ok guys the dizzy was bad so I went to the junkyard and got the inner part of a dizzy from some nissan so now the dizzy is working when i spin it by hand but still no spark when I crank the engine. what can be the problem?
have been messing with the dizzy and now I don't have any spark from dizzy. When I try to turn it by hand it does not give any RPM output I think the dizzy went bad.
ok I just did that an I get 1.35volts thats with the (+) on tach terminal and (-) on ground on relay board with the multimeter. If I spin the dizzy with the hand and pull the plug wires I get spark but I don't think thats enough(weak spark) cause when I bolt up the dizzy again and try to start the engine there is no spark and the realtime RPM display does not show any rpm's I think the injectors are firing because I smell gas in the exhaust and the spark plugs smell like gas but they are not wet.
Could it be that I'm using the old stock 240z coil, but new 280zxt plugs and wires
inland empire southern california RIALTO.
Well I passed they just asked me about 10 questions write a sentence in english and that was it. Now time to wait to get my letter for the OATH ceremony. wooooooooooo whoooooooooooo
I think so. I enjoy US history and politics so it shoudn't be a problem and understanding the english language writing and speaking it. I attended school in california k1-12grade so thats not a problem. Random USA civics questions
Here the deal I have no spark an no fuel going thru the injectors
stock 81 l28et
83 turbo dizzy
and everything else wiring etc.is from the 240z.
MS1 v3 board with relay board wire for direct coil
(-) of coil to the S5 on relay
(+) of coil on fuel pump relay and fuel pump 12v.
I have the stock 83 dizzy
black-ground
green- to tach on relay also resistor wired to 12v switched
black with white stripe- (+) side of coil
also which is the fuel return line on the stock fuel rail? I have the returned line connected to the bottom line on the fuel rail that goes to the fuel regulator.
Im using mobys numbers for start up
I downloaded MS1 Extra 029y4
Also were do I look for audit log files.
I have looked on everysingle file on megasquirt in my computer but cant seem to find it.
thanks
any help would be really appreciated.
I have read most of the post on this site but I cant seem to get it running I have pictures and zip file
240zturbo2.zip
Here are some pictures I need to buy some custom oil lines since the front tire is getting really close to the OEM oil line and they are really hard to bend to make more room.
I made a 2.5" downpipe waiting on transition for 3 exhaust.
So I finally order some parts for the z they should be here by the end of the week. 2 90* mandrel bends $13 and a 2.5 to 3" transition and brackets. megasquirt wire bundle, and relay board with cable for megasquirt. I can't wait to have this thing finished........
It's a 1999 Chevy S10 4x4 automatic transmission. This past week it started acting up. Traveling around 70mph around 2000rpms if I try to go any faster the RPMs will go up 200rpm's and then back down while pressing the accelerator. Like if the overdrive was going IN and out.
What could be the problem? bad solenoids?
