Everything posted by John Scott
I've confirmed what's legit and what should go on the startup items. Hmm, since I've disabled, will they show in the run? Also only see >Software> not the variables >software> or >SOFTWARE> Only shows 3 or the 14 active startup items the System Configuration Utility. Hijack this gave me quite a log I need to look over.
I know we have a few gurus here. How does one delete, not just disable a startup item in sytem config? My wifes laptop was severly infected about 9 months ago. Everything has been running fine, scans all come back clean, but still see the items in the startup list.
We were at -18. Brrrrrrrr. Set a new record low. Mean Temperature -4 °F / -20 °C - Max Temperature 10 °F / -12 °C 43 °F / 6 °C 64 °F / 17 °C (1998) Min Temperature -18 °F / -27 °C 16 °F / -8 °C -18 °F / -27 °C (2006) miss the 100+ days of summer. ..naw! I know I knock the Saab, but have to say for the Saab and Volvo, great cold weather cars.
...now that you mention it...
I'd really like new heads, bigger cam, M/Ts, and a Cert. cage. I'll probably end up with a few text books, crabby relatives, and a fistfull of bills.
HybridZ vs contemporary cars: RE: How Fast, really?
John Scott replied to lesd's topic in Non Tech Board
12.2/ 115.5 at a 7800 foot Density Altitude. Absolute baro 24.01. You have to compare apples with apples, We all race on the hill up here, and envy even the lower tracks 'Bad" days. Our DAs get up to 10,000'+Most stock Z06s run in the low 13s, a few in the high 12s. The '07 should be one to look out for, though I think I'll still have it for lunch. he latest record for new DR stock Vette was 10.85 at a minus 850 feet DA (sheesh) converts to a low 12 on a "good" 7000' day at Bandimere -
I have a relatively mild build and haven't seen any Vipers of Vettes that pose a threat, highway roll ons, stoplight wars. At the drags, Local Z06 took a big shot of NX to beat me, and I was still at his rear tire at the end of the 1/4. Its unreal how bad you can beat up so many factory performance cars, Vipers, Vettes, GTOs, Mustangs. Sure they have more technology, refinement, safety. Its just so damn satisfying to blow one of the high dollar cars into the weeds. Pick your battles, check the width of your wallet, then build one accordingly. Of course they're out there, but uncommon to see a faster cars being daily driven. -
^^^ Do those go on the front or rear tires? Wednesday forecast: Chance of light snow. High 18F and low 6F. Winds N at 10 to 15 mph. Thursday the big heat wave: Sunny skies. High 26F and low 9F. Winds N at 5 to 10 mph.
Nuts? Heck no! The more like home the better. even a place for the kids to doodle. Hot Dawg Modine heater and four windows looking out the back yard. Bifold and trifold doors close it off from regular garage. Doubles as excercise room. My dedicated Z area isn't huge, but over 850 sq ft garage total. Beer fridge in the back, BBQ is just around the corner!
The carburEtor, with an E, is alive and well especially in numerous racing series. It takes a lot of tuning skill to be within a hundreth of a second of your competition, throughout changing conditions, all day long. Screwdriver? You have no idea what you are talking about. It takes way more expertise to intitially tune a carb than efi. and 99.9% have no idea how to do it. You can't just punch in a new value in the window and click a button. It takes a lot of dyno time and knowledge as to which emulsion hole, bleed, booster needs to be changed and by how much, what the effect will be on the other circuits. Pro set up will provide a fuel curve equal or better than efi. There's way more than just changing jets or adjusting a mixture screw. For most it will go from box to manifold, and for the price, a benefit you mention, typically works amazingly well. Yes efi is superior for adapting to a wide variety of conditions.
