Well here I go. I am looking at my options for my next engine. I want to stay L series and go turbo. My longblock budget is pretty good to say the least. I want the motor be drivable. Maybe 350hp @~12psi for the street with the ability to go much higher.
I have heard things about the F54 block as well as the early 280 block.
They are both "stronger"...F54 because of webbing and early N42 because of siamesed cylinders.
Anyways here is what I am looking at doing.
3.0 stroker, 8.1:1 or 8.5:1 or lower compression. JE dished pistons or the like (not sure about how much dish), not quite sure about rods. Probably some 2.4 rods for better crank/stroke ratio but I have a set of 2.6/2.8 rods. LD crank. lightening, polishing, magnafluxing, cryo treating..what would be worth my money and what can I do myself?
I am pretty open to any head to use.
Most likely a holset turbo or a t3/t4 if I can...those are a bit expensive though. I want to have high enough compression to spool early but low enough to where I can run a good bit of boost.
Megasquirt, possibly with edis-6, Crank trigger, GN coil pack.
Intake? pretty open on that.
Exhaust? probably stock manifold until I can have a header built (I am designing one) , 3-3.5" pipe.
Right now the slate is wide open. I invite and look forward to sugestions from you.
I am about half-way done with the suspension (coilovers and illuminas are in but camber plates and proper top hats are still to come), 11lb Spec flywheel, have a broken in clutch that will hold upto 265 hp...
I would like to see different combinations people have used and combos people are thinking of using.
