surpip
Everything posted by surpip
  1. hopefully you are doing well after the hurricane? mine should be out of paint soon I would love to come down and go out to a meet or something!
  2. Yes, thay are all compatable i have an extra one from my 78' no lock though, just the switch
  3. I would recommend a solid roller as opposed to the flat tappet easier break in and you don’t have to worry about high zinc oil. Plus you can get a more aggressive cam profile but no matter what you do don’t cheap out on parts, save up to get the stuff you want not what you can afford at the time.
  4. It would be a waste to destroke that 350 with a 327 crank, IMO I would go for a 383 you will love the low end Tq and even on a budget still get them to rev to 6500 without much effort. I wouldn’t go any less than the 350. Bore it .030 get a decent piston (JE, SRP) good rod and a lightweight crank and as long as your cam and vavetrain can handle it you’ll be turning up to 8000. As far as heads go it really depends on what you decide with your bottom end.
  5. The door will be fine to use, mine has been broken for years. As for fixing it I would find a new hinge off ebay or possibly in the classifieds.
  6. Has anyone had any luck with using stock components ie, evaporator expansion valve, with a Sandon compressor? I’m debating on where to go with my AC, whether or not I just need to buy a vintage air unit. I have the stock condenser as well
  7. When there are more parts of your interior inside your house than inside the car.
  8. Don’t forget to do a taste test on the battery too, should have a spicy/extreme burning taste to it. (Please don’t really do this or put any fluids on your tongue if you don’t have experience with it your just going to end up with a nasty taste in your mouth an still have no clue what the fluid was.)
  9. You probably have rust in your fuel filer take it off an tap it on the ground and see if anything comes out, if anything at all falls out replace it. You might have to do it several times before all the rust clears out of the tank.
  10. Could be your switch as well, you can wire a light in line with a + wire off the switch and see if it goes out driving down the road. Could be the module as well though, sometimes putting fresh dielectric grease on the mount surface will bring them back to life for a bit.
  11. I did a relocation in my S30 I have 0 gauge wire running up to the starter post and 0 for a ground wire connected to a bare metal rear bumper mount. I agree with previous posts, I think it’s a ground issue. If you wire brush to bare metal your Batt ground and add an additional block to frame ground strap you should be fine, make sure to spray it with that red stuff that comes in a yellow can (batt terminal protector). As for the spark, if the ignition is on and the motor cranks just a little bit you should be getting a spark. In the on and start pos the coil and P/U are getting power and should light off if the motor is cranked.
  12. I see a lot of sharp edges on that head, might not hurt to throw in some old valves an do some polishing work with the dremel...
  13. You might have some luck if you buy the shorty spark plugs form accell.
  14. When you can take your earwax out with a magnet (mostly slag)
  15. Ive taken gummed up carbs apart before and its taked alot more than a good solvent wash and some air to clean out the gunk from the jets. Unless you took out the jets and were able to look through them, i wouldent rule it out just yet, but you should have a better idea when you do the test.
  16. You may want to ask yourself how much power you want, how much money you have to dump into it and what you will be useing the car for. A SBC build if fairly straight foreward and simple, BBC and LS/LX swaps are a bit more complicated if your looking for decent power and a simple swap i would go for the SBC.
  17. surpip
    Cam toast?
    Kind of hard to tell by the pic but it looks fine to me if anything take it to a mashine shop if your iffy about it
  18. Try squirting a little carb cleaner into the brake booster vac line see if it gives it a little more punch when you try and start it, if it dose its fuel related ie: worng float leve,l clogged jets. if not its a spark issue ie: dirty/fouled plugs, wrong wireing, weak coil/intermitent P/U. good luck
  19. Some vids of my 1/4 mile for your enjoyment 12.66@112 12.59@111 Cant get a good 60 to save my life.
  20. That looks like an NRG steerging hub adapter.. did that fit for you? i had to drill mine out for it to fit right. Car looks great tho keep up the good work!
  21. Ive seen a couple FSU's on ebay so that might be another option you could look at. What's the name of the shop i might have one done as well, dose it use the stock filler port or is there one inside?
  22. And this dosent evan cover half the stuff you whant to buy.
  23. I was under the impression that Helmholtz pipes were used for more fine "tuneing" on the exchaust note, because ive seen cars with those pipes still have a resonator.
  24. Could be just a weak lifter, never tryed this on a P90 head but on some hydro lifters you can push down on them an they will feel weak (not like the rest). I would recomend you take the valve cover off an see if they all feel the same.
