50
Everything posted by Derek
Twin cam head for the L6 from Derek at Datsunworks
Derek replied to Derek's topic in Nissan L6 Forum
Pretty much everything. Think of it as the ultimate Vtec killer. I still have things to work out with the cam towers and oil flow. Technically the cam gears would be in the back of the motor if all things were equal to the K20. Since I'm having custom cams made this won't be an issue. Of course since it's custom anything is possible:) -
Yea if I was doing this for a customer I would tell them to budget for four heads. One for the foundry to get right. One for the machinist and one for the unknown. If your lucky you might hit on #3. There is a lot of good and bad in the 3D printing field. I just wish they hadn't settled on mesh as the modeling standard. I can be quite cavalier when I'm modeling for CAM. who cares about gaps as long as the smallest ball mill won't drop into it. -
You can also just use all exhaust rockers as they aren't Vtech. As far as machining goes there is one point that may be vexing for people (me) who have never machined a raw head casting. Getting the tops of the valves to line up with the rockers. I modeled in a cam tower and two rocker arms. The models are based on high res scans so they are accurate. I based the location of the tops of the valves from one of the heads I purchased. As you can see in this screen grab there isn't a lot of room for error as far as the angle of attack of the rocker to the valve top. This has been my biggest worry. I imagine you only get one chance to get the angles right on drilling the valve guide bores. I'm not totally sure if the head casting is any good or not. Castings shrink as they cool and you factor that into the design. The problem is at the level I work at it's guesswork. The more cores a casting has the harder it is to predict the shrink rate because the hard sand reduces the shrink. So the reality is the casting may be too long or too short. It may also fail when I have it X-rayed. If the casting is junk then I have 12 tries to determine the right angle. If the casting is good then I'll probably machine a plastic test head that matches the actual casting and practice on that. If anyone has any experience on this kind of valve work I'd love to hear from you:) -
Hi I wasn't. I was merely using it as an example of the high end of things. Not the market I'm going after. This project is as much about proof of concept as anything else. Patternless casting has arrived. It seems expensive, but for this type of project it's ideal. I'm not the only one doing this. Ford racing bought a few of the 3D sand printers and are using them in their head development. There is a guy reproducing Ferrari heads that are NLA, and I'm sure there are more. I do a lot of motorsports work. This head will open up some of my clients eyes even further as to the possibilities. I'm doing this head for the Z because it interests me. And I have a car to put it in! I mentioned in the post that the nissan and 3000 were going to be machined in. The actual castings will be blank. -
Love it. I think I want my member name changed from "That Horny Z Guy" to "That Derek Fellow" -
Cheap as compared to the OS Giken:) I think that comes in around $40,000.00. -
All Honda. At least the intake inlet and the exhaust outlet. What happens in between is my design. I could but in reality it's a Vtech killer. I suppose if someone was inclined they could make it a Vtech but that is a hill I'm not climbing! No problem prodding! I'm going with custom Crower cams. This is not as big a deal as is it used to be. Thank you technology:) Here is the really neat thing about 3D sand printing. If you want intake on the left and exhaust on the right all I need to do is 3 mouse clicks and the entire mold package is mirrored. Sometimes cost goes beyond the price of the components. The RB has cam saddles that are part of the head. This requires line boring. The K20 has bolt on cam towers. This reduced the cost of machining greatly. That was the tipping point for me. I don't own a line boring machine:) -
Hey I just noticed that I failed to mention that ALL of the foundry sand for the mold was 3D printed. not just the cores. There are no patterns except for some exterior gating pieces. This is pretty cutting edge stuff. I've been woking with the process for a few years now and it's really amazing. Any changes I need to make to V2 are done digitally which is nice. -
Thanks. The intake will be custom and will be flanged to accommodate the DOCE pattern. I think the port spacing on the DOCE pattern will work so I can use 6 individual Jenvy ITBs. My plan for the exhaust is a little more convoluted. L6 block on engine stand, Mount P90 on block, bolt on header and fixture it to the side of the block. Remove header and p90. Saw flange off of header. Mount new head on block and return header to fixture. Manipulate tubes with heat and fabrication to match new flange and weld. This build really is about how cheap. Although the Jenvy ITBs are a luxury, I still want them! I could go with OBX stuff and may have to if I bust the budget. -
Hi Ray. Since I'm using the Honda K20 valves and valve train I felt it was best to stay as close to their design as possible. We decided against the RB as a donor because the K20 just had so much stuff easily available. This build is going to be the budget build. I bought 2 K20A3 heads used. That will give me enough parts to do one head plus some spares. Since I'm not using the Vtech option I needed 4 additional exhaust rockers. Derek -
