    33286
    5167
    Jerry Mitchell
    Jerry Mitchell
  1. Today
  2. Yesterday
  3. 03-01-2026 ATLAS Z UPDATE: Switched gears a bit, I decided to take a break from the trans tunnel and work on small stuff that has been waiting. I pulled out the 4" X 4" aluminum L backet plate I had, and measured and cut it to fit in front of the radiator, then cut out a portion to keep from inhibiting air flow to the intercooler! After I got that installed, I grabbed all the oil fittings and oil lines, and ran the oil line frm the filter boss to port#4 to help oil the 4,5,6 cylinder main bearings a bit, ran the turbo supply line and turbo drain line and installed everything, about 95% done on that. Then I installed the oil catch can and line and will go back and tie the line up later and finish the loop on the top fitting for that. Yeah I know it's gold....it what he had left....I will probably paint it blue. Before calling it a day, I mounted my electrical panel plate to the passenger floor plate or as Skillard calls it a heel plate. Then I just plain old ran out of daylight. PICS
  4. 02-28-2026 ATLAS Z UPDATE: I repainted the interior trim that goes behind the headliner with the landau Black SEM interior paint again and it looks like new, then I went around with some Locktite 567 and thread sealed the water, oil and boost sensors and ran them in and tightened them up...wiped off the excess..Then I started on the bracket for my gas pedal. There are 3 bolts above the gas pedal I will use to hold the bracket, and I am using 1/4" thick steel to hold it firm. It will need to be welded. Then the big job of hte day, then the trans tunnel isntall. Several trips of putting it in, deciding what to do, and then cutting strips of 18 ga. sheet metal, drilling holes, and self tapping TEK screwing it together. I have it about 90% done. I did it so that the majority was done before it was permanently installed in the car....that way I could cut off the screws and give it a last touch up of paint. I started running out of equipment and parts and had to do a couple other small things before stopping, taking a shower and running to the hardware store before they closed.... to God willing do more on it tomorrow. PICS:
  5. Cleaned up the block, got it primed and painted this weekend. Replacing pan and timing over, will paint timing when it gets in. Now I can get new parts on the engine, I’ll start with swapping the cam next weekend. Also ordered the TKX transmission should be here this week.
  6. Last week
  7. For the folks running lower-rpm, higher displacement naturally aspirated engines (say, 400 cubic inch and above), what have been your strategy to get reasonably quiet exhaust that isn't too restrictive? I stumbled across Flowmaster's purportedly quietest series of mufflers: https://www.flowmastermufflers.com/products/exhaust/mufflers/street_chambered_mufflers/50_series_big_block/ . These would, coincidently, go behind a big block (Chevy). Muffler size isn't an issue, since my fuel tank is removed (S30) and there's a fuel cell in the hatchback area. My question is about simultaneously quieting the exhaust and keeping backpressure to a minimum. This would be dual exhaust, of course, with a conventional crossover pipe, and headers (for the moment, block huggers).
  8. I have been way to damn busy last two weeks so haven't gotten much done. I did get to borrow a set of seats I thought I wanted, but they just really don't fit. being a full containment seat they basically stick out the window. I was also pretty disappointed with the quality. My buddy had these for one season in a drift car that lives mostly in a trailer or garage and they were already real faded from the sun and had plenty of little rips and tears after just one season. I ended up buying a set of kirkey intermediate road race seats. I have one of these in my other car and have put 100k street miles on it so figured id be happy with another set. I may add some head support pieces but for now I'm happy with them. Also think I got my wheel picked out. little teaser for now until I can get some tires and sit this thing on the ground
  9. I just posted this to ZCAR: “Receiving periodic/automatic emails that say: ‘Come back, we’ve missed you!’ Sometimes life gets busy enough that I forget to login. I appreciate getting occasional emails reminding me of this great resource. I also think it helps keep the involvement up in the forum. Excellent idea. Thank you.”
  10. The wheels I want for my 260Z happen to be 16" x 8" with 225/50-16 tires. I'm told they would fit with the CORRECT offset. Anyone know what that might be? Nick
  11. 02-26-2026 ATLAS Z UPDATE: Today I got my rollbar and rear strut brace back from the powdercoater as well as the tunnel I dropped off to sandblast. The rubber is still on there, but this yucky sticky layer of honey look goos (glue) is gone. I also picked up my trans mount, he welded it up and added gussets on both sides out of 1/4" plate. I painted the back side quickly before I ran out of paint. Ready for the next day in the garage! P.S. self tapping screws and sheet metal (18 ga) here and ready to built it back, then the welder will stitch weld it and weld the plates over the top and over on both sides to the door jambs. 1/4" thick, 4 inch wide plate. Car will be overbuilt int his area like I did with the radiator support. 350-400 horsepower you really have to, even with the reinforced floor I have.
  12. incrdibly nice work. Keep it up! can't see the flange on the turbo header....you hid it!
  13. this is very cool, I will be following along. Love the custom work. I am doing a 1jz swap myself at the moment so nice to see another with another person fab ideas
  14. turbo manifold is welded up and installed. I forgot to take pictures before it went in
  15. Earlier
  16. Kind of ghetto, but I am proud of it.
  17. was able to make the template for the back of the throttle.....will bolt right to a raised area right there with 3 threaded holes. good luck!
