- Today
BrentB changed their profile photo
- Yesterday
Might be a month or so before I get to it, but I’ll post updates. Figured I’m moving all the guts to the carbon fiber doors, why not see if the auto stuff will work. Played with one of the axles last night, fitment seemed good and went together really quick when they are manufactured correctly 😅. -
Part 12- The Rear Suspension is being finished, The Rear Major Structure was fabricated and tied into the existing frame and roll cage. The installation of the Rear Air Bag Suspension will complete this effort. This project still has to fit the Mercedes Engie and Transmission into the car, do the electrical wiring, install fuel tank, complete front steering and suspension and do the bodywork and paint. All these things done in less than 4 months to make the Sema Show. - Last week
BrentB joined the community
interested in the power window kit, my cage makes my window crank a bit of a challenge so i was considering a window kit aswell. -
05-13-2026 ATLAS Z UPGRADE: I picked up my intercooler piping from the fab shop and dropped off at J&S Polishing to be all done up except the exhaust.....I have to finish the other half of it. The welds really look nice. My Braille Battery arrived to go with the Skillard battery hold down bracket. I went ahead and mounted the battery and the disconnect switch behind the passenger seat. I took the time to paint the areas in the foot well behind the seat, and painted the sides of the passenger seat and began putting things together for good. Pretty good for just a 3-4 hour break in the garage. PICS:
New axle shafts came in today, woohoo. Now that’s how the snap ring is supposed to sit. Hopefully I can put them together this weekend. Also got some other goodies, push to start electronic locks and window kit. -
Anjin joined the community
jhm replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
Great progress! The car's underside, as a whole, looks really good. 👍👍 Sorry I don't recognize that little L-shaped bracket -- it may be custom, from a previous owner. -
It’s been a long week where in a lot happened, including me getting engaged to my beautiful girlfriend last week! But personal stuff aside we are here for the Z. The body shop couldn’t wait any longer and with my permission they ended up modifying the passenger side frame rail to fit. All in all they did a great job and the end product looked great and above all was very strong. As an added bonus they even gave the frame rails a new coat of underbody spray and drilled two holes in each rail to coat the inside with wax and prevent condensation buildup. This meant I could finally pick the car up last Friday after being over 4 weeks stuck in the shop. By coincidence I was free from work that day so I even got to start the reassembly of the interior starting with the dashboard. And I also quickly strayed the Apex fender braces silver to match the rest of the car. I finished reassembling the dashboard during which I had a little bracket left over. I have studied every possible parts diagram and video but I can’t seen to find where this bracket came from. It was stashed together with all the dashboard parts and bolts but unfortunately I wasn’t smart enough to take pictures of the disassembly. Does anybody know where this little bracket belongs? Anyway I decided to continue the reassembly of the dashboard and reinstall the dashboard into the car. This went rather smoothly even though installing the dashboard all by yourself is a bit of a pain. I immediately tested all the electrical components to see if all the light (which I replaced with LED’s) and gauges still worked. Everything fortunately worked except the tachometer backlight which turned out to just be a reversed polarity, which isn’t an issue for halogen bulbs but is for LED’s. This was easy enough to fix by switching two pins inside the tachometer connector. I’m now at a point where the dashboard is complete and the carpet is mainly in. Because of a national holiday I will have a four day weekend starting this Thursday. This means I can finish the interior of the car and start installing the Apex front and rear control arms, steering knuckles and front crossmember. I really hope these don’t contain manufacturing faults or else they own me a really big apology. -
05-11-2026 ATLAS Z UPDATE. So I had a little time tonight before the sun set so I went out and taped the edges of the carboard I cut out in the pattern of the real cover (with the center cut out larger than the hole needed) and then cut cardboard into pieces and pushed it up to the fuel cell and taped them down all the way around. Then, by lifting carefully I was able to remove the whole thing, and....after putting blue tape on the aluminum cover, I used a Sharpie and drew the outline. Now I just have to cut it out and clean file/touch up here and there and it should drop right on!
boomstick08 joined the community
calZ replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
Flatout got a set of control arms that were made too narrow and don't fit. Apex seems to have been sending things very slowly lately and then having a low rate of good parts when they do send them. -
I've noticed that refreshing the page when it hangs seems to help. I can go down the main page and open new tabs with all the threads with updates, and some will load right away while others won't. I refresh the ones that don't load, and then they seem to come up. It isn't a 100% success rate because sometimes they fail to load again, but it's almost like some queries get lost and sending them again kicks the server into gear.