Well you know..Idle hands. I'm finally going to use the .040 motor I bought from Tom. It's going to be the mule for this head. -
This is all Tony D’s fault:) Hi everyone. Some of you know me from my DIY EFI manifold project http://forums.hybridz.org/topic/63445-making-my-own-efi-intake-the-first-casting/ Well now I’m tackling a DOHC head. Some history: I get a PM from Tony D in September of 2012 about the Goerz-Paeco DOHC L6 Head coming up for air.http://forums.hybridz.org/index.php/topic/109116-dohc-l6-was-somebody-looking-for-the-goerz-paeco-dohc-l6-head/?&gopid=1020596 Which led to a brief discussion about what would be involved in producing a head. And that was the end of it... Or so you thought. Tony and I started trading emails about the feasibility of producing it and what kind of heads we could use as a donor for the valve train. Tony suggested bringing Jeff P on board because of his work with cooling the L6 head. Tony and I kicked around RB and KA motors for a while and then Tony suggested checking out the Honda K20. Bingo. Removable cam towers, factory roller rockers and a plethora of aftermarket parts. I called one oh my clients that is big in the import drag market and procured an old K20 head. I did some quick measurements and decided that it was probably workable. And so the journey began. The idea is to use the cam towers and valve train from a K20. I grabbed a quick scan with my white light scanner of the exterior. It’s dirty because I’m only using it as a reference scan to design against. I imported the scan into my solids program and then proceed to replace the mesh with solids. Jeff provided me with a great CAD drawing of his head gasket to work from. I decided to take a module approach to model the head. I made a single cylinder complete and the copied and offset it for the other cylinders. I then pulled the solids together to create a single model. At this point I was at a standstill until I could figure out what to do about the timing chain. Jeff and I had a long conversation about pros an cons of various designs. The preference would be a single chain so I ordered up a K20 set to see if it was workable. NOPE. Lower timing gear is too small to bore out to fit the L6 crank. Back to the drawing board. I decided to give the KA set a try. I decided the Altima set would be a good choice as it’s only a single row chain up top. With the roller rockers I don’t think you need a double row. I did a rough mockup on a piece of wood mounting all the pieces. Then I machined a chunk of plastic so I could actually mount it to the block. You can see I’m trying to incorporate the KA guides and lower tensioner but that won’t happen without a new lower timing cover. Here is the lower section with stock modified L6 components. The only tricky bit is I need to remove one link from the chain. I think this is a workable solution. Now I could finish modeling the front and back of the head. Next the front timing cover. The water outlet exits the head in the front and makes a 90 degree turn through the timing cover where the thermostat housing will mount. Now the valve cover. The K20 cam towers kind of dictated the overall size but I was still able to get the styling I was looking for. I was trying to have the flavor of the S20. I’m still tweaking the design but so far I’m pretty happy. The “NISSAN” and “3000” will be machined in so they are kind of placeholders for now. After talking with Jeff about his testing on coolant flow I decided to get the most out of the 3D sand printing process as I could. I designed a water jacket that would be pretty hard to duplicate traditionally. There is a lot of surface area so hopefully there will be large improvements in cooling. Here is a nice shot of the intake and exhaust cores, water core, and upper tensioner. You can see where the cross drilling will go to supply oil to the head, tensioner and idler gear lube. There will have to be additional oil supplied to the last three cam towers as the single feed in the front won’t cut it. Here is a cross section of the head. The cut plane is through the center of one of the intake valves so the ports look a bit off. There is machine allowance on the bottom so the combustion chamber is a little larger than it will be after surfacing. Well like I said in the original Goerz-Paeco post I think this is a very viable approach to producing DOHC head. Should make for an interesting conversation. Derek Oh and one more thing. What good would a thread about casting a head be without....... / / / / / / / / / / / / / / / / / / / An actual casting. We poured this Monday and I just got these pics from the foundry today. I haven't seen the head personally but we're pretty sure it is good enough to move forward with. Still lots to do but you can't imagine how happy I am to get the first one right. As long as things proceed as planned I will be selling these. There is still a lot to figure out. I have the foundry working up some pricing for me and I'll post that as soon as I can. Thanks for looking Derek EDIT: I now have a blog about this head on my site. I'm going to continue to post here but the blog is a condensed version of what you see here. There is a FAQ on the left side bar that has a lot of data. If you are new to this build you may want to come up to speed there and then start following it here as there is a lot of great back and forth that isn't on the blog. http://www.datsunworks.com/Blog/
DOHC L6, Was somebody looking for the Goerz-Paeco DOHC L6 Head ?
