Leon
    25
Everything posted by Leon
  1. Finally had a chance to degrease the diff, reseal every joint, and pop in the Kameari stubs. I torqued the pinion nut to 135 ft-lb per this nifty blog article: https://inzane240.blogspot.com/2014/01/updated-info-on-subie-r180-install.html. Planned install is this Saturday! I've also ordered W65 idle jets from Keith Franck so hoping to have this car fairly dialed in for a mountain drive on the following Saturday.
  2. You're right, it's more of a spacer than a crush tube. The shim is used to set pinion depth. There are a few active threads on this topic at classiczcars with a few folks there rebuilding their R180s.
  3. The diff arrived this past Tuesday and I confirmed that the stub axles fit! I'm awaiting my pinion and side seals to arrive next week. In the meantime, I'll clean up and paint the diff and then it's install time. I've decided to install it as-is and only fit new clutches into the diff if I feel like it's needed. I bought bolts for the rear cover from ZCar Depot instead of fitting studs. I'm assuming this won't be the last time I pull this diff so I'm hoping that this makes the process easier.
  4. Man I sure hope so... the research I've done seems to indicate that they match but I can't say I found anything 100% conclusive on this. We shall see.
  5. I gave up trying to estimate completion dates long ago. In Soviet Russia, project completes you. 🙃
  6. MONZTER intake part 2: NA Bugaloo!
  7. Hey Aydin, in the US, the 3.9 was '04-'05 only unfortunately. The '06 was unique in that it was a CLSD 3.54--'07 and later were all helical 3.54. Good thinking! I'm planning on inspecting the carrier and replacing clutches once the diff arrives. I had ordered fresh clutches from Racing Diffs with the thought that I was going to refresh my current diff but now they can be used for the Subi unit. Speaking of which, the diff has now arrived from the dismantler and is in Tyler's hands. He has gone the extra mile to pull the cover and take plenty of pics to confirm that it's indeed a 3.9 CLSD. ❤️ It'll be shipped out from Japan after New Years so hopefully in my hands in a few weeks!
  8. Thanks Garrett! I bet many can relate. But I know you especially have been focusing on every single detail, any idea when you'll be back on the road? Between family, work, and other projects, it's difficult to dedicate the time like I used to. But after all these years, I still love this car. This Z will be 50 years old in a couple months and it amazes me what this 50 year old car can do. 🤙
  9. I decided to act quickly as to not have the car down too long. After tireless and borderline obsessive searching, I committed to getting a Subaru R180 for availability reasons. The cheapest solution for stub axles turned out to be Kameari which I found for significantly cheaper on Yahoo Auctions Japan rather than buying inside the US: https://www.jauce.com/auction/m1117548805. They were $417 shipped to my door vs anything US-based being $500+. The fresh hardware is a nice value add. As for the diff, I wanted to retain the 3.9 ratio paired with the late ZX close-ratio box vs the 3.54 which I initially built the car with. I did like the deep overdrive with the 3.54 for highway cruising but the 3.9 gearing is perfect for mountain driving. In the US, the 3.9 LSD was only used in '04-'05 STI's and therefore is quite a bit tougher to find now versus 10 years ago. When they do pop up, they seem to go for way too much, for my wallet anyway. So I started searching other avenues to get one of these... There are more available on eBay UK but they tended to be missing the rear cover for some reason and condition was not so clear. Then I turned to the JDM which ended up being more complicated to understand as far as which models to target. Long story short, I learned that at least the '01-'05 STI with DCCD transmission got a CLSD 3.9 R180--good enough for me. I ended up contacting Tyler at Magnolia Auto Supply (shout out: https://magnolia-as.jp/) who helped me source a diff from Japan! Japanese dismantlers seem to be very thorough in how the parts are presented, this one came out of an '03 STI with DCCD and has 89k miles on it. This path is likely a bit more expensive than the UK route but I felt good knowing more about the part. The hope is that this diff lasts the lifetime of the car given that I don't put that many miles on it. The diff is currently on its way and I'm very much looking forward to getting the car back on the road. I've got a fresh diff cover gasket and seals to install once it comes in. I just need to source a Nissan R180 pinion flange and decide on studs vs bolts for the rear cover. Note the PN: 27011AA860 Per Subaru:
  10. In other words, I think this diff may have just become a parts diff...
  11. Unfortunately, more unhappy diff news this evening. It seems whoever assembled this diff majorly screwed up, to put it lightly. As I said, a local diff shop was the last to touch this diff when I had them inspect it... 10 years ago. So the costs may very well be sunk at this point which is disappointing. There is heavy embedment of the friction plate ears against the carrier and damage to the cover itself (perhaps due to mishandling during install?), I have a feeling the clutch vs washer vs plate stackup was done incorrectly. Elongation of clearance holes in carrier due to loose ring gear bolts And the mystery of where in the world are the LSD ramps was solved... the pressure ring was installed 90° off and the cross pin was put in the wrong place. INSERT REGRET AND DISAPPOINTMENT HERE.
