RTz
Administrators
    23
Everything posted by RTz
  1. If you two don't follow through, you'll both be banned
  2. They are not typically installed with significant restriction on the 'ingest' side. Since you've made the self proclamation of geekage, I bet you can figure it out on your own... convert 2.8 liters to cubic inches, know that a 4-stroke engine displaces half its volume every revolution, factor in time, and bingo... static CFM.
  3. You're right, it wont work on .03v, and yes, the fuel pump should be running while cranking. Try this... pull the inlet boot on the AFM, turn the key to the 'on' position, and push on the AFM door. When the AFM door comes off its seat, it engages contacts to activate the fuel pump relay. You should be able to hear the pump run.
  4. If I understand you correctly, you're talking about 'blowing down the clearance volume'. Part of the purpose of valve overlap is to do just that. And it works very well on its own. However, depending on the engine, it doesn't become efficient until some RPM is generated. At low RPM, as you've implied, there is still a fair bit of exhaust in the chamber, diluting the 'useful' air. Keep in mind that its far easier to push air than it is to pull air. That is the reason we get by on smaller exhaust valves even though the exhaust 'volume' is greater (thermal expansion).
  5. Supercalifragilisticexpialidocious!
  6. Actually, he brought that scenario up in post 5. Not sure I follow. As I undestand it, with these ECU's, "cold running" is only handled by the water temp sensor, and its simply a 'compensation'... no 'cold operation mode'. Thats what my experience tells me. If you've found something different, I'd really like to understand.
  7. For what its worth, with regard to stand-alone, there is no reason you would get better fuel economy with a MAF system. Obviously, it requires proper tuning, blah, blah, blah. Point is, I'll bet money an aftermarket system is capable of BETTER fuel econmy than a factory ECU in stock configuration.
  8. This thread has gone far enough off course. Put it back on course or I'll put it away.
  9. Where do I begin? OK, lets start with your shift key.... please use it. There may be some terminology conflicts in this thread. Those always add to the confusion, but in a nutshell, your engine is modified extensively enough that you really ought to be considering a complete stand alone EFI system. You do not need a MAF system per say. MAF is a load measuring device, much like an AFM, MAP sensor, or even TPS (if configured that way). They all go about it differently and they all have their advantages and disadvantages. But they can all serve the same principle function. Load. There is a simplified description here... http://forums.hybridz.org/showpost.php?p=808851&postcount=1 Not remotely true.
  10. Don't think I will. I happen to agree with him. Morals and cars just dont mix.... at least not in my book. Exactly. Owner could be deceased... and here were are trampling.
  11. Thanks for getting back to us (helps the next guy). The unfortunate reality is that the crankshaft endures a lot of stress in that situation
  12. As Sparks hinted at, if you're only going to keep it for 3 or 4 years, re-sale value would weigh heavy in my choice.
  13. The D80 is wonderful with color. Reds really bang. You've noticed I'm not a big 'color guy'. For the most part, If the colors don't zing, I don't want any. B&W floats my boat, more often than not. Thats the real trick, isnt it? A picture can be technically correct in all the way's we can find to define it, but if it doesn't 'make us think', its just another picture. Its one of the (many) things I'm stuggling with myself.
  14. I'm with Mario on this. If timing was actually changing by a full rotation, the car would run audibly different while idling. It would quit running in a short period. If you were looking for it... match-mark both rear pulley's. They are isolated from each other with vulcanized rubber. If separation has begun, it will show in the match-marks. If you find that this is the case, do not continue to run the engine until you sort it out. The temperatures powdercoating is normally done at strike me as incompatible with the isolation material.
  15. I've been had. I'm driving along and notice our town graveyard has a few bouquet's of flowers all nicely frosted over. Pulled in, snapped two quick shots to get a feel for framing. Look at the preview, zoom in and.... what the? LCD is showing a distinctively symmetric pattern... you know, kind of like synthetic. Take a better look at the 'flowers' and sure enough... fake I didn't bother to take any more. Outside of the humility, you gotta admit there's a certain irony in placing artificial flowers on a tombstone, eh?
  16. That little box is a great tuning and diagnostic tool. It can be used in series with the existing sensor or it can be used to *bypass* the sensor.
  17. That statement (as I cropped it) is technically true... *BUT*, If your car is running so rich that it needs this to be done then there is something wrong. You should be chasing your problem, not covering it up.
  18. Sweet Dan! I ran a tape on an L6 for comparison... Front of water pump pulley to bell house, 30" Top front of valve cover to CENTER of crank pulley, 17.5" Depending on the pulley, to the BOTTOM would be about 20.25" Top front of valve cover to bottom of pan, 25.25" So... L is nearly 6" shorter in overall height and roughly 2" shorter in overall length. Sounds like a tight fit.
  19. Go back an re-read Noodles posts. He's telling you how he went leaner. In a nutshell, If you provide less resistance than the water temp sensor normally would, your mixture will be leaner than it normally would. You do understand that there is risk in playing with this stuff, right?
  20. Touche. You know, that title of yours could be a LOT worse
  21. Sorry Woldson, I deleted your post. Lets let it go.