Derek replied to Vintageracecar's topic in Nissan L6 Forum
Listen I'll be the first to admit this is still and will probably be a pipe dream. But as technology advanced things that were previously absurd become feasible. The only way i would consider getting involved in this is if it used off the shelf components. That just makes sense. Also keep in mind what I'm pushing is being done right now by ford, chevy etcetera. This is how they are prototyping their stuff. When ever I quote out manifold or head work this is how I propose it. By printing the cores you can keep tweaking things until you get it the way you want it. Then after you have a workable design in both performance and cast ability you commit to traditional core boxes for production. By 3D sand printing the cores the combustion chamber and ports can be tailored to each head. As long as it fits inside the outer shell your good to go. The thing I like about this design is it looks right for the car. So if you can design an exterior patten that looks period correct and custom print the internals what's not to like! Derek -
Maybe because I'm a pattern maker the casting seems to be the least of the problems. Cams,timing chain and gears, lifters etc are all going to be harder to come up with. Also people qualified to bring a raw head casting to a finished product probably aren't looking for any hobby projects. And thanks to Tony instead of concentrating on the bid I should be working on i've given the casting approach some more thought. And I really think this is feasible. Acquire a copy of the prints. Develop the 3D model. Carve a traditional cope and drag pattern for air set sand for the exterior of the head. This will cut down enormously on the cost of the 3D printed sand and shipping. Have the water cores and air passage cores 3D printed. The benefits to printing the cores are huge. first and foremost your not constrained by the limitations of a traditional core box. Since each core is printed separately any changes are just a matter of redrawing the model. Also because it's a continuous 3D print there are no part lines and the sand is super smooth. To put this into perspective I would design the intake, exhaust and combustion chamber as one continuous chunk of sand. The finish and precision of this method can only be matched by investment casting. Also this gives you tons of freedom to individually design each heads internals. Here is a shot of a sample of some sand I had printed. I was doing some restoration work for the King Lunalilo Tomb in Hawaii and was curious how the sand would look. I sent them a STL file of the crown scan and they printed this. I was really blown away by the detail it picked up. So you can see the possibilities for this. First step get the prints. Second step find a machinist. Preferably one that want's a twin cam L6 head Third step source cams and assorted hardware. Fourth step develop 3D model for casting. (me) Fifth step have machining model and prints developed from casting model with proper tolerances and such. Step six patterns and castings (me) Step seven Machine castings So fill in all the steps except for four and six and this could happen. There's makers and takers in a deal like this. Makers donate labor takers donate cash. Derek -
I finally got this crap out of my head and you had to wave this in front of me Yes a copy of the prints are a good starting point. Often times though the prints are way off from the final castings. I do a lot of parts for a kit helicopter based on an old Sikorsky. The prints I get are from the 50's and were hand drawn by the the draftsman at sikorsky. Most times if I build to the prints he part wont fit. If I work from an original part it fit's every time. If someone came to me with this project this is how I would do it. 3D scan the original with my structured light scanner. Develop a solid model based on the exterior scan. Design the water core, intake, and exhaust system based on observation of the original casting and print. Make any changes to the design deemed necessary for use in modern machining and usage. Rig the model with the necessary gating, core prints risers etc. Have the sand mold and cores 3D printed at exone in texas. Ship the printed sand to the foundry and pour. Hope like hell your gating is right and you get a good pour as you only get one chance. Bask in the glory that technology can afford. Then fap Derek -
Hi Yes I do and I have them in stock 100.00 plus 5.00 shipping. PM me your paypal address if you want a set. Derek
I bought my paint from SPI. I heard about them on one of the hot rod boards and people were very positive about the quality. They have a basic red that was pretty reasonable.