  12. (1) Hoodie Size: XL Color: Dark Heather Zip: 94010 I'm glad you're doing another run, Ryan! I was bummed when my hoodie from the original group buy took some damage last year, wasn't sure I'd have a chance to replace it.
  13. Thanks for the heads up! Should be fixed now, let me know if you still can't see them.
  14. Looks like a year and a half is about my post cadence these days. I've been driving the Z sparingly but with much enjoyment since fixing the throttle hang. It's finally feeling close to getting to the level of refinement I want out of it. Unfortunately the diff started making some extra whiny noises beyond what it was already making so I pulled it this past Saturday. I got the chance to pop the cover off and found that I'm the lucky winner of 6/8 loose/snapped ring gear bolts. 😱 I'm not sure whether it's salvageable but I'm going to tear into it as time allows. The last time this diff was opened was by a local diff shop but I can't say for certain whether they had removed the ring gear... This is a Datsun Comp R180 3.9 CLSD so I'm hoping I can save it and run it but it looks a bit grim at the moment. The cross pin position is not centered and doesn't seem to have any ramps? It's late and I'm confused, will be looking into this later. The spot faces have heavy embedment from the loose bolts. If this LSD carrier can be reused, it will need machining. I pulled these bolts out by hand, their ends are broken off and lodged in the ring gear.
  15. Sorry, I'm being a bit cheeky there. I may actually be interested. Let me know if you're willing to ship and what you might want for it. I've got a few bits of harness on my early 260Z that need servicing. Most interested in everything going to the steering column, headlight and taillight wiring although it seems that some of that may not be available.
  16. 17 month update! The Z hasn't seen much action as I've been dealing with a perpetual throttle-hang problem and inconsistent low-speed fueling--lots of popping out the carbs at low load/throttle openings. The low-speed fueling was dealt with by a trip to Keith Franck's house on New Years Eve 2021 to use his custom progression-hole drill fixture. The first p-hole in my 45DCOE 152's was too far upstream, you couldn't even see the throttle plate through it at idle. This is a common problem with the 152's and Keith's fixture was the perfect tool to fix it. It turned out to be the correct diagnosis! I was rewarded with virtually no more popping out the carbs during low-load operation, the freeway cruise home was the smoothest it's ever been... besides the fresh rock chip in the windshield. But now the rev-hang problem was even worse, although the engine would return to idle after a sharp throttle blip which hadn't been the case before. This is an issue I've been dealing with, at various severity levels, for the entirety of the 9+ years I've owned this Z. I was invited to a cars and coffee event this past Sunday, 5/29/22, which was inspiration for the next round of trying to fix it. So the carbs came off for the 132nd time, this time with the intent of resetting the throttle butterflies. I decided to pull the carbs off the manifold while on the car as to not waste the manifold gasket which had been port-matched when I had it apart last year. What I also discovered were some slight interferences with the TWM manifold (would love to replace this janky manifold with a Datsun comp or Harada piece) as well as a non-functional accelerator pump on the #2 carb. I ground down the manifold in the offending areas with a file and radiused Dremel burr, this worked very well. Swapping accel pump pistons from carb #2 and #3 did the trick for making the #2 pump function again! I chalked it up to slight tolerancing issues. I then spent a good amount of time with a flashlight backlighting the butterflies, trying to get them as sealed as possible. I first set all the bearing preloads with the throttle shaft nuts as to set the throttle shaft in place. Then I loosened the butterfly screws enough to get the butterflies moving. Setting the butterflies was a matter of seeing where the light was coming through and trying to set it in a position where the light "leak" was even and minimize. The butterflies are eccentric in shape so turning them a bit here and there helped find the optimal position, along with snapping the throttle shaft for a bit of self-alignment. And I finally have the crisp throttle response I've always wanted! It could be better but it's a massive improvement over what it was. I'm still missing that "zzzzz" noise on overrun when snapping the throttles closed but at this point, I'm happy. I made it to the C&C yesterday and did about 160 miles of excellent ripping through the East Bay and Santa Cruz Mountains! Photos from recent drives: My son likes to service his car while I work on mine, we ensure that safety best practices are always followed.
  17. Nice work Phil, your home-brew solutions never cease to amaze.
  18. What kind of shape are the door cards in? Is the chrome trim still intact? More detailed pics would be great. Thanks!
  19. I was going to suggest NASA ST but it would be a tall task to make a Z competitive against GT3's and Viper ACR's. Not saying it can't be done but... anyway, we've gone way off topic on this fantastic thread.
  20. Just keep an eye on those gland nuts. I'd suggest checking torque after each event. You should be able to easily get a wrench through the spring in order to do so. Minimal disassembly required.
  21. Inspirational work as always Derek, well done! I enjoy following along with your design process. Is there any recent footage of your heads on a running motor? Aydin, Rebello is fantastic. They can take a long time to get things out the door and are pretty old-school but they've been thorough and accommodating to work with in my experience. They did a great job on my P90. Rob @ ZCG is incredibly into what he does. He can be intense but I respect his passion and tenacity in doing top notch work.