  18. 02-21-2026 ATLAS Z UPDATE: I made the template for the electronic, "drive by wire" throttle, and then started bolting together the parts of my Skillard rear deck flooring. I sits about 2 inches up from the hatch floor. There are some pieces that are missing, so I went as far as I could with that this time, and then I jumped on getting a transmission mount built. I used a 6" steel square piece as a spacer, since I have such a large space to fill up. I have it 90% done, I will have it welded up and a couple gussets cut and welded in, and then either powdercoat it or paint. Lastly, I started cutting on the old trans tunnel, and figuring out what I need to get as far as some 18 ga steel to cut and form in there. I will end up screwing it together and then the mobile welder can stitch weld it together, and fully weld then the plate that goes across, but that work didn't happen today....it was COLD and I got tired of my feet being numb. PICS:
  19. 😅 hopefully the only thing looking this good is the front. Ill leave the rest looking abit rougher. Really wanting to pull it out this year and at least drive around the block
  20. Looking GREAT!! 👍👍 I really like the metalwork....makes you look like a skilled Italian craftsman (whereas mine makes me look like a one-armed monkey with a rock and a baseball bat.)
  21. this has to be one of the slowest builds....small update.
  22. 02-19-2026. ATLAS Z UPDATE. I trial fit the rollbar and rear tower brace, and then dropped them off to be sandblasted and re-powdercoated in "polished aluminum" which is what I had my bellhousing done in. Then I worked more on the dash, I still need to wire it, but I got all the gauges in, the dash plaque in....for the dash plaque I had to build up the back, as the hole makes it DEEP.......cardboard stacked up to the right height and glue, then silicone caulk to hold the badge on, looks pretty good I think. a 280 dash but the plaque says 260Z.....so pretty rare sight in the USA. So, you can now see how the dash will look in the car God willing. I also ordered the skillard lower piece that goes from the center down to the console and also serves as a stereo block off plate. I will be painting it matching gloss black hammertone finish, and the console floor will be that color as well. The gauges didn't go in totally as easy as the install makes it sound....I had to get inventive. Not too bad. PICS:
  23. Let me know if you have one, how much and your location - please. Thank you! Garrett
  24. 02-18-2026 ATLAS Z UPDATE: picked up my 1/4" thick steel plate for making the transmission mount, set out my seat belts for cleaning, and my rear strut tower brace from Apex and a Autopower Street rollbar from Motorsport Auto have arrived. So, I will decide what color I want to powdercoat stuff (gloss black of "polished aluminum") , and keep pressing forward. Will be COLD for a few days, so any work done will be indoor stuff. PICS:
  25. 8th build? Wow! I'm still nursing my first (and only). Car has been on the road, and off. Registered, and not. The current iteration is "not". I need help - local help - with the care and feeding of the engine. The real problem isn't with the Datsun parts, but the Chevy parts... namely getting that darned engine to work properly. Seems like a simple problem, no? But nothing is simple these days! Also, the exhaust is too loud, and the transmission is geared wrongly. I need a custom re-welding for the former, and to write a check for the latter. I also need an engine hoist and a place to work on the car. Success with hobby-cars, begins with success in real estate!
  26. I agree with Mitchel. You need to decide what end setup will make you happy and build towards that. With that being said you don't need to go all out and put yourself in debt to do it. If the purist in you says you need it to be nissan powered than that seems like it should be a priority. Do some research on the VQ. There are a couple good versions and a couple that you should avoid. I'm personally not a huge VQ fan but power, weight, balance, etc, should be great in a older Z. Modern electronics make a lot of these swaps easier. companies like wiring specialties or similar, should make generic "swap" harnesses for these engines and will require little integration into the chassis wiring if your not that comfortable with wiring. ApexEngineered makes engine mounts. Transmission options aren't ideal. CD009 are strong but gearing and shifter location isn't ideal in my opinion. I got one for my 1jz swap and didn't like it so went a different route.
  27. The money is a big consideration but the main point is more what it’s worth to you. Do you want a particular setup and is the money more secondary, is money a primary driver, do you want to slowly upgrade or go all at once. I see a lot of people mention only the costs of the build but if somebody is really passionate about something then it doesn’t matter as much. For example the fuel injection on my ’77 280z isn’t in the greatest shape, she drives good enough but the AFR readings aren’t the best (extremely rich at idle and slightly lean at open throttle). The economical thing to do is to just swap over some triple Webber carbs, but since I would like to keep the fuel injection I decided to, eventually, slowly upgrade the fuel injection with a new ECU and a set of ITB’s. I might spend 3 to 4 times the money but I’ll have a car that I want, as I like it.
  28. ATLAS Z: Sometimes, it's easier to remove the obstruction to get stuff in, then re-isntall and mod as necessary. As mentioned, I am reinforcing the tunnel and floor with a 4 inch wide steel plate from one side to the other, welded in at the door jamb on both sides, welded across the floor, up and over the tunnel, one solid weld. steel is 1.4" thick. Add a massive amount of reinforcement for the power level. When I re-welded my radiator support I did the same thing....took the time to reinforce it and make it stronger than before.......same concept your body uses when you break bone, it repairs larger and thicker. I showed the jack pick for shock value....hehe it was a last resort, and again, I didn't get UNDER it.........I had the trans on a jack all ready to go, so I just pushed it under there to it was in the well then lowered it back on to the jack stands.
  • Who's Online   0 Members, 0 Anonymous, 1329 Guests (See full list)
