- Today
flatout replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
As far as i know from being in the 240sx world is the s15 6 speed is geared better for performance driving but is weaker than the s14 5 speed but i think the nismo one is advertised as fixing some of the weak points. -
Last weekend I went to my first classic car event with the 280z which was a lot of fun. To my surprise I wasn’t the only Datsun at the event. A bit later a one owner Datsun 1200 coupe (talk about rare) and an early 300zx also showed up. On my way back home in the Z cruising along at approximately 75mph she decided I didn’t spend quit enough money on it yet and turned my 5 speed into a 4 speed transmission. What probably happened was the main shaft nut backed off. Guess this is another nice surprise left behind from the previous owners “restauration”. Surprisingly the car still shifts into reverse and doesn’t pop out, 5th gear just acts as an extra neutral now. For now I will need to find a replacement FS5W71B gearbox or modify another 71 series gearbox to fit the Z. I know a guy who bought a 280ZX 5 speed as a spare 25 years back and is willing to sell it to me for €800. It’s ether that or trying to find the correct parts for a pre 80’s 71B and rebuilding mine myself. There is a local shop that builds rally cars out of S30 Z’s who can sell me a rebuild ZX 71B or modified S14 71C close ratio transmission but those cost €4k-€6k. For that price its more interesting to swap in a modified brand new NISMO S15 6 speed from Japan. Escort makes them to fit the L series engines complete with mechanical speedo connection and CNC transmission crossmember. Anyway I guess that’s just the life with a classic car….. -
@74_5.0L_Z thanks for the pick of your radiator frame, I had thought you maybe had an intercooler stacked up from previous pic. I ended up going with a dual pass radiator so I had have both inlet and outlet on the same side. I’m thinking of going with 20AN fittings, so I’ll 90 off the radiator and cut to the driver side. - Yesterday
It looks like the radiator in your picture has the lower outlet in the wrong side. I use a Griffin 24x19 P/N 56202-XS with the driver's side lower outlet. I had them make it with the inlet angled straight out of the core rather than angled. The radiator snugly fits into an aluminum frame that is bolted to the frame rails, and is retained by the hood when it is closed. -
Radiator came in, made a mistake on sizing it, but I think it still works just fine sitting on the frame rails, thoughts? Or should it get something skinnier that fits between the frame rails. I like the built in tray on this bumper, I’ll add some ducting that just continues this on to that bottom rail and continue it past to the end of the radiator. -
Yeah, I’ve already got the next size up and I’ve been happy with it. - Last week
06-28-2026 ATLAS Z UPDATE. The amount of work done today was hampered by work I needed to start on my 240Z, but I then made time to knock out a few things on the ATLAS Z today. The way my MAF meter sits in the piping is functional, but looks bad. I decided to take some left over 4" tubing, and cut it in half and form it to fit over that area, which will make it look like one solid piece, I will get it polished along with the last piece which is finished (I jsut need to go pick up and then drop off at the polishers). I then did the hood pin for my "window frame" hood. I am using one hood pin, and I bought it off of amazon, with the striker plate in black versus chrome. I then took the number decals I ordered for the car and lightly taped them on there to see what I think. They are supposed to be adhesive, but they have a weird clear coating over them I have to figure out. PICS:
i've had good luck with that exact husky tool box. I don't think for the money you can do better. -
Zpowersteering joined the community
No sir. The ZPS prototype was fitted in 2011. That EZ setup is similar, but it doesn't use torque sensors or an ECU. It's also substantially more expensive. There IS a company that "copied" our design, but they use an inferior motor that isn't for automotive use. Found it odd that they ordered two of our units back in 2014. We've also developed an electrohydraulic system for those wanting to retain a hydraulically-powered rack, but don't want a traditional PS pump hanging off their engine. Ours uses an electric PS pump with remote reservoir (not as popular as the original ZPS kit, but a number of V8 swap S30 guys have bought one. Hope that's all helpful!
