    33182
    5167
    awoodward3d
    awoodward3d
  1. Past hour
  2. Got the u-joints sorted. I could not get it off, ended up cutting it off and buying a new U-joint. Quadruple checked they were in phase before attaching this time 😅. Also got pedals finished, should put them in tomorrow.
  3. Today
  4. Oh I know, I just meant that most people only speak when they've got a good answer, and there are fewer people around now, so you're going to get fewer answers. It does suck how little activity there is these days. A lot of the experts aren't around anymore.
  5. Started work on the motor mounts for the Atlas Z car swap. I bought the motor mounts online for a tad over 30 bucks, apparently made for an LS, then I had to chop on them ( doesn't look good )and then made 1/4" thick steel plates for them to bolt to and then plates for the K member. It is all being bolted togther, and will then be welded when done. Next is taking the spare K member and strapping it to the engine in place, and cutting the remaining pieces and marking everything so I can take it to a shop and have it all welded. After that, sI will be doing a lot of cleanup on them to make them look pretty and then the Atlas will be ready to drop in! Once it's in, then everything will be bolted on to it. My remanufactured AR5 5 speed also arrived today, looks brand new.....no bellhousing, so I have to swap the old bellhousing on, and box up the old tranny to send back for the core charge....they are paying the shipping! Pics:
  6. Started work on the motor mounts for the Atlas Z car swap. I bought the motor mounts online for a tad over 30 bucks, apparently made for an LS, then I had to chop on them ( doesn't look good )and then made 1/4" thick steel plates for them to bolt to and then plates for the K member. It is all being bolted togther, and will then be welded when done. Next is taking the spare K member and strapping it to the engine in place, and cutting the remaining pieces and marking everything so I can take it to a shop and have it all welded. After that, sI will be doing a lot of cleanup on them to make them look pretty and then the Atlas will be ready to drop in! Once it's in, then everything will be bolted on to it. My remanufactured AR5 5 speed also arrived today, looks brand new.....no bellhousing, so I have to swap the old bellhousing on, and box up the old tranny to send back for the core charge....they are paying the shipping! Pics:
  7. The frame rails are nothing special except folded metal. You could make a pattern from heavy card stock and have them created locally and save a lot of money. Those would fit your car exactly. That will save you the tarrifs and the shipping. 1,5 mm thick rails should be more than enough. The other option is to split structural square tube and if you can't find a sheet metal shop. That will probably be more expensive, but is an option. The fender brace is a very simple item you could save money having made locally too. I helped a friend with a street car project and rather than weld items to the unibody and increase the potential for rust we opted to use some of the structural adhesives that new cars get built with. It's been on the car for 15 years and seems to be holding up well. Hope this helps, Cary
  8. Yesterday
  9. I am planning to do it the right way but finding a body shop that can straighten the car is a bit difficult. I was always planning to fully strip, repair, straighten and repaint the car at some point but if it’s possible I would like to at least be able to drive the car on the road. Seeing as I don’t have a car trailer and “officially” my daily driver isn’t allowed to tow more then 1400kg it would be a lot easier to transport the car to body shops under its own power. And for that I need an valid inspection…. Instead of diving head first into an full restauration, which will take years and tens of thousands of euro’s in one go, I’m just trying to spread out the costs and take it on piece by piece. I would like to at least enjoy the car for a bit and attend some meetings in my 280z instead of my Opel Astra diesel estate. Seeing as most parts come from the US it’s a big hurdle to buy. Shipping is very expensive, there is a 4,5% import cost and then a 21% tax on the total amount. In all I pay 50% more than someone from the US for parts. This also gives me time to calm down the misses a bit as she only sees the dollar signs flying away. I have seen this spiral before and I don’t want to end up with a stranded project. I want to keep my Z for life and I will take care of her.
  10. Last week
  11. 4200 engine update. Progress pics of my intake. almost ready to go to the polisher!
  12. 4200 engine update. Progress pics of my intake. almost ready to go to the polisher!
