Michael
    9
Everything posted by Michael
  1. Douglas - Point taken. I'm trying to be realistic about my results. Had a stock or stock-like hood been usable, I would not have done this. But, with the firewall relocation and other mods, I need a hood whose front lip begins somewhat aft of where the stock 280Z radiator "frame" is located, and which ends at the windshield, and which has about a 1/2" bulge to accommodate the air cleaner (any higher and my forward line of sight would suffer, as I'm short but I have to sit way back (Kirkey sheet-metal sit up against the rear wheel well). So far I have a spider web of thin wood planks, forming a structure akin to balsa wood model airplanes of the 1930's. I used a similar approach to built a sort of stubby G-nose, which is bolted where the original hood hinges bolt. There the finish was mediocre, but acceptable for my tastes. The foam which you mentioned - what is it's brand name, and what sort of retailers (home improvement stores? boat stores?) would carry it? Would it dissolve if covered with polyester resin? I prefer polyester resin to 2-part epoxy (very tolerant to incorrect mixture ratios of resin/hardener, very long working time), but the polyester resin has a solvent which eats away white insulation-type foam.
  2. No hope of fitting these without spacers if using the stock springs (no coilovers), is there?
  3. I’ve got a 24’ x 40’ detached garage on my 5+ acres in the boonies of southwest Ohio. But so what? My car project is still snailing along ever so slowly. It seems that if you don’t have adequate space for working on your car, the complaint is about getting adequate space. But once you get the space, you need the tools or the time to get the work done. And once you get the tools and the time, you need the skills. But getting the skills takes a lifetime. Anyway, the point is that even a small garage can be enough to build an excellent car; and no amount of garage space is by itself sufficient to make any project easy. Now if only real estate around here would EVER appreciate (it’s lagged the rate of inflation for decades, and the so-called “national†housing boom of recent years has completely bypassed this area)! So what’s my point? Well, if you don’t save your money diligently, you will almost certainly not have a comfortable retirement. BUT, save as much as you like – if you’re unlucky, you’ll still be poor in retirement. There’s much to be said for good judgment and good discipline, but the final arbiter is good luck!
  4. Would you be willing to sell cloth by the yard? If so, how much per yard? What’s the weight of the cloth (oz/yd^2)? I’m currently in the process of making a custom hood. Instead of a mold, I made a wooden frame consisting of plywood cross-members and pine stringers. The plan is to fill gaps between the stringers with foam, then cover everything on both sides with composite cloth. No mold, no vacuum bag, no oven. Just shadetree-type stuff.
  5. So maybe the oil-starvation problem that Mikelly identified would explain why the LS7 went dry-sump? If you’re a seasoned engine builder and an experienced wheeler-and-dealer, then doubtless you can build a stouter, more reliable and cheaper engine than the crate LS-7. If you’re not experienced with engines and are not good at finding deals, but you still have the ambition and desire for a niche engine, then the LS-7 starts making good financial sense. However, if I chose to spend that kind of money I would go all-aftermarket, with an aluminum Mark IV big block, a 4.5†billet crank, billet rods and one of several possible choices of heads (most likely AFR, since such an engine would be fine with rectangle-ports).
  6. Don't mean to get too far off-topic - but that huge rise in torque between 2400 and 4000 rpm - is that normal for turbocharged engines of this type?
  7. Stoking fear is every government's best instrument in making the public easier to govern. Fear causes people to willingly surrender privacy, liberty and self-determination to a central authority. Which is exactly what any self-respecting central authority wants! After all, a frightened public is more likely to reelect leaders who promise to "stay the course".
  8. Unfortunately chauvinism and xenophobia are eternal.
  9. Terry, what would you recommend for a brand of epoxy or polyester resin? BTW, I've had good luck with generic Bondo polyester resin (comes in a blue can), except that it eats away white foam. It works OK with pink (household insulation) foam.
  10. Ideal rear-end gearing would depend on a multidude of factors, including rear tire diameter, transmission gears, and operating rpm range of the engine. I recall mention of cars on this site running in the 11's or better, with tall gears such as 3.08; most Z's run 3.54, which is the most common ratio in R200 rear ends in 280Z's, and R180 rear ends in 240Z's. But intuitively, it's very hard to ascribe a slowing down from 12 seconds to 15 seconds in the 1/4 mile to bad gearing alone, considering that the Z's weight is comparable to (if not less than) the Monza, the aerodynamics are comparable, and the Z has better weight distribution. Could it be that something went wrong with the engine, during the swap?