Got a new tool chest, been accumulating a lot of tools with this build and ran out of room to store everything. Space is limited in my garage so this will get a pile off the ground. Took a break from the heat and built two panels in the nice A/C. First panel is for anything not tied to emergency cut off like locks/lights/signals, with cut off solenoid on bottom to feed the second panel. Second panel has 3 250amp relays to power a relay box, fuse box and distribution block each running off of ignition 1, 2 or accessory position of push button start. Not sure if that’s the right way to do it, but that’s what I’m going with for now. I’ll get back to the garage and work on some other projects next. -
im not happy voltage drops on this thing. best would be new fuse box re-route wiper and lights. i might try easy re-pin cause common, dome and lights uses same source. if that fuse box connector is some how the issue. on dome light i have not much draw, swap dome and light pins on end of connector
Zed Head. I hope that you can help me. I'm mayolives here and at hybridz and at classiczcar. I've been a member of both for probably 20 yaers. I'm using a new computer and can't get into my classiczcars account. The site says to put in my email address (mayolives@aol.com) and a recovery email will be sent to me. I've tried that a half dozed times with no reply. I've tried to set up a temp account to contact the admin. but it won't allow me using my email. Could you contact the classiczcars admin for me and pass on the information. I sure would like to get back in over there. Thank you for any help you can provide. Tom Barnett
06-24-20226 ATLAS Z UPDATE. Yesterday I picked up my rear spoiler, cowl and front bumper from getting wrapped in dry carbon fiber vinyl. Today I mounted them. PICS:
- Earlier
jhm replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
Either would work very well for you. I haven't had any first-hand experience with Intrax; but am extremely impressed by their technical data and the reviews I've read on them. -
Great to hear that you found the problem! I had a similar problem when upgrading my dashboard backlighting to LED. I knew that they alle worked but after reinstalling the dashboard into the car and testing everything out only the tachometer backlighting didn’t work. Turns out that the connections to the backlight had reversed polarity. After switching the two pins around in the connector everything worked perfectly. This wouldn’t be a problem for incandescent bulbs but seeing as LED’s are diodes the switched polarity suddenly did become a problem.
I found the wire. The black with yellow stripe comes in on the turn signal side of the switch (see picture, blue arrow pointing to the wire). I had the ground connected there. That ground, which is on the turn signal side, connects to the ground on the combination side of the switch (see picture, red arrow pointing to the wires). After that all was good. I wondered why the circuit seemed to work fine with my crossed wiring of the black to black/yellow. As it turns out the switch was finding ground through the wiper motor. As I was tracing the wires for the second time, I disconnected the wires at the wiper motor and found my headlight would go out... Eureka! Problem is now solved. Thanks again !
The settings recommended for my setup (front and rear control arms, front crossmember and quick steering knuckles) by Apex Engineered where: Front: Camber: -1.5° to -2.5° However if it's a street car, it can be reduced to negative one to even zero. Caster: +4° to +6° Toe: 1/16" to 1/8" total toe-in Rear: Camber: -1° to -2° Same as above in the front in terms of camber Toe: 1/16" to 1/8" total toe-in I agree for the most part with these specs but unfortunately this was as far as they could go at the moment. At least the car is way easier to steer now and she drives stable and straight as an arrow. The steering wheel does self-center but it could be a bit more. The rear needs a zero toe or a bit of toe in but for that I need to increase the track width of the control arm a bit and then come back for a new alignment. My shocks are a little done for (especially the right rear is nonexistent) but for just cruising around this is good enough for now. I do plan to install a set of coilovers from Intrax (local to me) or KW. I was considering BC Racing but they were discouraged by the shop if I wanted to have them last more than just 2-3 years especially since I can’t park the car in my garage. Don’t worry, she still has a roof over her head as she is parked under my carport with a cover over her. The more time goes on the more things I want to do, it truly is a never ending project. The next thing I would like to do is add a BRE style spoiler and an air dam as they are a bit cheaper then the rest of the suspension upgrades. After that I want to replace the stock shocks with coilovers and some stiffer sway bars. Way down the line I also want to replace the stock EFI system with a Halltech ECU but I will probably combine that with EFI Hardware ITB’s and a Zstory exhaust system. Separately from everything I would also like to upgrade the brakes for a full set of Willwood disk brakes at some point but that would also require increasing my wheel size to 16 inch. But my current brakes work more then good enough and I like my wheels so that isn’t really a priority. And when everything is set and done and I have some money to spare then I will send the body off for a full restoration and probably some carbon body panels. But those are really long term plans, you might have guessed but I am never ever selling my Z. This thing truly is my one and only dream car and I will pour my heart and soul into it. -