  13. Whatever frame rails you choose, have them put on by a body shop that can straighten your unibody first. You shouldn't have to use non stock parts to correct a tweaked unibody car - that's poor economics.
  14. tonight I pulled the tape, it had cured enough, it will continue to harden even more. This is not "just filler" or bondo.....it is 80% aluminum filings and 20% resin. It will not shrink, it will not crack, it is hard as a rock. They poured resin over the Pharaoh Tutankhamun's body, and 3500 years later, to get him out of his coffin they had to chip him out......so it is permanent. ALL METAL Filler. wear gloves! It reacts on skin and burns like there is acid in it.
  15. I started at dark this morning, and got the seats, center console and dash out of the 260Z. prepped the holes in dash and they are now plugged and curing. then I took some time and just gutted the whole area, to include the dash. Finished at 1:40 this afternoon.
  16. I'm not complaining to anybody specific. Ive been around this site for close to 20 years and back in the day it was so helpful. Now its dead. Is what it is.
  17. Stock diameter I think is alright with wider wheels. 245/50/16 looks good honestly, but 225/60/15 has only a few options, and they're all basic all seasons As much as I want Watanabes in maybe a 16x8 0 offset I may just end up with the Panasports that Z Car Garage offers in a 16x7 with a slight positive offset. I'm not completely sold on the +11(?) offset of those. They're on a ton of Z's, and I think they would look a bit better as a 16x8, but short of something custom and over double the price I just don't think I'm going to get exactly what I want
  18. Another source of frame rails and chassis reconstruction pieces is Charlie Osbourne of "Zedd Findings" in Ontario, Canada. He used to have a website; but I think his only online presence is on FB, and he retails his products through MSA Auto. I've used his frame rails and can vouch for their quality and fitment...he's an extremely reputable vendor. https://www.thezstore.com/product/5249/premium-front-frame-rail-kit-70-78-240z-260z-280z I've used Apex Eng for their steering knuckles and some other pieces; and have always been impressed with their quality of construction and customer service. I really like the design of their low-profile outer tie rod ends, which should be a great choice for your 15" wheels. Keep in mind that wheel design and construction, and wheel offset, can still affect interference between the rim and the outer tie rod ends. If you know your specific wheel model and width/offset, I can probably give you more definitive answer based on my own experience. Not to take anything away from AE; but have you looked at the other vendors for those pieces (e.g. T3, Futofab, etc?) They all have their pros and cons; so make sure you've done a full industry survey before spending all that cash. And nearly all of them also offer Black Friday specials; so you're smart to wait a few weeks before making your purchases. Good luck with it -- it looks like you're really digging into this project aggressively; looking forward to seeing your progress!!
  19. As I’ve documented on this forum before I got kind of stift by the auction company and the previous owner of my 77 280z. The frame rails are rusted and need replacement to pass inspection and something is wrong with the rear suspension. I’m trying to not spend too much money at the moment but still want good parts that will stay on the car trough out the build as doing thing twice costs more in the long run. I will have to take the car to a body shop to get the frame rails welded so I’ll be looking to get pre made frame rails to save on labor cost. That gives me two choices, 1,5mm thick reproduction rails from KF vintage or the 3mm thick rails from Apex. The KF rails are send trough a warehouse in Spain so that saves a lot on import cost for me but the Apex rails are twice as thick which may give the almost 50 year old car some much needed strength and rigidity. Does anybody have the Apex rails on there car and how are they holding up? As for the rear suspension the question is if it is the chassis itself that’s crooked or something in the suspension. As I can’t find many stories of bend chassis online I’ll take the bet that it’s the rear suspension. That means I’ll have to look for adjustable rear control arms. That way even if the chassis itself is a little bit crooked I can tune it out for now till the car will be fully restored. Again that search let me back to Apex, there was also Silver Project from Europe which was a lot cheaper but I don’t hear much good from them. Has anybody installed the rear (or front) control arms from Apex with mostly stock suspension? I currently have a list of products form Apex which interests me and I’ll probably wait till Black Friday to see if they got any good deals. I don’t know if I’ll order everything but the frame rails and rear control arms I’ll probably order. This is what I’m interested in at the moment: - Frame rails - Rear control arms - Fender brace (If the car gets welded anyway, why not) - Rear strut brace - Front control arms - Low profile outer tie rods (I run 15” atm) - Inner tie rods (because of the threat difference) - Steering knuckles All combined should give the chassis and suspension a nice upgrade and the adjustability I need to get the car on the road. I do plan on keeping the four lug setup and the coilovers that are currently on the car. I do like there coilovers but That may be too much money for now. Yesterday I contacted Apex Engineered with some questions and they claim that the suspension components I’m looking at do work with the stock components. Are there people on here running Apex components (except the track attack kits) and what is your opinion on them.
