Wow, sounds a lot like some of the stuff I went through except for the wiring. I've been running around fixing coolant and fuel leaks. Turns out I forgot to tighten the FPR hoses to the rail. Didn't actually find that until I leaned on the rail while it was pressurized. My plugs in the thermostat housing for the ports I'm not using were leaking bad. I got one sealed but ended up putting the temperature switch back in the other to keep that port sealed. It seems to be an odd deep thread. The pitch is easy enough to match, but the depth of the threads leaves a normal bolt or plugs loose even with tape. The only wiring problem I had was the FP relay. SM switches ground and I didn't want to run under the dash and change that relay around so I ran a second relay under the hood by the main efi relay that was switched ground from MS closing hot to the stock pump relay. Lots of fun, I really did enjoy the electrical portions of the job. It was tedious in some parts, but well worth the effort in the end.