  11. I've also heard that starters of Type 1 above are less reliable, because the starter gear is cantilevered. Can't confirm that from experience, though. One advantage of starters of type 1 is that some models have adjustable orientation; the motor casing can be rotated relative to the rectangular mounting block, allowing for adjustment of header clearance.
  12. Recently I built a custom nose-piece for my '78 280Z, integrating the headlights and radiator upper-support. I used polyester resin and cheap fiberglass cloth, both available from home improvement or generic autoparts stores; also, plywood ribs and foam between the ribs, with aluminum glassed-in here and there for hard-points. In functionality it's similar to a G-nose, but it's much shorter and follows a different philosophy. From that experience, for my next trick I'd like to build a custom hood. It has a slight bulge to accommodate a standard 14â€-diameter, 3"-high air cleaner atop the big-block. [with a Performer RPM intake, BBC’s are too tall to use the stock Z hood]. Again I'm using plywood ribs and wood stringers. The framing is coming out pleasingly, but I am concerned about underhood heat. The fiberglass cloth should be OK, but conventional polyester resin, as well as similar 2-part epoxies, would soften and possibly melt. So here's my question: any advice on brands/methods/retailers for high-temperature epoxy or polyester resin? I'm not expecting something that would survive a direct flame, but good stability at 250 deg F would be nice. I also plan to use a heat-insulating glue-on blanket, of the type used to wrap starters to prevent heat-soak. BTW, a search such as http://forums.hybridz.org/showthread.php?t=83659&highlight=epoxy+high+temperature is pretty much a dead end, but I vaguely recall discussions on this topic some years ago.
  13. My 1991 Corolla (rest in peace!) had a 1.6L 4-cylinder with 16 valves, but SOHC
  14. I'm one of the victims of the BBC cam lobe wipe problem. It happened to me with a very mild hydraulic roller from Comp Cams, DESPITE following proper break-in procedure. Since then I've learned of lots of people having trouble specifically with Comps Cams hydraulic flat-tappet cams. The other day I spoke with an engine builder who flat-out said that he no longer trusts Comps' off-the-shelf build quality (he says that their custom grinds are still OK). In the new iteration of my engine, I've got a Milodon high-volume oil pump and a Hamburger 8-qt pan with windage screen. However, the only oil-system mod that I made was radiusing the oil passage in the rear main cap - I didn't make any mods to the lifter bores, and now that the short block is assembled, it's too late. Crank main tolerances are quite loose, at least by Pyro's recommendations: 0.0025". I am going with a mechanical roller cam, partially because I want to hedge my bets on the cam-wiping issue. I'm getting top-of-the-line roller lifters and a custom-ground cam from Isky. The required valve spring pressure worries me a little, though; about 200 seat pressure, 500 open.
  15. I'd go with mechanical. They're harder to plumb, but are more reliable; no worries about a broken sender unit or poor electrical connection. BTW some years ago there was a thread on the accuracy of Autometer water temp gauges. As I recall, they can be off by some 10 degrees at room-temperature boiling point (212 deg F). I ended up with mechanical temperature and oil pressure gauges from Suntune (sp?) - from Pep Boys. Yes, they're cheap and cheezy-looking, but they are full-sweep and the water temperature gauge is dead-on accurate.
  16. Even with a brand new bushing set, thorough cleaning of the strut casting and sanding of the spindle pins, and liberal use of anti-seize lubricant, I found the "installation" of the spindle pin by hammering to be impossible. Eventually I used a hydraulic press, and with much creaking and moaning, the spindle pin finally seated. Indexing for the lockpin was comparatively easy, as the interference fit was much tighter in the A-arm bushing than in the casting, so that the casting could rotate relatively free. Definitely a poor design, and the most unpleasant mechanical repair on the Z.
