jeffer949
    9
Everything posted by jeffer949
  1. I dont think you can rest a 280z ecu I dont believe it has any memory in it.
  2. Does it go to the floor and then you have brakes at the very very bottom of the stroke?? If so your reaction disk came out in your brake booster. Probably happened if/when you where pumping your brakes up after you put the calipers back on the struts.
  3. Sounds like you have a bad oil ring and oil is getting into your cylinder. Id start with a compression check and go from there
  4. thanks for measuring 280ZFORCE puts my mind to ease. ill order up a flange and clamp today
  5. I have to say you are no where near done spending money on turbo stuff. because you see you are about to get a tast of boost, which is addicting and your gonna want more boost than what that tiny little t3 can produce.. thats the phase im in right now UPGRADE PHASE!!!!
  6. i say vacume bag carbon onto the board but have a release film on it so you just have a pure carbon lip
  7. I know. Thats why i said carrier also. Unbolt the whole electric sending unit. Take it out and throw it away or what ever you want to do with it. Take your Z's speedo carrier and cog with the appropriate cog in it and stick it in the hole! you might have to cut a new retaining slot in the carrier that is 180deg. from the original slot. This is because the sx tranny has the retaining bolt 180deg. from where it is on the z tranny.
  8. Why not go dry sump and kill 2 birds with one stone? One you would get rid of the problem of it being a front sump. and 2 it would cut the height down and possibly make it work with a stock hook.
  9. you can get the z transmission speedo cog and carrier to be in the sx tranny. and then it will work fine.
  10. Hrmmm i start working at blockbuster next week in the evening. hrmm hopefully i dont have this happen in front of my store.
  11. Just saw this on ebay. Someone might want to jump in this. Its an amazing deal! i just paid 350 for mine with 45k on it. I would get it if i hadnt just bought mine. http://cgi.ebay.com/ebaymotors/NEW-HOLSET-HE351-Turbo-Dodge-Ford-Thunderbird-SVO-tbird_W0QQcmdZViewItemQQcategoryZ33742QQihZ001QQitemZ110239059891QQrdZ1QQsspagenameZWDVW
  12. Wasnt planning on running a external. at least not for now. I had the wastegate bored out from 22mm to 29mm and the puck is 32mm. It seems to work for bigphil so far. My only problem with running the 4inch v-band is when i look on this site.http://www.siliconeintakes.com/product_info.php?cPath=10&products_id=326&osCsid=cc2d99e2473d7fc21158195539113a6d it says that the outer diamater of the flange is 4.09" thats like a .4" difference. isnt that to much??
  13. Yeah the whale tail is the way to go. the old spoiler kinda looks like an after thought. Where the new one actually flows with the body line. and keeps the sleekness of it consistant
  14. Well as some of you know i bought a Holset HE351CW off of a 05 dodge. Now it did not come with the exhaust elbow or v-band clamp. Now i wouldnt think this would be a big deal but i cant figure out what size i need. Im posting some pics of it with a tape measure measuring the outlet and then just a picture of my ported wastegate. Any info you could give me would be great. I know some of you say to use a 4" v-band clamp but i dont see how that would work since it is closer to 4.5"
  15. i didnt use spacers on my bolts when i did my swap into a 3.54 out of a 82zxt its been in my car for a month or so now and been down the track probably 10 times and still no issues.
  16. t3- 2" zxt afm-3.2 in and out. and stock tb fits fine with a 2.25 silicone coupler just fine. and no you can not shrink 2.25 silicone coupler to 2inches lol and yeah go ahead and lube up all your intercooler piping.. you will have fun blowing your intercooler piping all the time.
  17. A little on a side note but what do you think of this intercooler.http://cgi.ebay.com/ebaymotors/TURBO-INTERCOOLER-18x6x3-5-DSM-ECLIPSE-TALON-7MGTE_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ33742QQihZ015QQitemZ250230745867QQtcZphoto Same size with somewhat similar end tanks. Would it benefit from having the divider welded into place? If you would be interested in some more measurements I will be be getting this on Tuesday.
  18. try setting up your tps. When you have megatune open. click on tools and then click on calibrate tps. Then with your throttle closed click the get current. on the closed setting. next hold your throttle wide open click the get current on the wot setting.
  19. Glad to hear that they are standing behind the work. Its always worrisome taking back something like that and asking them to fix it. Then not knowing if they will stand behind the work.
  20. Im going to be doing this in the next half a year. and Im dreading it kinda cause my arches are completely original and in perfect shape but still i love the look of ZG's
