEMA SHOW 2025. This will posted in my usual Hybridz Forum site at V8 ZForums-Gen III & IV Chevy V8z site soon. -
I had a couple hours this morning, so I went ahead and worked some more on the layout for my brake master cylinder backing plate, and then installed my brake "parts", that divert fluid to all 4 wheels (I don't know what to call them). I used Finishing Lines for the hoses. These hoses are the new PFTE hoses that do not swell, etc. Guys are completely running brake lines in whole cars with these and they work great! I will be doing a combo of hard lines and this. Everything past the firewall back is the stock stuff. www.finishing-lines.com. They advertise a lot of Honda stuff, but they DO have our 10mm fittings etc. Great people to work with. I then went ahead and pulled the back window as part of gutting the rusty hatch out and then installing my new hatch I got form Resurrected Classics. My hood is at the sandblasters right now, should pick it up tomorrow, and then I can cut the hole and repair the spear with all metal filler a tad, as I can see some mud in it. Seriously thinking about having the hood and the deck lid powder coated gloss black to contrast the light blue metallic. Black spoiler and air dam also (they are already black, I can put a coat or two of 2K clear on them), I have glossy black flares........I will attach a pic that a guy did this with..... but the car is red.....it is giving me these ideas. Pics follow, Cheers!
just barely screwed them on and took a pic.
Good list, I went with the track Attack kit And a 370Z diff (R200). I went with the Bull Dog Frame rails as they can go over the existing frame rails. They are still in the box though, I’ll install those after I install the rear suspension. -
Those struts look really long. How much can they be shortened and still maintain sufficient travel?
When I installed my small block Ford in my car there wasn't a kit available to mount the engine and transmission. So, like you, I had to figure it out on my own. A particular challenge with these cars is that they are small and you will end up with a very short drive shaft. Because of that we have to pay particularly close attention to driveshaft angles. We need the axis of the engine to be parallel to the pinion axis, and to keep the u-joint angles as low as possible. If you don't do these things you will have drive line vibration that will make the car very unpleasant to drive at high speed.
Who's Online 1 Member, 0 Anonymous, 678 Guests (See full list)
