    33366
    5167
    globeclk
    globeclk
  1. Yesterday
  2. Selling a 79 280ZX Manual. Asking 6250 Located in Deer Park Wa Here's a list of all the problems I know of: Lifter tick that needs adjusting. Missing right mirror's glass. Left mirror glass fairly scratched. Dash cover is cracked. Carpet def needs replaced. No speakers in front, but I did all the wiring for back speakers and to the head unit and put new extending power antenna in, radio sounds really good now. dome light needs bulb. Left blinker needs new orange cover. Rust in spare tire spot in trunk, used to leak from roof but I fixed the leak. Just needs sanded and re painted. The battery tray is super rusty and needs replaced. Dash backlight flickers every now and then and probably needs replaced soon. Tires had tire rot from prev owner so steering wheel vibrates at highway speed. Not bad but definitely need replaced and balanced. No A/C or heat. As far as things I've done: New rear speakers and head radio unit, new power ant, new door pulls, replaced sun visors and clips, new thermostat, new water pump, new starter, oil changes every 3k since I got it, coolant flush, brake fluid, made a spare key, upgraded shifter bushing to the brass one, completely re-sanded and polished the aluminum wheels (they look amazing) and probably a handful of other things that I can't think of. The engine and trans are both super good and running strong. She is a blast to drive and gets a lot of attention from people. Here's the link to my Facebook listing: (10) Marketplace - 1979 Nissan datsun 280zx | Facebook
  3. Last week
  4. fresh coat of flat black powdercoat on my rocker trim for the ATLAS Z:
  5. Well, this car is akin to an AC Cobra. Sunny day only....around town hot rod. I want it as open air as possible. Mostly gutted out except for some interior bits to make it look nice. Also the exhaust exits right behind the front wheel!
  6. Thanks for the reply. The backspacing on those wheels isn't compatible with my bodywork. I would need a zero offset (or close to it) to work. I'd never heard of Atara Racing wheels before. They look interesting. I'd be interested to know the specifications they adhere to for there manufacturing.
  7. kyle319
    Wheels
    Hey, I'm gonna be putting my 280z on beadlocks here fairly soon and will be looking to sell my set of wheels on it currently. They are the graphite atara pisangs. 15x10.5 -35 offset, stock 4x114.3 patern. They have some r888's on them that are older but are still soft and hook well. Shoot me a pm if you're interested!
  8. Ferraris have louvers in the rear because that's the engine cover rather than the rear window. I guess it will be ok as long as it never rains. Hopefully it doesn't suck in too much exhaust.
  9. Although out of stock currently, 240zrubberparts.com offers the fuel sender boots.
  10. 07-20-2026 ATLAS Z UPDATE: my rocker trim I got from Ace King arrived and another ATLAS Z badge I ordered showed up as well. Z Car Depot sent me a set of hood spacers as well. PICS:
  11. Part 19-More Detailed Work on the Gull Wing Door More Detailed work continues on the Gull Wing Door- Drain Channels and Gapping the Door in preparation for weather stripping.
  12. Nice Nate, keep it up! I know how family stuff goes, we have three now so totally feel you on that. I've finally primed my side mirror today to repaint it in the original grey. Getting to painting a side mirror has taken me upwards of many months so you're doing way better than me!
  13. 07-19-2026 ATLAS Z UPDATE: I started by color sanding and buffing the tops of the fenders and the sail panels with 2000 grit, 3000 grit and 5000 grit and then used Meguires Premium Polish with my foam pad on the buffer at medium speed. Then I re-installed the side view mirrors, and re-installed the emblems and plug for the antenna hole. Then I finished the door panels by putting the latch surround trim under the door release latches on both sides. Then I took some rope and measured out the length for the serpentine belt and the remaining brake lines, which will also be PTFE braided line form "Finishing Lines". All of this took longer than it sounds. PICS:
  14. You really need the hard ring to make it work. The rubber cover holds it in place, but the plastic or metal ring is the pivot, so the geometry is right, and the cable can pull the brakes and hold the car.
