28
Everything posted by madkaw
Took the DS back to the shop and had it rechecked and wouldn't you know it ran perfectly balanced on their machine. So I'm taking the car in and have the shop check the driveline angle. I had made a change to the RT mount angle based on my measurements and it vibrates there, so I'm changing it back to the RT angle and taking to the shop.
I will add that I am currently having vibration issues, and not sure if it is the driveshaft. I am going to take it back to have it checked.
Anyone have a crank available in front of them to measure for a speedi sleeve? I imagine all the cranks are the same since all the seals are interchangable. I would like to have this preordered before I pull my engine and want to see if speedi sleeve has the correct size for our application.
Well I'm reporting back in on this issue and it's NOT resolved. I did moor the rear of the tranny down against the mount. I actuallu used a cable set-up(sorry no pics at this time), but it did eliminate the movement of the rear of the tranny. I still have the vibration and now I guess I am back to the driveshaft. I had the T-5 shortened by a reputable driveshaft specialty shop, but I question just the same. It seems the only thing left to try. I have had the half shafts checked and have my Subbie diff installed and still the same issue. Maybe the shop didn't get the drive shaft set-up right. I checked driveline angle and to the best of my knowledge i found that thr RT mount didn't put th diff at a low enough angle, so I lowered it-this was a while back and didn't change anything. The reason I think that my set-up was different and needed the change is because my custom tranny mount for the T-5. I am going to reset the RT mount back to stock setting and try once more. The driveshaft shop is equipped to measure and check this also, which is what i will probably will have done.
Thanks for the input guys, looks like I just need to suck it up and replace the rear main seal again-DAMN IT! I think part of the problem with the last time I did it was that it was hard to see what I was doing. I couldn't get the car jacked high enough to pull the tranny completely out of the way. I believe I scared up the crank pulling the old BAD seal out. I wouldn't have been able to see if there was a groove or bad spot on the sealing surface because of the awkward position I was working with. I think this time I am going to pull the motor instead. It's a little more work, but I want to do this right this time. I will have a speedi sleeve ready to install. Hell, i will probably just redo everything, oil pan and side seals-I hate oil leaks!
I just need a dizzy that has no bushing wear. My dizzy has a bad lower bushing and has ruined the shaft. I can swap over my module and pedestal, so hoping to find a good dizzy.
Well wouldn't you know it -the old Datsun guage is fairly accurate! It is slow to react to changes, but at cruise and idle it is fairly close. The slow reaction of the guage is probably why I summized the higher pressure at idle. It takes about a minute for the guage to stablilize at idle. Warm idle(800rpm), 10w40 on a 30 degree day here= 25lbs pressure(stock guage and verified by mechanical) Driving around it seems to hover around the 70lb mark.(stock guage) The mechanical guage is mounted on top of the valve cover right now, so i can't see it while driving. I will have to figure a way to mount it outside the hood tomorrow. So 70lbs would be normal over what rpms?
Cosmetics do count and that puts the Honda fit OUT of the running, but thanks for the input.
The Mazda is in the running , but it's MPG is one of the worst. It does have good reviews.
I own 3 subbies now and the BRZ looks fun, but crashes the budget and not sure on rear wheel drive for a 50 mile commute in all weather, than there is the storage issue. As far as power goes, I bet most all models will have a turbo option I will add that the subbie impreza is a candidate , but hey get really slow trying to get the MPG up. But I guess they all will be slow in this category LOL Not sure about the looks of the new subbies either
Well soon enough my daughter graduates from IU and leaves town, taking the WRX with her( sobbing on both accounts). This leaves dad with a 1996 impreza L that will soon be turned over to my so turns 16 shortly. So, I'm in the market for a new car. Criteria so far: 35 mpg highway Hatchback for hauling **** when I need to Fun driving experience , not a numb steering wheel Peppy for a gas miser, probably will go for a turbo I4 of some kind 20000$ max price Doesn't have to have all the bells and whistles- loving heated seats for my back! Not loyal to any brand I know that you guys own or have driven some of the smaller compacts and would like to hear some comments. My car was in the shop the other day and I had 3 different rentals. A Fiat 500-( I don't think so, very doggy and not enough storage) Honda civic, boring Toyota corolla - non hatchback and also dull Cars I have showed interest in are the Focus GT 2013, Sonic turbo, Hunydia Veloster , Mazda 3, Kia Rio( I know , I know), Dodge Dart coming out.Ford Fiesta . I like the VW GTI, but not sure if it's worth crashing the budget. It seems a lot of manufactures are going turbo 4s for 2013 models, so I might need to wait it out. I know it's a stretch to find something nice for 20k anymore,'but the smaller budget helps keep a higher cash flow for the Z. This will be a car for commuting to work mostly and I drive 50 miles each way. At 50 years young I want something nicer as a daily driver, but also want to drive my Z a lot, so I rather put money in the z to make it comfortable and reliable to drive anytime.