  20. There's a shop near me that has been advertising pre-buys for these bodies(and others). I get the impression that they're working with the manufacturer.
  21. I answer questions whenever I've got a good answer, but I haven't tried enough different sealers to be comfortable risking your engine on my recommendation.
  22. He does mention having to trim his stock valence a bit with the 245s, but 225s and you having an air dam is more clearance in two ways. Small chance of rubbing though.
  23. Here's a link to pictures of @ktm's car that has 245/50R16 tires, so you can see the diameter.
  24. You could step up to 225/60R15. They're a inch larger in diameter than your current tires, but I think stock diameter tires are a little small for the wheel wells anyway. Some guys run 245/50R16 tires, and a 225/60R15 is the exact same diameter, so I don't see why they wouldn't work.
  25. I took a break from the project but recently started getting back into things. I also went to go visit the shell at the bodyshop earlier this month and they're doing a great job. Buttoning a couple of things up, I finished setting up the fuel surge tank. The original FPG setup had some looped fuel lines and other things I wasn't keen on. I ended up doing 10mm nylon hose to a Y block and a -10 SS hardline return into the side of the surge tank away from the wiring. Generally the whole contraption is a pretty tight fit and just about everything needed to be exact/deliberately placed. I've also been working on modifying and welding a bunch of suspension parts. Mostly plating and reinforcement, some aesthetic before sending things off for powdercoat and zinc plating. In the next few weeks I need to figure out some wiring and misc. bracketry before the engine bay gets finished out.
  26. Well. The above mod worked and its now front jumped. Had to make a new dip stick tube and then I started on making an adjustable cam gear. Turned the inner bore out and faced the rest so ill have a good flat surface for the aluminum inner hub to bolt to. I realizing noone answers questions on here anymore and people just use it for documenting their builds. Its really sad.
  27. Feels like the options for smaller wheels are just becoming impossible to find, at least in the US. Europe and Japan still have lots of small new cars, so I think they have a couple more options. Even the more popular size Miatas use in 225/45/15 I can only find in 200tw, but they're so much shorter than stock, I think they always look terrible and out of proportion on the Z Potenza sport looks okay. I think the 052 is out of the question as a 200tw, but moreso because of the cost. I'm trying to keep it under $200 per tire so I can spare some change for the wheels. Right now I'm thinking of the Continental Extreme Contact Sport 02. They're 340tw, but supposedly slightly better on the comfort than most other options, which I have started to care more about now that the car is much nicer haha. Know the Toyo Proxes R1R are popular for some guys running 16s, but they're only in a 225/45 profile. I appreciate the support! I know many posts have nothing people can really respond to, so sometimes it feels like you're just typing into the wind, so I appreciate that people have been enjoying the build all these years.
  28. All my wheels are 15" and 16", so I can definitely feel your pain. Have you looked at the Yoko Advan 052? They make it in a 245/45-16 size, and it's pretty high performance. I'll probably get myself a set, once I talk myself into the that high pricetag. 😜 I've been running the Bridgestone Potenza Sports (300tw) in that same size the last couple years; and have been fairly impressed with them. Great street tire, wear like iron, and can even put in decent trackday lap times with them once they've got some heat in them. Your car's looking great....I love seeing the updates!
