Check the basics:
Plug wires routed correctly and not arcing or in bad condition (LT1s are very sensitive to spark breakdown)
Make sure you have fuel pressure (invest in a pressure gauge that screws into the shraeder valve on the rail)
If the opti is going out, you will usually have a slight miss at idle and a hesitation under load...it should at least fire unless its completely bad)
Check for vacuum leaks. Make sure that all unused ports are plugged, esp. at the throttle body. Try unplugging the MAF, and let the PCM default to speed density. That way if you do have a leak somewhere the PCM can account for the extra air.
Tim
According to my local dealership tech., the engine to chassis grounds are very important. I even ran 2 extra ground wires from the intake (2 rear bolts) to the chassis.
Try that......
Drill out the spot welds and pull of the rails. Inspect and replace, or put in subframe connectors.....That rust in the pictures really doesn't look that bad at all.....
While I totally agree with the argument, and realistically this Bill is a good idea, and probably overdue, since I have a vested interest in keeping my 73 car(s) exempt, I am against it, as well as being against regulation in general....
Tim
Here is a summary of the Bill:
It should not effect vehicles that are already exempted, but rather stop any more vehicle years from falling into the exemption.
Full text: http://info.sen.ca.gov/pub/bill/asm/ab_2651-2700/ab_2683_cfa_20040524_183247_asm_floor.html
lol why are you on the net! you should be driving your Z!
i think you need to man up.
mike
ha ha LOL.....I have to get my daily dose of Mike's trials and tribulations....AKA "Comedy Hour"