  15. 07-18-2026 ATLAS Z UPDATE: Today was Doors Day. I put this off for a long time, because it is just no fun. I deleted the windows for the car to lighten it up and keep it in the mindset of being basically a 4 wheeled motorcycle. I gutted the doors out except for the door handle mechanisms, leaving the locks in....and then vacuuming the bottoms of the doors out and then taping the holes off, and then I installed my repro door "cards" I got from Hung Vu. the Arm rests I got from Ebay and the holes left for window crank and door lock I filled with some push in plastic plugs I got off of eBay as well. I then started on the layout for the rear window. I am replacing the glass with Clear Polycarbonate from a company in England called Plastics4Performance (.com). I am getting the rear window in clear, with the special hardened coating, and making it a custom order, having slots cut into it like they do for the Ferrari 488 cars (see pic). The weight will be easily half of what the heavy glass weights, and I will lay down a layer of rubber int he window well, drop the glass in, and then with holes already drilled, bolt the window down into the hatch itself. It should look great! I also installed the door weatherstripping and the threshold plates. Seems to have made a big difference looking at it after I was done today. PICS:
  16. Earlier
  17. I'm not dead. 2025 was a pretty big bust though. Just way too much going on being a family man. But I've recently made some progress. Engine is back out for hopefully the final time. Finished welding up the chassis side of the engine mounts and engine bay is painted. Still need to do some finish welding in the transmission tunnel. Also fabricated a mounting bracket for the brake master (booster delete). Still to be done off the top of my head: Cut down and weld the brake master pushrod Fab new brake lines Mount clutch master Fab clutch line Install flywheel Install adapter plate for final time with loctite and such Install clutch Drain and replace fluid in transmission Clean up transmission shifter hole (rusty from standing water in it (before me)) Install transmission Install new thermostat housing Install rear coolant adapter (with gasket, was just set on for test fitting) Install intake coolant adapter Fab and install engine to engine coolant lines Finish last bits of engine harness wiring Weigh final engine/transmission combo Install engine/trans for (hopefully) last time Fabricate radiator mount and ducting Mount and plumb radiator Plumb fuel line That's starting to get down into the last bits before first fire up. I'll also need to fabricate exhaust at some point, but it'll survive running an open header for just getting it back on the ground. With any luck I hope to have it close to first start by end of August. Will depend on how many side quests I have to also complete.
  18. @senna21 I would advise you (if you still have a chance now) to remove your brand new sending unit and apply some JB Water Weld or Tank Weld (or whichever preferred fuel resistant epoxy) to the inside/outside of those terminal posts. My brand new sending unit from ZCar Depot leaked. I filled up my brand new tank (also from the s30.world) and went to a car show. I had a big embarrassing fuel leak. They are sending me a replacement unit. I won't be taking any chances again and will JB weld stuff. Both posts leaked.
  19. I agree. Are you sure the Prothane bushings don't use that outer sleeve? Most poly kits I've seen are like Mitchel said. You might want to see if the bushing slips in as it sits.
