- Today
Yep, same here. I'm on my 8th build right now, and still have designs in mind for several future projects. Despite the advent of numerous social media platforms, we're still getting new members on a regular basis; and there are always nods to our forum from the social media pages for technical data, expertise, and assistance! I need to give a HUGE shout out to @SuperDan for keeping this forum going (even at his own personal expense); and all the dedicated Mods & Admins that put countless hours in over many years to make the forum what it is.
Happy Birthday HybridZ. I’m a little over one year into my V8 track build, this forum has been very helpful 💪
The seats may be worth keeping, if their condition/design/material are something you'd want in the 240. The diff may be an R200, which is often desirable (even if it's an open diff). You mentioned the rear disk brakes from the ZX....really not worth considering unless you're planning to upgrade the stock front discs on the 240 (all of which is largely unnecessary if the 240 is street-driven, IMHO.) The rest of the suspension/steering is not typically transferrable -- the S130 design is significantly different from the S30. Nice-lookin' 240, BTW! 👍👍 And welcome to HBZ...happy to have you!!
G-Tech started following Does anybody know what today is?
Well Happy Birthday to Hybrid Z !There is still plenty of time to keep playing! What a great forum it has been. Thank you for those who help keep it going! I'm close to the 20th century (2004) since i started on my Z. Still going strong
HybridZ is now 26! It's too old to remain on its parents' health insurance plan, and now needs a real-job, with benefits and maybe even a 401K plan. Anyone left here, who started working on their V8 Z project back in the 20th century, and is still wrenching on it? Anyone?
- Yesterday
Thank you. I have some experience with Megasquirt and have a unit in a box. I may look into that.
I agree, keep the fuel injection for drivability but if it’s in your budget I would look at aftermarket options if the current stock system gives you too much trouble. If you just want a simple plug and drive solution then the Fast EFI might be the simplest option that keeps the car closest to stock. But if you have a bit more to spend then I would suggest going for an ECU that capable of sequential injectors instead of batch fire like the Haltech Elite 750. If the stock EFI starts to fail and you just want the car to run and drive good on a “budget” then I would suggest looking for some second hand triple Webber carburetors. It would just be a case of removing all the stock EFI components and intake and slapping the Webbers on (with ideally some slight dyno tuning to dial it in). The stock fuel injection system and ECM are nearing 50 years old now and most are slowly starting to fail. I believe mine is also on the way out as the idle is very rich in fuel (10,3 to 1) and no matter what I do it just won’t change, it looks like it’s stuck on the WOT fuel setting (yes I checked the TPS and everything else in the EFI bible). The car runs good enough for now (13,0 to 1 when driving) and once the frame rails have been repaired the car will pass inspection but the next step will be an new Haltech EFI system with properly some ITB’s from EFI Hardware.
I would keep the fuel injection for better driveability reasons. You may consider going to aftermarket EFI if the stock isn't up to snuff, but a good workshop manual should make it easier to troubleshoot. Going aftermarket can clean up the engine compartment though ...