I used panel adhesive on all my rust repair panels and haven't had a problem. Expensive but worth every penny. Derek
32 years for me. Bought it in 1980. At the time I had a 1968 Firebird and a 1970 Maverick. The 240 then replaced the Maverick that was my daily driver. And now after all these years the Z is my daily again. Funny how things work out like that! Here's a shot of the Firebird. This was probably in 1979. Derek
Bill Coffey and his fenders. Which Fenders?!
Derek replied to proxlamus©'s topic in Body Kits & Paint
Hey I can see my car from here! The red one with the hood up. I called bill. They're from Reaction Research I'm sure if you call them and say I want bills fenders he'll probably know which ones. Derek -
Truth or heresay? OS Giken to finally reproduce the TC24-B1 head
Derek replied to MazterDizazter's topic in Nissan L6 Forum
Well since we're talking castings, patterns and production I feel qualified to weigh in on this one. I usually agree with Tony on stuff as he seems to have a firm handle on this kind of thing. This time he has a death grip. bringing a head like this into production is incredibly costly. The last head pattern I bid on was hitting $25,000.00 and they had all the 3D modeling done. Anything over $200.00 and your market dies right off with most Z owners. At least in the kind of numbers you need to get to justify bringing an item into production. The only thing I've made that has paid off the development costs are the speaker panels I sell. That's why I have to want what ever it is I'm developing. I seriously have well over $25,000.00 in R&D and production on my manifold. When I finally came up with a price on them ( I think it was around $3500.00) I didn't get a single nibble. Which is ok because I did it to get the attention of future pattern customers. And it has more than paid off for that. Now having said that I'm working with a product that is going to change everything. Seriously. I've been too lazy to post about this but this is probably a good time. There is a company in Texas that has equipment that 3D prints bonded foundry sand right from a 3D model. I'm currently working on a few projects with it and it's AMAZING. No patterns. Although this will make me irrelevant in some jobs I'm learning and using the technology so I don't get run over by it. Here is a link to the web site. printed sand It's expensive and you only get one shot with the sand but it's still way cheaper than doing patterns.And you're not tied to a design. I'll be putting together a separate post in a few days with my thoughts on this stuff and a few pics and how I think it's going to change everything. OK I admit it I'm a fan boi but it's just so freaking cool. I never would have done patterns for my manifold I just would have printed the sand and poured it. Derek -
Hi Bill Looks great! I think just about everyone (including me) found it easier to cut the tops off. Derek
Personally I don't care for the look. Plus since it's mostly popular with the younger crowd it's done on a shoe string budget. As a fabricator I always enjoy looking at good fab work but that's not always the case. It's more like how fast and cheap can I get this done because I have to drive it to work on Monday style of fabrication. My gut feeling is they would be more comfortable on a site that is dedicated to stance type cars. I can take nuggets of knowledge from any forum on Hybridz and apply it to my car. I'm not sure what I would apply from a stance topic. Just hold fast to the "no texting" style of posting and any problem child will just fade away Derek Get off my yard you punks (said in my best geezer impression)
Best Adhesive or Tape To Stick Body Molding To The Car's Body?
Derek replied to slownrusty's topic in Body Kits & Paint
That's the stuff. Great work on your car. Looks awesome. Derek -
The 3M grey acrylic double stick tape is the stuff. It's a little pricy but well worth it. Make sure you get it right the first time because there is no repositioning! Derek