  17. Project_BBZ, any updates? I still haven't decided on the heads, but am leaning toward the Brodix Race-Rites. Aluminum is important to me (more a personal preference than a rigorous engineering judgment), and small-port BBC head choices in aluminum are quite limited. Cam choice is shaping up to be a custom-grind from Cam Motion, or a very similar (both are mechanical roller) cam from Comp Cams, PN 11-770-8, XR274R series. I might use Comp Cams "beehive" springs, PN 26120
  18. Never mind the styling – I’m just disappointed that this thing is so heavy. Muscle cars were never particularly light, but they were lighter than “full size†sedans and wagons. And now the so-called muscle cars are themselves the largest passenger cars in the fleet. The same thing happened to the Mustang – weight kept creeping up in the 1990’s, and now lard has been piled extra-high for the new generation model. But at least Chrysler and Ford have SOMETHING that’s RWD and “moderately pricedâ€, bloated as it may be. GM still doesn’t have a RWD car, unless you count the Corvette and some Cadillacs.
  19. Mikelly makes an excellent point – if you’re going to spend $25K on a Z restification, to bring it up to (say) comparable performance levels to those of a modified C5 Corvette, why not just get the Corvette? However, considerations of “am I getting a good deal†and “am I buying the right parts†– which make or break any project – apply to both the Z and the Vette. Here’s what I mean…. First, the $25K modified Corvette figure makes two assumptions: that you have enough skill as wheeler-and-dealer to find a suitably-priced, good-condition specimen; and you have enough skill to select and install the performance add-on parts yourself. Well, the latter might be easy, but I would argue that if you can get a $20K 1999 Corvette in GOOD CONDITION, you probably have good enough street-smarts to score a comparably good deal on a Z – thus reducing the cost of a HybridZ from that of the above-posted estimates. I mean, apples to apples! You could just as easily spend $30K on a Vette with an engine that’s about to blow, a slipping clutch, dinged bodywork and shoddy electricals. Second, the Corvette is a heavy car with a long wheelbase. Sure, the handling might be great, and extensive mods might be required to the Z to achieve comparable performance. But the dartiness, the “tossability†that comes from a light car on a short wheelbase is very difficult to beat! In this sense, the Chevy CHEVETTE handles better than the Corvette. Third, the cost of making mistakes with the Corvette is higher. Remember, the real cost of a V8 Z swap isn’t in the parts that go into the car – it’s the parts that don’t fit, don’t work, or break, or are mismatched. Compare the costs of a cracked junkyard 350 block from a Caprice, vs. a cracked LS1 in the Vette! Fourth, the Corvette will always scream, “high performanceâ€, whereas the Z can remain somewhat subdued. That’s important in terms of insurance costs, attracting police attention, unwanted street racers, and so forth. And fifth, the Z swap is emotionally more satisfying, in the sense of an achievement of personal craftsmanship. The real apples-to-apples comparison is not 1972 240Z vs. 1999 C5 vette, but 1972Z vs. 1972 C3 Vette. Now compare the costs, the relative performance levels, and the mods involved!
  20. I have a 454 in my 78 280Z. It was A LOT of work, but my “swap†erred on the side of excess, in terms of structural rigidity and weight distribution. BBCs have a declining aftermarket support, especially for the middle of the road that’s neither all-out racing engines nor stocker muscle car restorations. In contrast, the aftermarket offers good options for 400+ cubic-inch SBC builds. The principal reason to build a big-block Datsun is that you’re personally familiar with the BBC engine, and prefer to work on it rather than the SBC. Then do the BBC swap – you’ll enjoy the car more. If you are starting with a clean slate, and especially if you’re inexperienced with Chevy engines, I can not recommend the big block. For an all-out drag car the BBC is an interesting option is you’re interested in 600+ cubic inches and 4-digit horsepower with nitrous. But I don’t think that there are any such cars on this board. The most powerful belonged to a member named Ron Jones. He had, if I recall correctly, a 502 making about 800 hp, good for 8.6 in the 1/4-mile. There are (or were) about 4-6 BBC Z’s on HybridZ. One belongs to Brad Barkley (Ratsun), one is the “blown blue Z†which is since been re-converted to SBC, one belongs to Corzette, one was a work-in-progress posted by a recently-joined member who decided to build a BBF instead. To my knowledge, all of the successful drag BBC Z’s are back-halved. Mine has the firewall set 6.25†aft and what some people might consider a tube frame, but the suspension is essentially stock. All of the BBC cars have some form of automatic transmission, typically a Powerglide or TH400. Mine is the sole exception (as far as I know) – a Doug Nash 5-speed. Bottom line – if you’re particularly enamored of BBC’s do the BBC swap; otherwise don’t. If you don’t have an engine yet, go SBC instead.