Most of the Apex kit has been good, a few minor fitment issues on some parts and that front bracket to attach the subframe with the hidden carriage bolts was a PIA to get in. Getting these axles has been a mess. I ordered the rear kit 8 months ago and still waiting on parts. Luckily I’ve got lots of other things in my build to work on, but if I didn’t I’d be really upset. -
05-09-2026 ATLAS Z UPDATE: I finished installing the Apex Engineered rear strut bar and then went about cutting the floor pieces from my skilard floor and got it to fit all back together. Then I installed my rear license plate light and got everything all wired in at the rear of the car, and finished running the fuel cell breather hose down and cleaned the whole area up. Then I started on the venter of the console. I used some thin gauge aluminum plate....making templates out of cereal box cardboard and then cutting the aluminum to fit. Then I drilled holes and mounted the 2 pieces for today, masked it off and painted it in matching Rustoleum glossy black hammertone....matching the dashboard. I took some cardboard I had left over and made 2 templates of the rear cover plate, and then cut the center out of the first one, so I can begin the process of taping in pieces to get the hole cut out just right, then I can cover the aluminum skillard cover with blue tape and draw out the pattern and cut it out. I am also going to be installing the Snow Performance Stage 1 braided water ethanol 3 quart tank back there, but I haven't decided on the spot I want yet. All teh wiring is now ran up and down to the floor behind the passenger seat. PICS:
engine looks great. Really loosing confidence in APEX parts. -
Apex said that batch with the new vendor had the groove to short, they are sending some new ones. Glad it wasn’t me, was racking my brain trying to figure out what I was doing wrong. Go the rockers and intake on today, engine is getting close to done. - Earlier
Doing some housekeeping and realized my dumb 240z site was down. It's back up now for whatever that's worth.
05-08-2026 ATLAS Z UPDATE. My Snow Performance Stage 1 Water-Methanol kit with braided lines arrived and I have started the layout of it.
I'm seeing videos and pics of S30s running the full track attack setup. Are any of those folks on this board? I'm installing the 2026 version now with 5 lug and 370z 14" brakes. I wondered about the upper diff mount being solid but then realized that on the 370z the upper bushing goes into the solid frame. The track attack has the whole rear cradle being suspended by bushings already so adding an additional upper bushing to the diff would be doubling it. We'll see when I'm on the road.
Its been 10 years. Delete please
Yokai_Z joined the community
A slow-responding forum is commonly caused by high server load from excessive traffic, inefficient database queries, too many active plugins, unoptimized heavy images, or poor caching strategies. Other factors include network congestion, inadequate hosting resources, or unoptimized JavaScript. In other words, unless the forum owner owns the server - money ain't the problem - it's the server connecting to the internet.
Seems like half the time the site isn't even accessible. What's going on here? If money is needed, then I would suggest starting a fundraising campaign with its own separate thread. In the past, they've done well. Maybe another merch run if Cockerstar is up to it. The site is slow as it is due to the decline of forums. If this site becomes regularly inaccessible, it's probably going to kill off the remaining activity it has completely. Forums these days are mostly running on momentum, site problems kill that.
Phantom started following Ls1 swapped 280zx exhaust issues
Phantom replied to bajajoas's topic in Gen III & IV Chevy V8Z Tech Board
The steering shaft issue seems to be fairly common on LSZ's. My '77 280Z (which is manual rack & pinion) has a large diameter hole in the driver side motor mount to allow the stock steering shaft to go through. No elegant but has worked well for 23 years. Don't get in the death spiral of needing another modification based on something from a previous mod which was based on a previous mod, etc. I saw that alot so spent a lot of time noodling over fitment issues to keep things as simple as possible. FWIW - the 280ZX and the 280Z are very close i weight so would imagine the 280ZX would be fine without power steering.
Who's Online 0 Members, 0 Anonymous, 1366 Guests (See full list)
