Alright, well the engine is out of the 81 turbo and is on an engine stand being cleaned up. Ill hopefully get the oil pan, motor mount brackets and valve cover sandblasted and repainted tomorrow. My goal is to get the engine mounted in the car this week...
Also, I decided to take the plung on megasquirt. I will be following twoeightythreez's guide for installing megasquirt using the stock harness.
http://forums.hybridz.org/index.php?showtopic=48292
I have tried to contact the poster to get more info on all the parts needed, rather what he used but he hasnt got back to me yet.
Anyways heres the list Ive come up with...
MSII- Trying to decide If ill get it assembled or not. Either way Ill either need to tell them or do it myself to have it set up to run the coil directly.
http://www.diyautotune.com/catalog/bosch-bip373-coil-driver-mod-kit-p-230.html
Ill have to see if when you order it there able to install this for you, assuming I buy the assembled one.
Wiring harness: http://www.diyautotu...ready-p-43.html But get the short version in order to have the plug because Ill be using the stock wiring harness.
82 Distributor- Since MS will be directly controlling the coil will this work? Turbo or NA?
IAT sensor- Any GM sensor
240sx TPS
coolant temp sensor- Any GM sensor
wideband- LC1 sensor? Now I will only need the sensor itself since I will be able to read out my AFR on the laptop?
Thanks for the help guys. Ive been doing alot of reading.. alot of info to absorb.
Thanks!
tuning cable http://www.diyautotu...-thru-p-35.html
