Leon
    25
Everything posted by Leon
  1. Hell yes! What did it put down on Rebello's dyno?
  2. William is pricey and will take a while but his work is fantastic. Rob at ZCG sends a lot of his cars through William's.
  3. Congrats Takashi, the Z is finally driving! Drove mine to work last Thursday and Friday. Looking forward to a drive sometime.
  4. Thanks Takashi, I look forward to it!
  5. I have a buddy running 235/50-15 Toyo R888R's on a 15x10. There's a bit of stretch but not a silly amount. The Achilles ATR-K come in a 245/45-15. Both tires are R-compounds, essentially semi-slicks.
  6. I've been driving the Z sparingly due to work and family but I dusted it off this week while I had a couple days off and actually put a wrench on it. I replaced a frozen fan clutch. Yay! I've also been having an issue ever since I swapped out the struts, the rear brakes lock up after parking the car. I transferred the brakes over to the new struts so something happened in that transition. Turns out just the right rear parking brake adjuster keeps adjusting, every time I put the handbrake on. I can yank on the handle multiple times and it just keeps on ratcheting until the brake locks up. I haven't have time to diagnose yet so I've disconnected the right rear clevis for now. Still plenty of things to do but I'll whittle away as time allows. Happy New Year everyone!
  7. If I'm remembering correctly, there was a migration quite a few years back where inactive accounts were erased, or something to that effect. @SuperDan can elaborate, I'm sure. Welcome back to the game.
  8. I'm not familiar with the EFI stuff but where is the PCV valve located on that manifold? Are there any other possible oil paths into the intake that you haven't explored, outside of the stem seal and piston rings?
  9. Sounds like a rich condition more than oil fouling. Can you run the injectors and rail off of the manifold and compare the spray patterns? Vacuum does seem pretty low unless it's a radical cam. I get about 17-18 inHg at idle with a .540"/270° cam. It's all about the overlap and IVC point so you can also have poor vacuum if the cam is too far retarded. Doesn't necessarily explain a fouled plug but worth looking into.
  10. Looking forward to hearing this run!
  11. Will send PM when my donation status changes. You should've received my cell number if you look in your email notifications.
  12. Well looking forward to finding out! Perhaps an Ecotec? I'll PM you my number.
  13. Nice, glad you made it! Trekkor and crew always run a great event. A few of my coworkers went (the silver S2000 in the background of your photo and the other in a Model 3). I'll be running at Sonoma Drift for the first time this coming Wednesday, in case you or @stupid_fast plan to be there. Gonna guess that radiator is from an LSx vehicle.
  14. I prefer more rubber but overall I dig the build!
  15. I'm not saying that it wouldn't work, just that it's not good practice. I understand that your case is a particular one being it's a race car. The problem is that no matter how good your MAP signal is, not having a manifold reference for the FPR means that your VE table will be delivering differing amounts of fuel even if the VE table values are equal. Not having the reference makes tuning more difficult and reduces your resolution in high-vacuum areas of the VE table. Of course it can be done, as you have. I just disagree with your premise that "most EFI installs want constant pressure". Most EFI installs definitely have MAP-referenced FPRs for the reasons above, especially for street-driven cars as is the case for the OP. I'm including OEMs here as well, doesn't matter whether they're ITB or not.
  16. What makes you say that? An FPR without vacuum reference will lead to a wonky fueling table at the very least. It's good practice to maintain a constant pressure difference between the fuel rail and intake manifold, it helps take a variable out of the fueling calculation.
  17. It depends on how you set up the return springs. There will already be a load from each carb/TB with an additional load if a tension spring is used as an auxiliary return. A torsion aux return spring would help reduce loading. Something else I just noticed, there are three throttle rod supports and the manifold is actually three individual pieces. It's held together via a bolt-in support. The position of that middle (redundant) throttle rod boss is going to be very hard to control and will likely lead to throttle rod bind, which will then make for a sticky return to idle and require heavy return springs thereby putting more stress on that cantilevered boss. You'd be better off having the manifold be one piece and consider removing the redundant throttle rod support. Better late than never I suppose, I'm curious if this project ever got past the design phase!
  18. Well shit! Hope you can get it sorted before the 14th. I'm not sure an F22C1 would fit the character of the car well but to each his own. VQ is a cool swap and the LSx is a given.
  19. Nice, we'll see if I can make it. I'm already planning to run the road course with NASA the weekend before so the wife will take some extra convincing if I'm going to make it happen.
