        Pop N Wood
                Posts3012
                Days Won5
	A very odd quest I had no idea where to post??Pop N Wood replied to 1FASTKINGCAB's topic in 6 Cylinder Z Forums I have no idea what your question is.
	Oil Filter Bypass block-off???Pop N Wood replied to Zerrari GTO's topic in Gen I & II Chevy V8 Tech Board I am not sure how much good this mod is going to do you since most spin on oil filters contain an internal bypass anyway http://minimopar.knizefamily.net/oilfilterstudy.html#m1-301
	Nice work. You really put a lot of custom effort into that crossmember I had an F body alternator bracket that had been machined to work with the Corvette accessories I would have sold you for cheap. I couldn't use it cause my engine sat so low the alternator hit the steering gear.
	Having the clutch not fully disengage can cause such a problem. What all have you changed since the trans last worked right? Is it all stock stuff, or an aftermarket clutch? What type of transmission fluid are you running and when was the last time you changed it? Does it make a difference if the car/trans is fully warmed up or cold?
	What is your Top Speed. On or Off Track.Pop N Wood replied to v80z's topic in Gen I & II Chevy V8 Tech Board I think it is interesting how much faster the cars have gotten since this thread was started.
	is it worth fixing/painting? (lots of pics)Pop N Wood replied to caszboy's topic in Body Kits & Paint Man, that is totally 70's.
	I think I may have asked this before, but I know on LS alternators you have to put a resistor in the field circuit HisAndHerz talks about or just what you are seeing will happen. The warning light works a resistor, if it is a bulb. If it is an LED than that is not enough resistance. Wonder if it is the same on your unit.
	So in other words no one has any direct experience with that particular unit?
	Try clicking the link Mario gave you and working up the url from there The have phone numbers on there home page.
	Fuel pump probablemPop N Wood replied to 84Nissan300zx's topic in Trouble Shooting / General Engine My guess would be chaffed insulation on the power wire. These cars are getting old.
	Update Sanderson(JTR) Header and JCI MountPop N Wood replied to Dudeboy's topic in Gen I & II Chevy V8 Tech Board Well I have an LS2 crate motor, which is a Corvette motor, and I know Vinh used a Corvette motor. Perhaps I should look at the wires more closely. I was only doing a trial fit to relocate the dip stick. Maybe I got a wire from the wrong side of the motor.
	Twin Charging: Supercharger Boost Q? - attn Frank280ZXPop N Wood replied to boardkid280z's topic in Turbo / Supercharger I think the Volkswagen one has the tubo and blower running side by side with a flapper valve directing air into the engine from either the blower or the turbo depending upon which one is making more boost. Popular science had an article on it.
	Update Sanderson(JTR) Header and JCI MountPop N Wood replied to Dudeboy's topic in Gen I & II Chevy V8 Tech Board Yeah, VinhZXT is correct. You will need to make a new mount for the passenger side to move the mounting bolt forward 1 inch. It is not that hard to do. Just cut up some 3/16 plate and use the stock aluminum mount as a template. I wish JTR would change the header to move the passenger side collector back a little bit. I just noticed that the other day. How are people with JTR LS headers dealing with that problem
	Just removed 40 useless pounds ...Pop N Wood replied to Zmanco's topic in Brakes, Wheels, Suspension and Chassis I read once that a spare from a Maxima will clear the 4x4 calipers. I would like verification of that since I have the 4x4 fronts and soon enough should have the 240sx rear brakes.
	Fuel injected motors are sensitive to the thermostat used From this thread
	random question - can i mix expoxy with cement?Pop N Wood replied to rustrocket's topic in Non Tech Board In addition to an additive coat them with rino liner. They sprayed all the concrete block walls in the Pentagon to keep the concrete from becoming shrapnel in an attack. Also use a lot of chicken wire or rebar when you cast them
	I can't beat Spark's suggestion for cheap. If it never leaves your driveway that that is the solution. The only way you could do it cheaper is to find a muffler on the side of road. MSA sells turbo mufflers for $49 that work perfectly on a NA Z. I have bought similar mufflers at places like Autozone for $9. You will need to get a double bend to go under the rear cross member, but from there on up you can almost run straight pipe. Hit the local autozone and see what they can hook you up with. I can't imagine you spending more than $100 total.
