jeffer949
    9
Everything posted by jeffer949
  1. ya i saw that also. kinda looks like its a spark plug wire arcing to ground. which isnt good
  2. why not ask the guy for the part number and then go to the kaaz website? and see which one it is?
  3. Thanks KTM. I tune my motor for 11.5:1 to 11.8:1 under high boost. I just havent done my research as far as meth goes yet. I need to since im going to be putting a HY35W on this week.
  4. Oh and please tell me you where data logging during those runs!
  5. If you look at your afr's they are starting to get richer and richer and richer at 4500 and hence your power is decreasing. so you might want to do some more tunning and it looks like you need to back your fuel off some. but then again i guess that could be your meth. kicking in. and im not sure how your supposed to have it tuned for when that kicks in.l
  6. i have a turbo ill sell ya stock t3. make me an offer
  7. thats a good way to go but honestly its over kill for derek. he is staying NA. i do think i should walk you through the 240sx swap. its a piece of cake for someone like you. start looking for a good quality 240sx transmission. if you have an extra bellhousing laying around we can do the swap in an afternoon. well i guess you will need to have another drive shaft ready that has been shortened ready also. but we can do it real easy like. lol hit me up sometime if your interested
  8. i think you are supposed to have them honed so they have a better fit. i would try to heat it up some with a heat gun and then put it on so its on tighter. makes it less likely to come off or to wobble. the bhj dampers have it in there install instructions to have to hone the damper so you get a tighter fit.
  9. lol i have no clue. i just got the job yesterday and havent started yet because my dad is mailing me my social card.
  10. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=270221306530&ssPageName=STRK:MEWA:IT&ih=017 i just ordered this intercooler on ebay. It is the same size as the one suggested earlier but it is 3.5 inches thick instead of 3inches thick. i think it works out to be like 36inches bigger than the 3 inch one. should work nicely with my new hy35w that should get here next week also
  11. yeah i have noticed alot of peoples are off. guess im lucky that mine is on.. but i do have to replace my hinge pin.. wish me luck on getting it straight again righ?? and nice video. i wish my car was that clean
  12. have you even thought about the search button??
  13. i just got a part time job at block buster so ill have more money for my car lol. so ill get to watch all the movies i want!!!! which is good because i tend to dl alot of them. oh and a movie that blew me away recently was "The Last King of Scotland" absolutely amazing
  14. ok i have this turbo on my engine as we speak. I have the HX30W and i was running 19psi through it and it felt slower than my stock t3 did at 13ish psi. when i swapped out my t3 for the holset hx30w at the same psi(13) i had to decrease fuel on my VE table in megasquirt. so this means it flows less air. so just some real world experience. i did blow it up the first weekend i ran it(it was in poor shape before i put it on) but even if i didnt i would be looking for a different turbo. i have an 05 hy35w on its way and im sure that will make my power goals a reality
  15. http://motors.shop.ebay.com/_Car-Truck-Parts-Accessories__280z-cold-air_W0QQ_nkwZ280zQ20coldQ20airQQ_fxdZ1QQ_ptasZ1 or make your own
  16. Hey guys i was looking at getting this dampner also and i can see spending the 80 bucks on it but what i cant see is spending the 40 bucks for the bolt and washer. Is it really needed and if so why?
  17. You have a r200 in there already correct?? If so just take the cover off of the current r200 and put it on your lsd and then put it in. Not sure what half-shafts you have though but ive seen your work im sure you can figure it out
  18. ebay has license plates from japan
  19. I would be safety wiring all the pressure plate bolts together. At least do 3 groups or 3. best way is to torque all your bolts down and then break out the punch and drill and drill a whole though the outer left corner of the bolt. and then take a long piece of safety wire and make a loop through the first one and then take some safety wire pliers and spin it to the next bolt and lace it through that one and then keep going to the next one. Then your done!! or use this method to drill the heads of your bolts http://www.ekartingnews.com/NewToKarting/safetywire.html
  20. im currently running my clsd with just the stock r200 diff cover till i get a different bar for my rear end to clear it.
  21. He has pallnets upgraded studs. i walked gabe through the helicoil this morning on msn messenger. If his gasket isnt blown out completely he might be able to drill and tap the hole for a helicoil with out taking the manifold off which would be a plus!!!
  22. i wanna try and go to the drag strip here coming up in the next week or so. once i get my hy35w should be fun. ill see if some other people wanna come.. ill pm ya
  23. can you get it off?? try taking a chisel and put it underneath the nut and pry on it while your turning the nut with a ratchet.
  24. hey veritech-z your in orlando? we should get together some time
  25. congrats on the promotion. im about an hour away from there lets be sure to meet up!! be glad to meet ya!!