Hi all, I'm new to HybridZ. I'm looking for information on the best parts to pull from a donor car I just picked up. My 240z and the 1982 280zx donor are in the pics. The donor car is complete and the odometer shows 71k. My plan was to pull the full drive train and swap it into my '72. I will save all the parts from the '72. I want to keep the car all Nissan. So, for the motor, is it worth keeping the fuel injection? I have also seen something about using custom brackets for the rear disk brakes. After I have picked what I want the rest will be parted out. Thanks for looking and good info. Bill
- Last week
luigi replied to flatout's topic in S30 Series - 240z, 260z, 280z
The heater hose block is really elegant!! I'd like to buy a master cylinder adapter plate (if you sell them). -
Have to agree with you there. Living in a climate with winter weather, I'll never build another car without heater/defroster (even a dedicated track car). The car's looking great...I love the custom machining. 👍👍 -
glad to help, contact me anytime...turbo240z@yahoo.com
Got a few more things done last week. Made a driveshaft adapter to switch from the 1310 ujoint to a 1330 ujoint flange. now to order a custom driveshaft. The technotoys rear parts allow for some placement adjustment of the SN R200 so I made a spacer to slightly move it forward to align the axles better with the hubs. For some reason the diff itself is slightly crooked with their front mount so i'll be remaking that at some point but not a priority at the moment. havent ordered yet but got a good idea what seats im going to run so took some measurements and got the most of the cage tacked in. Harness bar height "should" be good but I wont fully weld anything until i have seats incase it needs to move up or down. -
02-08-2026 UPDATE. Today I completed further work on the fuel system. It is on a sheet of metal that will be hung from the ceiling down on all thread to where the pumps are horizontal facing the floor and a tad bit lower that the fuel cell outlet so gravity flow will be good. I then took all of my interior panels I have out except he center console, and cleaned them up and painted them with SEM interior paint....Landau Black....which was referred to me years ago and really is a perfect shade and everything for these old Z cars. After they had dried, I quickly installed them a little bit, not fully, but enough for them to be in place, and then finished leveling up my fuel cell and bolted it all down. I am having some problems with the pilot bearing for the trans.....it appears I will need a sleeve or perhaps a bearing with a larger O.D. as the ATLAS, never came with a manual trans, and the well for the pilot bearing is roughly twice that of the bearing I have here that I strangely was told to use. So, I am working that problem out. I also went and installed the door handles and door locks, a bit more work in the doors, and they will be ready to be sealed up. Also got the lock mechanism into the hatch lid, but none of the rest of it. I painted the seat brackets on the floor in anticipation of a rather soon to come re-entry of the seats, which are fully reupholstered. PICS:
I started stripping the car today so I can put it on my rotisserie for few unibody sheet metal repairs... mostly the floor and the rear portion of the frame rails. I removed the heater core box, the engine and transmission, the front struts and the rear axles. I still need to remove the rear differential and the gas tank. I have a 2006 Chevrolet Corvette Z06, and one day I was looking at the brake vents and thought they would be good for the 240Z. And so they are! I installed these before I went to Road Atlanta in 2016 (I think)... this car has been off of the road for so dang long now! Anyway, they worked very nicely to cool my brakes. I made a custom fiberglass piece to adapt from the Xenon front spoiler to the round inlet of the Z06 vent, and used one screw and washer to secure the back of the vent to the inner wheel house sheet metal. The front brake rotors are Z31 vented units. I still have the unmodified backing plates on them, which is a mistake. It prevents air from getting to the back side of the rotors. Something else to address added to my list! Rear rotors are Z31 units. Calipers are 240SX. Axles are Z31 (with custom shafts). I bought parts from Ross back in the day (Modern Motorsports) for the brake and axle conversions. I bought the R200 differential from an eBay seller probably about 20 years ago. It was a NOS 200SX unit with a 4.11 ring and pinion. I removed the factory carrier and replaced it with a Nismo clutch type limited slip. I bought a high capacity finned differential rear cover and a billet transverse link from Protunerz.com during the recent Black Friday sale. So, I will be installing those when I put the differential back in the car. For now though, everything has to come off the car so I can make it light enough to put on the rotisserie for the floor repairs.
Gearjamer joined the community
SEMA 2025 Chinese Version of Assembled Toyota A806 examined
Second Owner of the SEMA SHOW Toyota A86 Body The First Owner of the SEMA SHOW Chinese Made Copy of the Toyota A86 Body decided to sell the body. The real question is why? The next Owner bought it with the idea of attempting to assemble the body and create a drivable car. As the body has No VIN Number and No Manufacturer ID Number, they knew that car registration in most states would not be possible. They intended to use this body as a Race Car as no registration would be necessary. As the video demonstrate that most mounting holes that not align with OEM parts. Also, they discovered a lack of sufficient welds on the body panels. Mounting brackets were missing or mislocated. So even if it was going to used as a Race Car, major welding and reinforcement of the vehicle would be necessary. So far, there has no one that I know who purchased a 240Z body from this same manufacturer. So far, we could not get a firsr hand through inspection of the Zbody and find if that body is manufactured better or not. -
Here is the plate I made to assist with routing the dry sump hoses across the front of the engine: Here is the -16 AN hose that runs from the outlet of the tank to the inlet of the pump. It has a heat shield sleeve over it to protect it from getting overly hot from its proximity to the header. I put the intake manifold and carbs in place so I can determine how to route the coolant hoses from above the #4 and #6 exhaust ports to the thermostat housing.
