Pop N Wood
5
Man I really like the look of that.
Why are my rear tires moved forward?????
Pop N Wood replied to Rebird's topic in Brakes, Wheels, Suspension and Chassis
Z's have always looked that way to me. -
I posted the link without looking at it. I modified the link in the previous post to go to the Japanese page rather than the British page.
Put these two ahead of MSA. Much much more responsive customer service http://www.blackdragonauto.com/ OEM and performance Z parts http://www.courtesyparts.com/ Mail order Nissan parts
From the site http://zhome.com/ Z Car Transmission & Rear End Gearing Contributed By: the Members of the IZCC Produced by: Carl Beck IZCC #260 Special Thanks to: Steve Golik-IZCC #356, Tom Bell-IZCC #2802 & Ross Corrigan-IZCC # 255 The Purpose of this page is to give you a quick reference listing of the gear ratios used in the various models of the Z Car. We will try to include both transmission and rear end gear ratios FYI. As of 12 Mar. 2000 -cjb -------------------------------------------------------------------------- Standard Differentials & Rear Gear Ratio's This is the list that we came up with, after discussion on the Z Car List, and review by the subscribers there. Standard Rear End's as Delivered From The Factory 1969-1989 : 240Z 70-73 MT (3.364) (R180) 240Z 70-73 MT 5spd. (3.900) (R180) - non US 240Z 71-73 Auto (3.545) (R180) 260Z 74 MT (3.364) (R180) 260Z 74 Auto (3.545) (R180) 280Z 75-76 (3.545) (R200) 280Z 77-78 MT (3.545) (R200) 280Z 77-78 Auto (3.545) (R180) 280ZX 79 MT,4 Spd,2 Seater (3.364) (R180) 280ZX 79 MT,5 Spd,2 Seater (3.364) (R180) 280ZX 79 All With Automatic(3.545) (R180) 280ZX 79 MT,4 Spd,4 Seater (3.364) (R200) 280ZX 79 MT,5 Spd,4 Seater (3.7) (R200) 280ZX-GL 79 (3.7) (R200) 280ZX 80 MT,2 Seater (3.545) (R180) 280ZX 80 Automatic 2/4Seat (3.545) (R180) 280ZX 80 MT,4 Seater (3.9) (R200) 280ZX-GL 80 (3.9) (R200) 280ZX 81-83 Automatic all (3.545) (R180) 280ZX 81-83 Turbo - all (3.545) (R200) 280ZX 81-83 MT (3.9) (R200) - - - - 300ZX's - - - - - -- - 300ZX 84-86 MT and A/T (3.7) (R200) 300ZX 84-86 Turbo MT and A/T (3.54) (R200) 300ZX 87-89 MT and A/T (3.9 ) (R200) 300ZX 87-89 MT and A/T (3.9 ) (R200) 300ZX 87-89 Turbo MT and A/T (3.7 ) (R200) Note Turbos: #1) after 4/87 only-(3.7 Clutch Type LSD) 2) 88 All White SS used a 3.7 Viscous Coupling LSD) 3) LSD Unites Came With Finned Rear Covers Additional Comments: a) Viscous Coupling LSD requires special splined half shafts - 84-87 R200's can be used in earlier cars, but require modifications they are not direct bolt in swapable to 240/260/280Z/280ZX's c) 84-89 R200's used a 12mm bolt in the ring gear - earlier R200 used a 10mm bolt in the ring gear, so you can not swap Gear Sets with the older R200's -------------------------------------------------------------------------- Standard Transmissions & Gear Ratio's 1970 through 1971 Factory Four/Five Speed Transmission Ratios 70/71 three piece case U.S. Non-U.S. F4W71A FS5C71A 1. 3.549 2.957 2. 2.197 1.858 3. 1.420 1.311 4. 1.000 1.000 5. n/a 0.852 RearGear 3.364 3.900 1972 through 1976 Factory Four/Five Speed Transmission Ratios 72/76 two piece case U.S. Non-US F4W71B FS5C71B 1. 3.592 2.906 2. 2.246 1.902 3. 1.415 1.308 4. 1.000 1.000 5 n/a 0.864 RearGear 3.36 3.900 (72 thru 76) 1977 through 1983 Factory Four/Five Speed Transmission Ratios Note: Ratios in 4spd.'s are the same as 5spd.'s For 1st-4th gears. 