Don't buy into the magazine article, Chevy hipo, or whatever it was. They made a carb work, but far from getting the full benefits from the fuel, especially on peak hp numbers. You can't just swap to alcohol metering blocks (methanol) and expect it to work...not well anyway. AFR for e85 is not within the range of adjustment from methanol or gas hardware. Talk to these guys: http://aedperformance.com/ They are fast to respond to inquiries. They, and other carb guys are working on a specific e85 carbs.
1.72 60' at LACR in palmdale.. 11.44 @ 119.7 on motor 215/60/14 BFG drag radials.. Great times, 60' on 215s!
Cant get starter motor back on...
John Scott replied to Ansel Marrow's topic in Gen I & II Chevy V8 Tech Board
Drop the header on that side?? Depending on your finances, mini starters are nice for clearance. Good luck! -
Someone Hug Me..I'm Gonna Cry! Dropped a Dowel into Engine!
John Scott replied to slownrusty's topic in Nissan L6 Forum
That's too bad. I dropped a carburetor stud down an intake.. when it was running... beat up my valves and a piston. My wife has a nasal fiber endoscope, mini video camera at her disposal. I've tried, unseccessfully, to talk her into letting me borrow it for situations like this. What's wrong with the smell of 90wt oil? Hang in there! -
Man, thats flyin', great times! PG and FI? How much improvement? What were your old times?
Born from jets? yeah right!
Some guys are just luckier than others. I'd love to watch mine get dropped in a crusher. Saab story?? :D good one, Jon! Saab "engineer" to another: "look at all this room in front of the engine...hey I know! lets put the pullies, AC and alternator on the back (!) of the engine and then cram it against the firewall.." " But won’t that make rubber belts prone to failure impossible to change?” “You big weenie, Do I look like a mechanic?” ".OO, OO! and run lots of rubber lines under the manifold, and put the most neccessary bolts behind numerous brackets, and make the simple rear discs hard to replace by adding an adujster nut thingy. Here, have another shot of Slivovitz, har har!" Three speed automatic..in ‘91?? Born from Jets? What kind of jets were they building? Saab navigator to Saab pilot: “Dude, they’re gaining on us, hit the afterburner already.” Pilot says “I did, man, like five seconds ago. It’s a “JET” thing..called turbine lag.” “But that thing has a propellor...and two wings.. and its passing us. I think he threw some strudel in the intake.” "Oh, snap, we're going down, try the ignition,...now where's the friggen key again?" That's just the beginning of the madness. Nordic winters must be long.
More like from a bunch of whacked-out crack smoking idiots. I have never worked on a more poorly designed bunch of chaotic weirdness in my life. Finesse, simplicity, and efficiency must be the antithesis of Saab engineering. Avoid Saab 900 Turbos like the plague! There...I feel better.
2004 LS2 GTO.....OneFastCar!!!
John Scott replied to Danno74Z's topic in Gen III & IV Chevy V8Z Tech Board
4 speed M22 Judge, kind of a goldish color? I've met a few of the GTO guys at the Ft Collins Sonic meets in Loveland, Bandimere track days. They're a dedicated group of enthusiasts. BTW Congrats on having a new boss! -
Anyone running Weld Draglite wheels
John Scott replied to a topic in Brakes, Wheels, Suspension and Chassis
275s on a 7" rim? -
The GTOs are underated IMO. Great cars. Does he run it at Bandimere? There's a huge club following with the GTOs around here. -
Since the 300ZXT shafts are a desirable swap into early Zs, How do the length of the 300ZXT shafts compare? I assume they are the same length as non turbo shafts, but greater range of compression?
Are six bolt CVs, lets say from 86 non-turbo 300ZX, same as older 280 ZXT six bolt CVs? Probably answered in a post somewhere. Been digging for days and can't find answer.
Finally found a bunch of Datsun Zs, many with R200s, and the guy wants $200 for each rear! I think some guys just fall in love with their wrecks and don't really want to part with any of them. Good news later found another u-pull-it. 3.7:1 200 out of an 86 300ZX with Automatic. Price less than 1/2 complete. Looks in great condition.