Excellent pics! This really helps me visually. So if there was something blocking that drain in the main, then it could possibly raise pressure and cause the leak at the same time.(just brainstorming here). I will keep you updated.
Beermate, Thanks for the info on the rear main return. I finally got the fittings to run a mechanical gauge in parallel with my sending unit. The seal is still there, just not holding the oil back.. It leaves a puddle in the garage floor and it comes out the bottom of the bell housing. When I replaced the previous seal it looked as if the oil was coming from the seal area. Everything else was changed too! Haven't run the car yet with the mechanical guage I am going to have a Speedi Sleeve ready to put on if and when I change out the seal So if the rear main cap was removed I would see this slot for the oil return in the cap itself? The filter bypass wouldn't cause high pressure, but what about the pump relief valve.
Well my memory fails me on how, but I took my T-5 to a driveshaft shop and had it shortened. I'm running the T-5 in my early Z. It cost me 120$-I do remember that. another thing to consider, if not already mentioned, that the U-joints are not replacable.
At 50 years of age I have contemplated a turbo 911. I make good money, but probably a stretch to afford the car and the maintenance(just tires alone are scary!) I really want to own a "super car" before I pass this world, but do I want to be car poor. Then yesterday i finally get my car back on the road after months being on jacks. I go for a small 20 minute ride and get two thumbs up from different folks and a guy in a van ahead of me stops his van at a 4 way stop sign, puts on his 4 way flashers and jumps out of the van with I phone and shouts---"hey can i take a picture of your car". Traffic backing up everywhere!! It may not run like a GTR, but the cool factor is there and so is the driving fun. I do understand where you're at though.
My oil pressure is almost running a constant 70lbs at all times. I plan on running a mechanical guage in parallel shortly, but I believe the guage is fairly accurate-why do I think that... I am on my second rear main seal- and it leaks. I thought for sure the first one was bad, but now I don't think it is the seal. I have read posts about a plugged PCV system will pressurize the system and cause a leak, but I have checked and rechecked that system and replaced the pcv valve. I am running a high volume pump and was running a HP spring. I replaced the HP spring with a regular pump spring a noticed NO difference in pressure. When I had the head off to replace the HG I blew air through the oil passage of the block to the filter and from the pump to the filter and it seemed to flow freely. This engine is fresh with less than 10k miles. I am running a drilled Schneider cam with NO spray bar. I have looked at the FSM and tried to follow the path of oil, but not sure if this told me anything. I am curious about the relief valve that is in the block. The FSM doesn't give any info about this, but it illustrates it in the flow chart. I believe I have a partial blockage and it is driving up my pressure, but not sure about how to find it.The engine runs good and can't see any signs that any component is lacking oil, but don't want to wait for this to manifest itself into a failure. I appreciate any suggestions to help troubleshoot this item. I am going to get the necessary parts to run the mechanical guage in the next few days, so i will report back on those findings.
Another reason not to use the cover is that it is too long and it would have to be modified. Look closely at my valve cover - it was shortened and it will still be tight running the plumbing. So I wouldn't want to cut up a 200$ cover and then have to cap it- or pay someone to cap the CF. Then there was the issue of getting the lettering right side up!
Alex, do you have pics of the n42 head , especially the chambers? Also what year is the l24 ? Finally, what's wrong with the original head?
I remember seeing your set-up while searching. I hoping to see that you continued the project, but alas, another non-blow-thru turbo set-up. Any plans to finish up?
If you have the head off, take the time and make it as detonation proof as possible. Make sure the chambers are unshrouded as much as possible and every sharp edge is softened. Even the spark plug hole threads that are at the end of the chambers-file them smooth. Do you have the book-'How to modify your Datsun engine"? You need to get it and study it. Does the head have the bigger valves? If it does they might hit the cylinder walls on that P-30 block. You'll need to notch your bores. Does the head have a performance head in it? I think your making a decent choice using that L24 block if you know it's okay-the less unknowns the better. If you can't answer the questions above you need to research before you install.
That comment was mostly in jest. I have been all over Monzters pages, and I know the deficiencies of this kind of set up.I have also acquired Corky Bells book. I think I will TRY to resist the temptation to pressurize Mikunis, but I'm a stubborn sometimes. I think this set up will work NA and look cool too!
Though weight is a concern, the majority of the weight with a triples set up is the triples. The CAI(valve cover) is gutted of all webbing and is shortened. So basically you have an aluminum box made from .120 cast.I'm thinking 4lbs with the backing plate. Do you think a fiberglass mold would look as good as polished out aluminum? I do believe the fiberglass type would be the best for weight, but can you pressurize fiberglass
Does anybody make a ZG flare reversal kit?
madkaw replied to RebekahsZ's topic in Fabrication / Welding
Once I make that committment there is no turning back, but I will sell off my cut-off lips for someone else that changes their mind