77-79 1980 81-83 Borg Warner T-5 {Turbo Only] 1 3.321 3.062 3.062 3.500 2 2.077 1.858 1.858 2.144 3 1.308 1.308 1.308 1.375 4 1.000 1.000 1.000 1.000 5 0.864 0.773 0.745 0.780 1984 Through 1989 Factory Five Speed and Auto Trans. T5 Nissan FS5w71c auto auto turbo turbo non-turbo non-turbo turbo 84-86 87-89 84-89 87-89 87-89 1 3.350 3.324 3.321 2.458 2 2.056 2.077 1.902 1.458 3 1.376 1.360 1.308 1.000 4 1.000 1.000 1.000 5 0.752 0.711 0.759 R 3.153 3.382 3.636 2.400 Special Note#1There was a 5 speed 720 truck('79-'85)transmission that will bolt into an L-6 car, that also has "lower" gearing. However, there were two other sets of different gear ratios available, depending on the truck model: #1 #2 #3 1 3.592 3.321 3.592 2 2.246 2.077 2.057 3 1.415 1.308 1.361 4 1.000 1.000 1.000 5 0.813 0.833 0.813 -------------------------------------------------------------------------- Factory Competition Transmissions 77 - 83 There were Factory Competition 5-Speeds available through NISSAN Competiton Dept. There were two overdrive Transmissions, and four with the direct drive (1:1 in fifth gear) #1 #2 #3 #4 #5 32010-N3130 2.906 1.902 1.308 1.000 0.864 (close ratio) 32010-N3030 3.321 2.077 1.308 1.000 0.864 (wide ratio) 32010-N3220 2.818 1.973 1.470 1.192 1.000 32010-N3221 2.348 1.601 1.296 1.138 1.000 32010-N3222 2.192 1.601 1.470 1.138 1.000 32010_N3201 3.321 2.270 1.601 1.240 1.000 (rally transmissions) Notes: The overdrive (FS5C71B) and direct drive (F5C71B) transmissions utilize the Servo-type (steel) snycro mechanism. For a complete parts breakdown of the listed overdrive and direct drive transmissions see the Nissan Motorsports Schematic catalog (99996-M8015). The shift kit (99996-E3030) is required when installing any of the listed transmissions into 240Z's built up to 8/71. FS5C71A Conversions: These parts will allow the FS5C71A 5-spd transmission from the Datsun 2000 (SLR311) roadster to be adapted to any Z. The R200 flang assy (38210-N3103) is required on Z's built from 12/74 to 7/75. 30401-22010 Clutch Housing 32130-A7100 Tail Housing 32241-A0200 Main Shaft 32890-A0100* Striking Rod Assy. 37000-E4100 Driveshaft (to 8/71) 37000-E8710 Driveshaft (from 9/71) -------------------------------------------------------------------------- 1990-96 300ZX Transmission For Both Turbo and NA. The transmission model is RS5R30A. The 300ZX model is the same for both the NA and TT, but Nissan relocated the starter in the TT, and changed the outer and inner front cases. 1st 3.214 2nd 1.925 3rd 1.302 4th 1.000 5th 0.752 Reverse 3.369 -------------------------------------------------------------------------- Please contact Carl Beck With additions and or changes to this page.
Front Suspension Questions
Pop N Wood replied to IdahoZ's topic in Brakes, Wheels, Suspension and Chassis
Well, just had the cross member out to cut the L6 motor mounts off and no cracks in 18 years of using eccentric bushings. I will probably get rid of them when I do the bumpsteer mod in a year or two. I'll let you guys know should anything turn up. Now broken TC rods, there have been several posts on those. -
Bikes have their place. Where would all the young, otherwise healthy organ donors come from? Emergency room techs don't call them donorcycles for nothing.
R-200 or R-180, Whitch one is for me?
Pop N Wood replied to Nealio240z's topic in Gen I & II Chevy V8 Tech Board
Most R180's are 3:36. Some R200's did come with 3:36 ratios, but they aren't very common and people who have them seem to know what they are worth. This list shows some R230's diffs came in a 2.946 ratio. Would put your 50 MPH RPM at 2115. But expect to drop a grand or more doing an R230 swap. An even better list of diff ratios is on this site http://zhome.com/, about half way down the left had side click on "Index Of Technical Articles " I have seen several Z's where they swap a vette pumpkn in an otherwise stock rear suspension. Don't know what is involved with that swap, but you can get some high ratios in a vette rear. But probably not a cheap solution. Is there an aftermarket overdrive you can add to the back of the TH350? But once again, I imagine not a cheap option. My suggestion is just get a run of the mill 3.5 R200. 3.36 won't buy you much over the 3.5. The ultimate solution is a T56.... -
What a difference the right size carb can make
Pop N Wood replied to deja's topic in Gen I & II Chevy V8 Tech Board
What about mechanical secondaries? holley's site says our light Z cars with low rear gearing are acceptable candidates for mechanical secondaries. Any one have experience with these? -
