- Today
it didn't occur to me that it could be something specific to this page but mine has been painfully slow for at least a month. Just assumed it was something to do with my internet.
Seems fine to me. Must have just been an intermittent issue.
- Yesterday
Part 11- trial Fit of the 370 Rear Drive Sewction into the 260Z. In this episode, the Car is finally on the ground for Rear Suspension construction. Since they are using a Fiberglass Hatch Delete section, there will be very little space for anything else but a Fuel Tank Cell. the major problem is time to finish the car as they are not even at the half way point of the build. The craftmanship truly amazing as they solve problems with building a one of kind vehicle. . -
Been a long week but got everything completely stripped and got some epoxy primer layed down on all the metal surfaces. have plenty of body work to do but atleast its sealed and protected now. Hopefully in the next week or two i can get the bodywork done and get some color on it. I did talk to john and his comment is "I don’t claim to be an expert on bonding. But in my experience cracking at a bond line is often due to inadequate surface prep both the underside of the fiberglass and the underlying metal), poor bonding agent, not enough bonding agent, cheap body filler, and/or excessive flexing of the unibody. On the other hand, I know a lot of guys who do the bolt-on installation. For performance applications, it can be an advantage for working inside the wheel well". With that said I think I will spend the time to make the fitment as good as possible and make a last minute decision based on how well it fits/looks. - Last week
Brad-ManQ45 started following Hosting site slow to respond.
What is wrong with the server setup on the hosting site that causes such slow response times?
Front end got tidied up quite nicely and I made new brackets for my intercooler. The drier clears, but I'll have to place the trinary switch on the #6 line instead of the drier. No big deal, but I wasn't able to make the rest of the hoses while I was here. Used on the threaded holes for the original airbox for one of the top brackets, and an existing hole made by the previous owner. The brackets on top aren't supporting weight, just preventing it from tipping forward or back so it doesn't torque on the lower brackets and bend them. Only downside is the brackets look slightly lopsided but the intercooler is centered! Took the car to get aligned and they told me there was play in the steering shaft from a cross threaded bolt. Looks like the end wasn't all the way in and the bolt had never crossed to the threaded side. I loosened everything, chased the threads, and got everything tightened up. Also added one of the missing trim pieces. Looks much nicer. The car as a hole is feeling pretty good, and nearly everything is great. I'm just at a loss with the rear end. I know it'll probably help slightly when I go to the 3.54 rear and everything is rebuilt but there's just this persistent vibration. Flipping the driveshaft 180 somehow solved most of it, but I still get the occasional buzzing and it's driving me crazy. I'm about ready to go back to the stock control arms, oem spindle pin, stock mustache bar, and a kameari mount on the original front diff crossmember. Everything on the car just feels so great except for the rear end buzzing or squeaking. So much of the car is damn near perfect that the small issues like that are a distraction from enjoying it as much as I could. Alignment rescheduled for today, so we'll see what they find or if it solves my problems. -
Turbodelta joined the community
To wrap this all up, it made 308hp 358lb/ft at 4510RPM 17PSI. Power was climbing the whole time, but it ran out of injector at 4500RPM so I limited all runs to this. More power than expected. Plenty of power for the street, but to be safe I will step up to bigger injectors.
They are super light, I’ll get a weight on the shell this week and share, and in a few months when I get around to installing them I’ll get a full weight with windows/hardware. -
Those are incredible. I'm with Mitchel on needing to know the weight difference. You gotta put them on a scale for us. Very interested in fitment and your thoughts along the way. They look like they allow for roll up windows and factory door handles too. very nice. -
Mitchel0407 replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
I would love to see a full weight comparison between the original and carbon fiber door. I know from lugging my 280z doors around that the factory doors are quit heavy. -
Martathord joined the community
dylus121 joined the community
Without the oil cooler, my water temps were never an issue. Never over 200 on track. When I put the Aviaid Mangusta pan on the car it had a provision for an oil temperature sender. Even though my water temps never got too hot on track, once I installed an oil temp gauge, I discovered that my oil temps were getting near 300F. I added the Setrab 34 row cooler, and my oil temps stay below 250F. -
Thanks sharing the pics. How do your oil temps do? I’m thinking of going with 2 smaller coolers so I can mount them right behind bumper on the sides to get direct air. My 370Z over heats at the track with oil cooler, intercooler and radiator all stacked. -
I threaded bolts up, looks like they’ll fit, I’ll find out soon. -
On my car, I am using the SN95 timing chain cover, water pump, and pulleys. By doing so. I have a couple of extra inches of space at the front of the engine. - Earlier
bolt pattern looks too small to. maybe just the photo? -
Snugged up harmonic balancer and installed pulley. Water pump pulley doesn’t fit, hole in center needs to be slightly bigger, about the size of that indentation. I’ll get that on another day. -
jhm started following 280z 1jz track build from a pile of parts
I should give him a call. I've talked to him several time when buying the parts. I read the PDF off ztrix site to a body guy and he was not confident in the success. but John may have some better ideas. -
Looking good! You're motivating me to swap over in the future. But I think when that time comes I want to rewrite the whole care and tidy things up. Decades of splices here and there into the main harness has gotten messy despite being functional
waiting on apex engineered LS mounts to come in Tuesday. They sent me some to see how much I need to modify them to make them fit on the LT motor. Then there gonna make some to start offering for kits
- 1 reply
- 2
John Washington (ZTrix) would probably be a good resource to talk to....he's been building/installing those for many years. I like what you've done with your front core support -- did something very similar on my car when I replaced the front frame rails. Great progress -- love seeing your updates!! 👍👍 https://www.ztrix.com/ -
Many, many discussion threads on this exact topic. Here's just one; but it should be helpful for you. You didn't mention if you had done any body or suspension work, so I'm assuming you are stock all around.
I'm real hesitant to try and mold the rear fenders. I have mixed feeling of molded vs "bolt/riveted on". So many Z guys mold them but very little details on longevity, expcially from something that is going to see excessive speeds, heat, vibrations. ETC. Anybody have any real world longevity experiences and installation techniques? -
Although this is supposed to be mostly a race car, this car is a example of what I can build so and don't like cutting corners so changed my plans and going a bit further than originally planned. Pulled the glass (should have done that months ago). pulled the drivetrain and started sanding. Cut the arches for the rear overfenders. welded in the rear marker lights, fuel filler door, antenna, and started smoothing firewall holes etc. Hoping to get it in primer ASAP and start on body work. Found a few "easter eggs" under the paint but nothing too unexpected. Going to take the engine apart for a health check since its unknown. Depending what I find will be what I do. Hoping to see a healthy engine and just do basics. JZ are tough so feeling optimistic.
Who's Online 0 Members, 0 Anonymous, 1103 Guests (See full list)