  20. Replacement Door Mirrors for a 1972 240z Nissan The old MSA door mirrors fell apart and I wanted to find a better replacement. After doing some research I found that GM part #987460 refers to the classic chrome outside rearview door mirror used on 1955, 1956, and 1957 Chevrolet passenger cars would be a good fit. I found a kit that provides both left and right mirrors at United Pacific: Item No.110745 Exterior Mirror Bundle for 1955-1957 Chevy Passenger Car (Pair) which includes: · Polished stainless steel mirror head & chrome plated arm with identical design as original. · Convex mirror with wide angle optics for R/H side. https://classic.upauto.com/exterior-mirror-bundle-for-1955-1957-chevy-passenger-car-pair-110745 I purchased the mirror kit at Amazon for $57.69 https://www.amazon.com/United-Pacific-110745-Exterior-Passenger/dp/B07CSM82R6/ref=sr_1_5?crid=3D4VKZQDPPL45&dib=eyJ2IjoiMSJ9.Ji_ewCdOZDHJk5NTl-hJJNFlKNsQBt5lpAOLKHcRoK31x-GRce_gxezK_VKJFo0J9IkZHkDcZBC1uO-yqa9wAikFa3d3ppFs1Z_e9oMH7GHS0hSYXVCL3mPH2KdHlNipyinC19rlSI2bJ2OSt4dOu31VkbQgttxV3F9sjOnvlwdEzUBrH0x35XHZypqXaZKhHaGVoA8HQfe6yph6tpYjD9i1U7980UgA3v1My4M_ZeA.60nOt1lFZGTfNCnWtHJyTgcmFLSL1-4Gz3NCXbznMr0&dib_tag=se&keywords=car+side+mirrors+chrome+metal&qid=1783662323&sprefix=car+side+mirrors+chrome+metal%2Caps%2C189&sr=8-5&ufe=app_do%3Aamzn1.fos.9fe8cbfa-bf43-43d1-a707-3f4e65a4b666 See pictures.
  21. Note that this applies to my 1972 V8 240z which uses a Motor Sports Auto (MSA) / Jags That Run (JTR) style hood release bracket. The stock hood release cable tends to fail with age. If the cable breaks you will be very sad. So I decided to replace my failing hood release cable with a Lokar Hood Release Cable kit. I installed the hood release handle where the driver’s side vent control was mounted. The vent control mounting bracket is rigid and lines up the hood release cable with the stock hole in the firewall. The vent control was moved to the left of the Lokar hood release lever and bolted to the underside of the dash. Installation required making two brackets from 2” x 2” x 1/8” aluminum angle one for each end of the cable. The release arm on the stock hood latch release mechanism required modification because the Lokar cable stop would not fit into the stock cable connection. I removed the stock cable connector on the release arm and replaced it with a spare Lokar throttle cable end and ball pivot. This allows the attachment point on the lever arm to swivel as the release arm moves to release the hood latch. Summit p/n: Lokar Hood Release Cable Kits HR-1100U $129.95 https://www.summitracing.com/parts/lok-hr1100u Summit p/n: Lokar Cable Fittings WCA-1034 $33.95 https://www.summitracing.com/parts/lok-wca-1034
  22. 07-15-2026 ATLAS Z UPDATE: Today I finished sanding the first coat of gloss clear and then prepped and applied a second coat of poppy's patina. Now 48-72 hours of cure time before color sand and buff. I also finished the work on converting the hatch lock pushbutton to a hood pin setup. PICS:
  23. I finally had some time this weekend to work on the Z again and finish off some of the little things that where nagging me. I finished my DIY door card project and got them installed in the car. I must say that they turned out pretty good. The only finishing piece would be to add the wood trim back in but I would have to make one myself. A few weeks ago I managed to pic up a set of Euro taillights from an original Dutch 260z that where in excellent condition. So with the remaining time I had that day I quickly switched them out. Yesterday there was a small all Nissan/Datsun meet I attended which gave me the opportunity to compare my Z with others and do up some inspiration for future modifications. Afterwards I finally had the time to take some proper pictures of the car (with the car not half apart) and cruise along the dikes. WhatsApp Video 2026-07-13 at 09.15.40.mp4
  24. Your engine bay looks very clean, nicely done! You really are flying true this project, keep up the good work!
  25. Those sleeves are really had to take out, that’s why they sell inserts that reuse the old outer sleeve. Because of this I went with polyurethane bushings in my 280z and I must say they are pretty comfortable. People always complain that they cause massive vibrations and are undrivable on the street but I really don’t know what they are talking about, they feel fine to me.
  26. I can’t wait how she looks out in the sun!
  • Who's Online   0 Members, 0 Anonymous, 1809 Guests (See full list)