  21. Mike, just be wary of the 0.120â€. Much of that tubing is only around 0.118’, and if your race sanctioning body requires >0.120†tube thickness, a persnickety tech inspector might fail you. I went with 0.134†in the critical areas, just to make sure.
  22. Most things that we do, we do because we’re told to, or because we feel compelled to. Most things that we do for amusement and recreation are silly and soon forgotten. Unless they get us into trouble. Accomplishments? Like what? Cars rust, houses rot, fortunes crumble, muscles turn to flab. One thing that’s starting to become clear for me – and this Z project is contributing to the clarity – is that goals can be grouped into two halfs: those that can’t be achieved, and those that aren’t worth achieving.
  23. ‘Baddriver’ has an excellent summary of the cost picture!!! It answers, in a nutshell, the basic question of “how much does it cost to do a bare-bones conversionâ€. The answer is: if you already have your Z, and it runs OK, and you’re reasonably happy with the ride quality and the aesthetics and the suspension and the brakes, and so forth – and NOW you want to do the conversion, but for a “daily driver†that will have no particular place or purpose at the track – well then, the typical cost of “just the conversion†will evidently be around $4K. Another curious observation – if you pay a professional to do specific jobs (not the whole conversion, but merely specific parts thereof) – typically, you’ll pay about the same for the professional’s work, as you would for doing it yourself + buying the tools + buying the wrong parts + breaking things + starting over and trying again. Of course, that’s assuming that you’re not a mechanic and that the professional is honest. On my car, nearly everything that I built is hamfisted garbage. And nearly everything that the professional built is elegant and functional. If only I realized that 5 years ago...
  24. Car $600 Roll cage/frame $2000 Engine mounts, etc. $500 Firewall relocation $1000 Brakes replumbing $300 Radiator relocation $300 Fuel cell install $200 Fuel cell $200 Seat and misc install $400 Other welding $300 Engine $800 Shortblock rebuild $1300 Intake, carb, etc. $500 Exhaust $400 Suspension $300 Transmission $700 Clutch hydro $250 Clutch assy $300 Flywheel $300 Bellhousing $350 Seat $150 Belts $150 Bodywork (ghetto) $200 Electrical $100 Oil pan and pump $300 Plumbing $100 That adds up to $12K – give or take. The car is “rust freeâ€, but hardly attractive. It does have a brutal roll cage, though. Broken, obsolete, incorrect or dead-end parts: about $2000 Still necessary for engine†Heads $2500 Cam $400 Lifters $400 Rockers $300 Pushrods $100
  25. Some good points made above, but that doesn’t assuage my frustration.... The trouble with crate or OEM big-blocks is that they’re towards one or the other extreme: 3500-rpm truck engines that don’t make much more torque, let alone horsepower, than a mild 406 SBC; or radical race-only engines with 13:1 compression and 360 cc rectangular-port heads. Have you ever seen a crate BBC with a flywheel? Well, it if comes with a flexplate, and (I dare say) ALL of them do, and the crank is externally balanced, often the right way to rebalance the engine is to pull the crank, take the whole rotating assembly to the machine shop, and reassemble the short block. But if you’re going to do that, what’s the point of buying a crate engine? You’ve just disassembled what you paid someone to assemble for you! So what about starting with a crate short-block, say a Gen VI 502 from GMPP, and adding your own heads and valvetrain? Great, except that chances are that the piston dome volume is all wrong. Options are: angle-mill the heads to deal with the BBC’s monster 119-122 cc combustion chambers; run a mild cam; run a big cam but end up with inadequate DCR; or rip apart the short block and get pistons with larger domes (see above). So what’s the right dome size? It depends, of course, but for a stock-stroke 454 with 119cc combustion chambers and a mid-0.6†lift roller cam, it dome volume comes out to around +25cc. Ever seen a crate shortblock with a 25cc dome piston? Oh yeah, and then there’s piston to valve clearance issues. Bottom line, THERE’S NO GOOD SOLUTION! The BBC world has split into 3 camps: muscle-car restoration with nearly stock engines, trucks with nearly stock engines, and dragsters. Building a street-performance BBC (about 1.1 hp per cubic inch) isn’t getting any easier, despite the superficial appearance of lots of new aftermarket parts!!! Don’t believe me? Call up AFR, Pro Topline or Dart, and ask them about their oval port heads. Listen to the laugh at the other end of the line.
