Derek
    53
Everything posted by Derek
  1. Thanks for the order. Glad you like them. Derek
  2. Hi Carl This may sound a bit crude but I just built a porch on my house and used a foam sandwich material for the roof panels. It's 3" thick foam with 2 sheets of powdercoated aluminum bonded to them. They come in 4' wide and 2' wide and have an interlocking edge. The stuff is really tough and very reasonably priced. You order it cut to length. It's the same stuff they make walk in cooler with. This would be good for the sides but not the floor. Just a thought. Derek
  3. It looks to me like the front manifold is bent outward. Is the level sitting flat against the back two? If that's the case I would adjust the casting a bit. If you go that path I can give you a few pointers about working with cast aluminum. Derek
  4. Derek
    iPhone layout
    Looks good. Is there a "view new content" link? That would help. Jeff if you scroll down to the bottom of the browser on the left side is a drop down. Switch it to lo-fi and try that. Derek
  5. That has to be it. I wondered why the asbestos hype but that makes sense. You see. Proof that all of the collective wisdom is right here on HybridZ. You get a cookie Derek
  6. I know some of you guys buy from Mcmaster. I got my new catolog in the mail today. They're pretty tough to get so there used to be a market on ebay for them. I thought I would see if they were selling. Then I stumbled upon this http://cgi.ebay.com/McMaster-Carr-Supply-Catalog-70-1964-ASBESTOS_W0QQitemZ190370575283QQcmdZViewItemQQptZUS_Texbook_Education?hash=item2c52f873b3 And that's not the only one that sold in that range. I'm speechless. Derek
  7. Hi Daniel How did you determine your lag. By looking at the data log? I sometimes think tuning this thing has been harder than building it! Thanks Derek
  8. I tried it out yesterday and was quite impressed. It's under a tab called "VE Analyze Live". There doesn't seem to be a manual yet but it's pretty intuitive. I was running a little rich at idle. I reset my AFR table and turned on auto tune. Slowly but surely it dialed it right in to the AFR I requested. No fuss no muss. Derek
  9. Nice work! That's also the same color my 73 was. The paint scheme has nice a 70's feel about it. Me likee Derek
  10. Happy birthday!!!!! 10 years ago I was 40....Has anyone seen my walker? Derek
  11. funny but the narration needs punching up. Think Dan Dykroyd and the Basomatic http://www.youtube.com/watch?v=4iYI_43UpZc
  12. Looks good. Don't put a center bar in if you can help it, like the evolution has. If you move up to a pedal set with a clutch the center bar is a pain. That' whay I set mine up as a hoop. Derek
  13. Thanks. The pedal box was a big improvement. I set everything up like it was the 240 so it's comfortable to me. Derek
  14. Here's what I came up with using one of my old seats. I pulled the pedals out of the G25 and hung them. Made a big difference. Derek
  15. Kind of sorta maybe. If I can get three firm orders from reputable forum members (that leaves you out) then I'll start the next private conversation with those three as to how to make it happen and the time frames involved. Well considering I own Datsunworks.com I'm imagining that will be on there somewhere! Until nissan sends me the cease and desist order that is. Then they'll really be collectible. Shoot me a pm and we can set up a time to talk.
  16. Thanks. Boy you got that right! The castings are just a minor part of everything it takes to make these run. There is a huge amount of machining and fitting that has to happen. I put the pricing up because people were asking. Even if I get firm orders for three that won't cover the expense of updating the patterns for production. Realistically no one is falling over themselves to buy a set. Derek
  17. I've had a Sycrowave 250 for about 15 years now. It's a great machine for SS and aluminum. I wouldn't go much lower than a 250 if aluminum is in your future. A 180 will be like trying to drive 10 penny nails with a tack hammer. you'll get there but it takes some time! Derek
  18. Is this what your looking for http://forums.hybridz.org/showthread.php?t=149652&highlight=led
  19. Yes I am a capitalist pig! Thanks for all the kind words guys. I think the pricing is pretty fair but the proof will be in the puddin. Right now i don't plan to sell any of the parts separately out of the groups. Derek
  20. I've posted some theoretical pricing here: http://forums.hybridz.org/showthread.php?p=1109515#post1109515 Thanks Derek
  21. Well I guess the time has come to put some pricing up for my EFI manifold. http://forums.hybridz.org/showthread.php?t=129941 This still doesn't mean I'm going to produce them. I know that sounds snarky but I figure this will separate the wheat from the chaff. I can then decide what I'm going to do from there. The first thing to remember is they aren't cheap. You can absolutely buy less expensive ITB setups. There is a ton of hand work producing these. The only reason to justify spending the money is for the looks. And to me they're worth every penny! Ok lots of pennies. I've broken it into three pieces. Manifolds, linkages and fuel delivery. Manifolds including throttle shafts and butterflies $2100.00 Linkage including 6 arms and 5 links with rod ends. $385.00 Fuel delivery. Injector hold downs. Stainless lines and distribution block $750.00 I don't have pricing worked up yet on the vacuum log. As with everything these prices are subject to change. If I do decide to produce I'll only take orders for 3 and then revisit the pricing. Thanks Derek
  22. Hopefully you figured it out. The bracket is slotted and pivots on the 8MM bolt. This allows you to set the air gap. Derek
  23. If you set up your edis wheel like this illustration the timing will be very close. If it isn't then the problem is in how you have Megasquirt set up. The key-way which lines up with the damper bolts is at the 12 o'clock position and notice the relationship between the missing tooth and the sensor. You can mount the wheel backwards and this would throw things out of whack. I can't rember. are you using a laser cut wheel or did I modify an ford wheel for you. Derek
  24. Well it's working on mine but that probably doesn't count! Does the COP use the ford edis control box or just the sensor? If it doesn't and you have the edis wheel set up like the picture in my instructions http://forums.hybridz.org/showthread.php?t=153367 then the problem is in the Megasquirt. If it does use the EDIS brain then it sould run in limp mode with the Megasquirt disconnected. Derek