I started tearing down the motor today. I’ll probably work on it some more tomorrow, would like to be painting it this month. Also starting to design and fab the fuel cell supports. Going with some 1” square tubing. Got this table to attach my portable band saw, works great -
Airclaw joined the community
02-06-2026. ATLAS Z update: my FabBot 4 inch back relocated shifter for my AR5 came in today. Very nice billet construction. Doesn't appear to need a gasket and it came with nice socket head bolts. Also got my RAM clutch pedal adjuster. This allows you to adjust where your clutch pedal takes up or if it takes up too high, this will allow you to adjust it so it takes up where you want it to. This is for hydraulic throw out bearing setups that are in the bellhousing. PICS:
I got their tail panel, the first one had manufacturing defects. I reached out, they replaced it free of charge. I have since bought fenders. While they certainly aren't NOS quality, they are good quality and will take less fitment that most used fenders and it's new metal. The stamping on both the fenders and the tail panel were all quite crisp. Again, not 100 point concourse quality but a good starting point for reasonable money.
02-05-2026. ATLAS Z UPDATE. I got up early and got on the road. I went to Junkyard Jenny's in Ft. Lupton, about 110 miles one way and bought a R200 rear out of a 1978 280Z manual trans that she got in. Less than 100K original miles and she inspected it and said it is VERY nice inside. So, I got the diff, the mustache bar, and the front mounting parts. I ordered a new gasket rom Eric at Z Car Depot, and will paint it up and install later....after the trans is in. then teh driveshaft . It's an open diff with 3:54 gears! Exactly what I wanted. I ASSUMED my late 74 came with an R200, but when I looked under there, a greasy R180 stared back at me! . If you are in the Colorado springs area and want a free R180 let me know. I took my Wilwood clutch master.....I got from Godzilla Raceworks, and masked it off, wiped it down with alcohol and applied several thin coats of silver engine paint. Why? to match the brake master and the color palette in the engine bay. You will also notice I used stainless fittings to get the hookup for the clutch line that I brought in from the cabin to the master nice and clean. On the brake side, I got the Master mounted up to my adaptor plate I finished yesterday and mounted it up requiring me to remove the clutch and brake pedals, move the clevis point on the brakes up 1 inch for a better pedal ratio as I eliminated the brake booster (I did this on my 240Z, so it was quick and easy). Once I got everything bolted up, I was able to adjust my brake pedal height, but ran out of time and daylight for the clutch side. I need to get a replacement locknut for the clutch master rod as I cant find the one it had.....and then use the Speedway threaded clevis and pin, which is larger diameter, and that is why I pulled the pedal and drilled it out. In the pics, you can see I achieved the clean install I wanted. I loosened the clamps holding the master cylinders and moved them, etc. little things to make it look even cleaner. I will plug the remaining "slop" in the holes drilled and paint with a Q tip to finish it off, but I have kept the shaved firewall. Yeah, I am happy. Not too bad for a big bumper 260Z.
02-04-2026 more work on the ATLAS Z. I got the adaptor plate for the brake master done, more progress on the fuel cell, and unpacked some stuff. Pics follow:
- Earlier
Part 5-Major Problems in the build -time may run out before the car is finished. https://www.youtube.com/watch?v=DcXWWiwmGSI -
Part 4-Fixing the Gull Wing Doors and create special Interior design work Finding a mistake costs a lot of correction time but when you doing a one of a kind project that is to be expected. Go to---https://www.youtube.com/watch?v=itN99F8VKbQ
Who's Online 2 Members, 0 Anonymous, 958 Guests (See full list)