Converting the 240Z Passenger Seat in a Reclining Seat I found a need to convert my Passenger Seat into a Reclining Seat to gain additional Space. I know later models of Z cars 2 PLus 2 need to have Folding Seats to allow additional passengers into the Rear Passenger Compartment. So i removed the Factory Seat Tilting Mechanism and examined carefully. The mechanism consists of a Tilting Cam that limited the Seat Tilt to 15 degrees. A Steel Center Pin, in this case, operated as a Pivot Pin. So, removing the Cam and removing the Two Steel Pins should allow the Full Tilting of the Seat Back. First, Both Steel Rivit Pins had to be removed. A 4 1/2" Rear Angle Grinder with a Gringing Wheel was utilized to remove the pins from both brackets. Grinding the Rivet Heads off with Grinder Removing the Two Steel Pins-see Blue Arrows Internal Parts of the Seat Brackets Two Removed Rivets, Limiting Cam, and Outside Plastic Knob Weld two 12mmx 1.25 nuts to the Bracket Arms Amazon sells the new Plastic Knobs with 8mm x 1.25 x 30mm for $15. They come in a pack of Four Knobs but you only need Two per Side unless you convert the Drivers Seat too. Insert One Knob in the Center threaded hole to Lock the Seat in Upright Position. And Another Knob inserted in Center Hole for other side. Seat Folded Flat with both Knobs Removed-Maximum Space Available. With Both Knobs Inserted , Seat in Normal Position With Both Knobs Removed- Laying Back -Sleeping Position is possible. With Seat in Folded Position- There enough Space to Several 8 Foot Pieces of Lumber in your Z now. i hope this project will make your Z more useful and comfortable. -
PART 17- Fabrication work on the Gull Wing Doors is going at FULL BLAST!!! Detailed fabrication work on the Gull Wing Doors is very impressive. Actually, some of the work to correct "mistakes" are truly expert workmanship in action. Years of experience demonstrated how to solve problems. -
06-23-2026 ATLAS Z UPDATE. Cut and fit the 4" pipe for the intake. Using a 45 degree bend, and the 90, I cut turn/twist, cut on angles, and as you can see in the pics, trim off pie cuts to get the angles going where I want them to. This requires drawing a line where the pipes have to meet and welded in just that spot. It's exactly what I did with the other pipes. After welding, the welds are sanded down smooth and then my polisher does his part to make it look like a seamless one piece unit. I also used the new air cleaner and marked where further cutting on the hood was necessary and then cleaned up those edges. later, I will spray gloss black into the cap and use some q tips to paint the cut edge and it will blend right in. I also got the call to go pick up my 3 parts I had wrapped in black DRY carbon fiber....the cowl, rear spoiler and front bumper. PICS:
Pete! Looooong time! Can't provide help regarding your specific query, but it would be a lovely thing to have an old-timer reunion, if only virtually. I left the thorny wilds of Ohio and relocated (so-of back) to Los Angeles, where occasionally... maybe once every 3-4 months... one sees an S30 Z on the road. Not a "hybrid" (whatever that means anymore!), one presumes, but at least the body-lines are familiar. My Z is still with me, after 27 years... but like yours, has been off of the road for a while. The irony is that the chassis, suspension, brakes and so on, are decently OK... operate better that one might expect for a 50 year old car. But that engine! Never ran right, and now doesn't run at all.
toe out (especially significantly) will definitely make a car drive "twitchy". I've always felt a road car benefits from toe in stability. A track spec may vary from that but street toe in is usually an improvement. I'm really surprised by the caster number. 1º is very little. how well does it self center the steering wheel? If your happy with it then that's all that matters. but you may even have a little more improvement if you can get 4-5º out of it. -
Took the car to an alignment shop near my work last Friday to have them realign the wheels. I was in luck as one of their most experienced techs was in that day (old guy with almost 40 years’ experience with wheel alignments). He immediately recognized the car (old Z’s are pretty rare over here) and remembered working on a few of them back in the day. I gave him the recommended alignment specs I got from Apex Engineered and with that, my own complaints about the handling and his own intuition he got to work. Turns out the previous tech just absolutely butchered the alignment. He told me he set everything (camber, caster and toe) to zero but turns out I actually had a lot of positive camber and toe out in the front. For reference a -0,67 degrees toe means a 0.286 inch toe out, that’s massive! The rear still has some work to do as the track with needs to be increase slightly (by turning out the rod ends) so camber can be improved and toe can be turned in. As the rear control arms sit now (stock as shipped from Apex) the toe adjustment is slightly too long and the outer rod end needs to be turned out a bit. Unfortunately the front office didn’t really get how modified the car was and didn’t plan enough time for the tech to tackle this himself so I’ll have to do it myself and come back later for final adjustments. But man the car feels so much better. I have way more control over the car now and steering has become a lot lighter. I hope to make some time next week to fix the rear as I can feel she doesn’t like going over 80mph but that might also be because of a lack of aero. I do plan on buying a reproduction BRE style spoiler and an air dam. Zservices in France sells them made locally and even offers them in a textured black at no extra cost which might be interesting and won’t look that out of place on a silver car. They are also easy resell afterwards as I plan to replace some body parts with carbon fiber down the road once I have the body stripped down and restored. But those plans are for way down the line. -
I am using the stock headers. They had to get cut short to make the turn around the frame rails. It is using an OEM ecu ( I believe it was manual) that is running UPRev. The mounts are Mckinney that were sold by ZFever. Not sure how they got them sinze McKinney went out of business a couple of years ago.
carbz joined the community
What intake manifold do you have? I have seen similar problems with cannon intakes. Dead cylinders at idle and/or major flat spots or hesitations. The issue with cannon manifolds is they have a port that connects all the cylinders together. This is a bad design choose as intake pulses from each cylinder are able to interfere with adjacent cylinders. The solution to this problem is to weld the ports up between the cylinders, or change to a better manifold, like a TWM
Who's Online 0 Members, 0 Anonymous, 603 Guests (See full list)