	Stalls out when throttle is openedPop N Wood replied to SuperPickle's topic in Trouble Shooting / General Engine It would probably help immensely if you posted what type and year of car you have and whether you are FI, carb, heavily modified, etc.
	I did that in the service. Still have a lot of friends in the field. I have been wondering if there will be a resurgence in that area. Trouble is right now it is a collapsing industry. The US hasn't started a new plant since the 70's. The ones that are running are being decomissioned slowly but surely. 40 years from now none of the current plants will still be operating. I think the country will have to turn back to nuclear. The only question is how many years it will take. It is also a tough life working in a nuc plant. Lots of testing and training involved. Worst part is those plants need to be manned 24-7. If you get on with one be prepared to work more than a few night shifts and holidays. I see a lot of kids coming out of school with large debts. 40K to 50K seems to be typical. I went through on the GI bill and with money I saved while in the service. Lived with mom, worked summers only and went through a state university. Came out completely debt free. Got hired as an engineer and had my employer pay for grad school. The military is always an option to earn your way through school. Although Iraq makes that a completely different proposition from when I went in back in the 70's. Did 6 years in a peace time military. Hard to imagine these days. Can't say I have met many engineers who have gotten undergrad degrees with employer money. Get your degrees while you are use to being poor. Having done both it is tough to go back to school once you start working for real. Having interviewed probably 100 engineers I will say don't get too hung up on big name universities. The overwhelming majority of the engineers I work with graduated from state schools. If you can get financial help, then take the money from the named schools. Otherwise don't run yourself into debt and just study hard. when it comes to getting hired grades mean more than the name of the school.
	One last thing to think about is eliminating the stock mount underneath allows you to get the nose of the diff lower. This may help get the driveline angles correct.
	An engineering degree is gold these days. Electrical typically pays more than mechanical. Chemical engineering salarys fluctuate to a large extent with oil prices but are often at the top of the heap. http://money.cnn.com/2005/04/15/pf/college/starting_salaries/ If you want to talk about a reitrement boom, look into defense aerospace engineering jobs. This is a growing concern in the industry. The company I work for routinely makes offers in the 70's for new graduates. The other huge issue is you can't outsource jobs that require security clearances. A huge growth industry post 9/11. And yeah, you don't need a 4 year degree to do well in life, but the odds are hugely in your favor if you have one. Do a little research on what a doctorates is worth in terms of life long earnings. Geologist is a good, rewarding job. But be prepared to make considerably less right out of school than what your engineering buddies will http://hypertextbook.com/facts/2005/VitaRymaruk.shtml Plus I would imagine the majority of the high paying geologist jobs are working for the oil companies and not digging up dinosaur bones.
	brake troubles... not a reaction disk issue.Pop N Wood replied to clsatt's topic in Brakes, Wheels, Suspension and Chassis You need to lengthen the rod going from the brake pedal into the back of the booster (the one that contacts the reaction disk). Make it longer so that the brakes start to catch after a half inch or so of pedal travel. I have no idea with an otherwise stock system why that rod would suddenly be too short. But if a "previous owner" is involved than anything is possible. Triple check that reaction disk in the process.
	That statement is misleading to the point of being untrue. It is true the temperature of the coolant may not drop as much in a single pass through the radiator. But you will be moving the coolant faster through the SYSTEM, getting more passes through the radiator and thus should see lower temperatures coming out of the engine. Moving the water faster, within limits, will remove more heat making your ENGINE run cooler.
	When I lived in California some years ago I ran a near stock 2.4L. I had some getting hotter than I liked issues with the stock cooling system when I would go up the mountain to Big Bear lake on a hot desert day. I then puta 3 row core into the stock radiator, oil cooler, chin pan and MSA fan shroud for the mechanical fan. Never had an issue after that. My car also had the vents in the middle of the hood. Maybe some so cal guys with a set up closer to yours will chime in.