450 HP to much for a Z frame?
Pop N Wood replied to Forces's topic in Brakes, Wheels, Suspension and Chassis
Whew. That's a relief. My motor is only rated at 446 HP. Should be good to go. -
Funny. GM recommended a 750 cfm carb with my 6.0L.... Guess heads and intake can make as much difference as displacement. -
My pricing estimate seems a little high on this
Pop N Wood replied to Forces's topic in Gen I & II Chevy V8 Tech Board
Might be cheaper, depending upon what kind of deals you get. Might even be more HP than a mild V8. But definitely will NOT weight less. To attempt to answer the question, I don't know that there is any way to accurately estimate the cost of the incidentals with any accuracy. Every swap is different. The fact you have an engine and are not including that in the cost of the build makes your list pretty unique. About the only way I know of is to build an exhaustive list and talley up the cost of each item. Then go back and adjust the values as you actually buy stuff. -
Why are people so enamored with used LSD's when brand new power brutes sell for $550?
I have been running the eccentric bushings and ball and socket TC mounts you mention for the past 18 years. The "urethane" bushings that were causing all of the TC rod failures did not use the ball and socket. This meant the TC rod had to flex to allow the suspension to articulate. My guess is eventually the rods work hardened and snapped. Kind of like breaking a coat hanger by bending it repeatedly. I don't know why you couldn't use the eccentric bushings with the relocated bumpsteer mod. But I don't see the point. Put the hole were it belongs and go back to stock or urethane bushings. If you have to rotate the eccentric bushings down, then that is the same as drilling the hole lower. Supposedly the eccentric bushings can slip. They are not unsafe, but like I said if you are relocating the cross member pivot hole, just get rid of the eccentrics. -
the JTR headers have bigger diameter primary tubes than the JCI ones. Actually I am not sure why anyone would buy the JCI headers. The JCI mount kit is suppose to be pretty good. Seem like a lot of money until you realize how much work it is to engineer your own. Besides, not everyone has the tools and patience to do it on their own. There is something to be said for getting the job done. Making your own cross member is not that difficult. http://forums.hybridz.org/showthread.php?t=105868 Just a lot more trial and error involved.
Damn. Makes me feel pretty good about buying that LS2 crate motor, I should get the whole swap done, with all new parts, for only $500 more than that guy wants for a used motor
Going to a 3.36 rear will only drop your 50 mph RPM from 2800 to 2400. Your top speed will go to 104 mph. The spider gears are the weak point in an open diff R180's. so if you go with some form of LSD it will hold up reasonably well depending on how you drive But you will still be turning over 2400 RPM on the free way. Best to start saving up for some type of overdrive transmission. Probably not the answer you want to hear. -
So what happens if you get there and you realize you don't like it?
Did you really like that "How to Restore Your Datsun" book? I have it, but don't know why I paid someone money for stating the obvious. There is really no useful information in that book.
Can we play Help the Newbie (w/ pics)
Pop N Wood replied to SteelToad's topic in Gen I & II Chevy V8 Tech Board
Keep in mind truck engines will require new accessories, oil pans and I believe intakes. Not a show stopper, but the cost can add up. You simply don't find many F body LS parts in salvage yards. That leaves ebay and GM direct. -
Brand new brake booster went out again!!
Pop N Wood replied to SU'dCrazy280's topic in Brakes, Wheels, Suspension and Chassis
Another possiblity is some type of backfire causing the booster to overpressure. There is only so much vacuum you can pull, thus only so much damage that could possibly be done through "too much vacuum". Do you still have the one way check valve in line to the booster? Maybe that needs to be replaced. -
Then don't open the thread below http://forums.hybridz.org/showthread.php?t=113150
you think that is bad you should see the pictures of his ass
LS2 started, bought the engine!
Pop N Wood replied to smoorenc's topic in Gen III & IV Chevy V8Z Tech Board
Have you decided what mounts you are going to use yet? -
Z's like that went for more than $1000 in CA when I bought mine there 18 years ago. Hard to believe they got cheaper in all that time. Looks promising. Go look at it, but don't make up your mind on it until you see it. Be prepared to leave empty handed if everything isn't as it seems.
