jpndave
    4
Everything posted by jpndave
  1. Can this still be added to, I am interested in two sets of gauges. Thank!
  2. Already planning one. I will start with a Coyote and then change to the Voodoo as soon as I can get my hands on one. Have the Ford Tremec Magnum and Bell for these (Modular pattern) engines. Coyote will be a tight fit between the towers, 1" on each side to spare. We'll see what other issues occur. I'm sure it will need a low profile oil pan amoung other things, probably front mount accessories. It should almost be a front mid-engine configuration. I hope it can be made to sound more european as I think they have Americanized it to keep traditional Mustang appeal, we'll see.
  3. I have a 6.2L and 6L80E in my Jeep Wrangler you can see in my info. If you go that way I HIGHLY recommend getting a native paired engine/transmission. The communication is important for proper operation. Don't need the other modules if done right.I just have ECM & TCM. It is quite large in girth. A 6L90E is about 30mm longer than the 6L80E. If you're really serious about this I may be able to lift one up into my 240Z chassis as I am building a stroker 6.2/6.8 right now for the Jeep and the Trans is out. Don't expect double clutch manual type shifts from that unit. They're better than earlier autos to be sure and I LOVE it in the Jeep but no way is my 240Z getting an auto.
  4. I am. Probably will do a Coyote now and then swap in the Voodoo when available. Changed my T56 magnum to the Ford version. I think it will sound much better with the right exhaust. They appear to have "Americanized" the sound to not lose traditional mustang customers with the GT350. The GT350R, sans resonators sounds better. Aside from the exhaust, firing order and center crank pins are different But it still has the alternating bank flat plane.
  5. For what it's worth I agree with flatrate on this. I looked seriously at gapless top ring and decided against it, everything I saw confirmed the above. Wouldn't consider gapless 2nd. There may be something to be had with this gapless top ring, but largely seems like trying to solve a problem that isn't there to begin with. 2nd ring is always gapped a little looser than the top to avoid flutter on the top ring. I'm using JE pistons with the narrow ring set, metric, steel 1.2mm top, 1.5mm Napier (hooked for oil control like flatrate mentioned) 2nd, 3.0mm bottom.
  6. You need to match the master/slave combination. I'm not sure what volume that slave has. Larger master means more throw at the clutch at a higher effort. Smaller master is less throw and lighter pedal. And remember it's based on the area of the bore, not the diameter.
  7. Width is 2" narrower than the strut towers and that should be the worst of it. I'm a little worried about the alternator and A/C, both low and forward. Ford is going to offer the Voodoo as a crate. Over 500hp and 8,000+RPM with that engine. Should be lighter than even an LS with the flat crank.
  8. I'm leaning toward the wide ratio because 1-4 are more evenly spaced and I would like a low RPM cruise for economy and comfort on the highway. I hate to admit this but I am seriously considering using a Ford engine in this project. I know it's like heresy to speak here, especially on this part of the forum, but that new Voodoo engine is really cool. It has both the sound and high RPM capability that I dearly love about the Z now. I may put a Coyote in it for now and in a couple of years when I can get a 5.2L Voodoo go that route. I haven't decided for sure. Already have a LS3 mock-up block and know that engine inside and out which makes the decision that much harder. I just can't get the sound and RPM I really want with the LS. Plus the way the engines deliver the power, the DOHC with VVT would work much better at having the high RPM with low cruise speed and hit better down low so the car isn't all over the place in the lower gears.
  9. Here is the manufacturer's page. I think mine is a locking 300 series. http://www.newton-equipment.com/aero-filler-cap-range.html It seals with an o-ring that is engaged when you rotate the cover, top shelf product.
  10. I have one of the caps like your original post, aircraft spruce link on socorob's post. Quality and function is superb. It's in the Jeep project in my signature. Make sure it's positioned to allow a fuel nozzle to fit properly.
  11. Well, I might be making a pair of molds...
  12. Have you got a bracket to mount it with? The Gen 3 is kind of a pain that way.
  13. The PCM is very resilient and is weatherproofed to go in the engine bay. I wouldn't mount it right next to the exhaust but most anywhere else is fine. The Gen 4 is easier to fit than a Gen 3.
  14. Here is some information I found. One of these is on the first page of this this thread.
  15. jpndave
    Ford Engine
  16. jpndave
    cytfr
    From the album: Ford Engine
  17. jpndave
    cyotfrmsmnt
  18. jpndave
    cytfr
  19. I am seriously considering going this route over the LS. That is saying a lot, I KNOW the LS and have done swaps on them before. I have a 6.2L I am stroking now in my JK, 4" to a 6.8L and had planned a similar non-VVT engine for the 240Z. The 4 valve Coyote or much, much more ideally the Voodoo seem to really have what I want in the Z. That is a high revving (over 8K on the Voodoo!) powerful lightweight engine and in the Voodoo's case, that sublime, exotic sound! My Z has a balance, blueprinted short stroke 2.6L (280 bore, 240 stroke), cammed tri Weber setup now. I want lots more power but the high revving engine and sound are great. I hate to lose that. Also, with the LS, many are saying that the low end at slower speeds is simply too much when you get up in the power levels. This seems like the perfect balance. A true sports car engine that loves to wind up. And with the VVT and 4 valve heads, you can have the smooth bottom end and still keep the high power levels. So, after reviewing the dimensions I appears with the Coyote, that it is tight but doable on the width. I'll likely have to make headers but will probably want to do that anyway. I may be able to modify some shorties for now and do long tubes later. The alternator and A/C might cause issues, hard to tell on that. With the Voodoo, time will tell. They do plan to offer it as a crate. It may be a while before that is available. Hopefully the Voodoo will keep a standard Modular bellhousing pattern. Don't know if I would trust the 3160 and should have a T56 Magnum in a week or so anyway. They are rated to handle the RPM for shifting. Anyone have any more current info on the Voodoo or more knowledge/suggestions on the Coyote? Any threads I am missing? I think I am in for this route. Will they cruise at say 1500RPM at 60MPH? My LS does that pushing a 5500lb. rig on 37" mud tires quite nicely. Really helps with comfort and mileage. But, stand on it and drop two gears and the fun starts! A 2300-2500lb. Z should be easy to push along by comparison.
  20. HP tuners or EFI live can disable the VATS and set your parameters to what you need in the Z. We have both here but usually use HP Tuners. Depending on how you have your engine wired, you'll want VATS disabled, tire size and gear ratio set, speed input set depending on what you have for VSS, emissions turned off if you aren't running it, tach set to a 6 cylinder out probably (4 hi and 4 low on a Gen 3, Gen 4 is a little fussier as 58 isn't easily divided by 6 but 5 high and 5 low gets you close enough). On the Gen 3 it's possible to get full operation out of the PCM only, even cruise. I deal with this stuff every day. Let me know if I can help.
  21. It sounds like you have a few things going on. Who reworked your harness? Are you trying to go through the GTO original harness and PCM to trigger the starter? I would go straight to the starter for that wire, not through the GM harness. The PCM will need to be flashed for it to run. You don't need the body module for engine operation.
  22. Any updates on these? Still available?
